Question about Shuttle MS51N Motherboard
Boot up takes too long
After pressing power on button it takes roughly 2 minutes for the xp pro boot screen to finally finish loading. it pauses a few times during load (looks as if its going to crash)
once its loaded its fine, works normal.
  • 33 Answers
This happens when the computer gets full of "junk" (this happens with any computer over time) and can be remedied with a fresh windows install.
If you don't plan to reinstall windows in near future I suggest you go to Control Panel -> Add/Remove Programs and uninstall any software you don't use/need
Also tweaking the system registry migh help speed up boot time:
1. Click ‘Start’ then 'Run’
2. Type in ‘Regedit’ then click ‘Ok’
3. Navigate to ‘HKEY_LOCAL_MACHINE\SYSTEM\Cur rentControlSet\Control\Session Manager\Memory Management\PrefetchParameters\ ‘
4. Right-click on “EnablePrefetcher” and set the value to ‘0′
5. Close 'Regedit'
6. Navigate to 'Windows\Prefetch' folder (usualy drive on C:) and delete all its contents
5. Reboot.
7. Enjoy greatly improved boot time ;]
Hope this helps!
Posted on Oct 01, 2008
Repair start up
i found this very good guide: 1. If your operating system is XP, CTRL and F11 key simultaneously when you see the dell logo after turning on the Laptop and follow the screen instructions.
* Power the computer on.
* When the Dell screen appears press and hold the CTRL and F11 key simultaneously on the keyboard, then release them both at the same time.
The Dell PC Restore by Symantec window appears.
* Click the Restore button or press the key to highlight Restore and press the key.
A caution message appears advising that all data will be lost.
* Click the Confirm button or press the key to highlight Confirm and press the key.
The Progress window appears. Once the process is begun, Dell PC Restore usually takes only 8 to 10 minutes to complete.
When the restore is complete, the message The system recovery process was successful appears.
* Click the Finish button or press the key to highlight Finish and press the key.
The computer will restart.
2. If your operating system is VISTA / Win 7, tap F8 key when you see the dell logo. It will take you to advanced boot menu options under which you will see Repair your Computer, Select that option and enter your password if it asked, then you will be seeing list of options like system restore, command promt, etc., In that the last option says Dell PC restore or some thing like that. Select that option and follow the screens .. Thats it.
* Start the computer.
* As the computer starts, press the F8 key until the Advanced Boot Options menu appears on the screen.
* Press the (Down Arrow) to select Repair Your Computer on the Advanced Boot Options menu, and then press Enter.
* Specify the language settings that you want, and then click Next.
* Log in as a user who has administrative credentials, and then click OK.
* Click Dell Factory Image Restore.
* In the Dell Factory Image Restore window, click Next.
* Click to select the check box for Yes, reformat hard drive and restore system software to factory condition.
* Click Next. The computer is restored to the default factory configuration.
* When the restore operation is completed, click Finish to restart the computer.
3. If in both case, the Factory default didn't work, then your laptop's factory image defaults partition have vanished (i.e. Corrupted / Deleted). So you have to do Operating System re installation with the Operating System CD / DVD shipped along with laptop. Follow the below link to install windows XP Pro on your own.
Feb 01, 2014 | Dell Inspiron 6400 Notebook
HARD RESET KINDLE 2
Is it charged?
Hold down power button, may take up to 20 seconds, You should notice screen blink a few times, go black, finally come back to the "boy under tree" page. At this point let go of the button and let it finish resetting itself. After a minute or less it should be ready to go again.
Jul 30, 2013 | Amazon Kindle 2
Tryed to install xp pro with sp2 included but gets as far as please insert xp2 disk ! so switch off as it wont accept and it does the same again 39 mins to go but wont go any thurther ...i have a new disk...
Boot Your Computer from the Windows XP CD
Turn the computer on. When the Dell logo screen appears, perform the following steps:
Press the key on the keyboard. (A Boot Menu appears.)
Insert the Windows XP Operating System CD into the CD Drive of your computer.
Press the key to highlight the first CD-Rom listing.
Press the key to boot from the Windows XP CD.
Press the to boot from the Windows XP CD when prompted. You will have only a few seconds, watch closely for the message. (The Windows XP installation begins.)
After several moments of initializing some modules, the Windows XP Setup screen appears.
Press the key on the keyboard. (The Windows XP Licensing Agreement appears.)
Press the key to agree and continue. (Setup searches for previous versions of Windows.)
Press the key if any previous versions of Windows are found. (The Windows XP Setup partition window appears.)
NOTE: If C: Partition2 [NTFS] is listed on the screen, complete all of the steps below. If you do not see the listing, you can skip to step * Press the key to create a new partition using the size listed..
Use the arrow keys to highlight the listing and then press the key.
Press the key to delete the partition.
Press the key to confirm deletion of the partition.
Use the arrow keys to highlight Unpartitioned space.
Press the key to start formatting with NTFS. Setup will examine the computer/copy files;
this may take some time.
During the graphical user interface phase of setup you will set the following options:
1. Regional and Language Options.
2. Computer Name (Windows XP Professional will also require an Administrator password to be created).
3. Personalize Your Software
4. Modem Dialing Information (if a modem is present).
5. Date and Time Settings.
When these are done, the computer will restart automatically. When the computer finishes restarting the Finishing Setup phase begins. You are required to input information during this phase.
1. Click the OK button at the Display settings window.
2. Click the Next button at the Welcome to Microsoft Windows window.
3. Click to select No, not at this time at the Ready to register with Microsoft window and then click the Next button.
4. Click to select No, not at this time at the Do you want to set up Internet access now? and then click the Next button.
5. Type the user name of your choice in the Your name: text box at the Who will use this computer? Type the name of any additional users who will use the computer in the additional text boxes provided and then click the Next button.
6. Click the Finish button at the Thank you!
Jun 29, 2011 | Dell Inspiron Mini 9 Notebook
Installing on Windows XP
Hi Good day!!! Follow this step
1. Insert your Windows XP installation disc into your CD drive (Home or Pro--it does not matter).
2. Now as you computer boots a little more it will say "Press any key to boot from CD.." press a key to do so.
3. The CD will load up a blue screen and then spend a while loading files it needs. When it is finished it will list a few options, mainly "Press ENTER to set up Windows XP." Press Enter or Return.
4. Now you will be at a screen to select where to install Windows to. This is where you can delete old partitions and format drives. The box in the bottom half of the screen shows all your drives and the partitions that exist on them. Use the Up and Down arrow keys to highlight your "C:" partition and press the 'D' key (if all that shows up is "Unpartitioned space" and you have no C: or D: partitions, skip this step). On the next screen press the 'L' key to finalize deleting the partition.
5. Now you are back on the screen to choose where to install Windows. The box on the lower half of the screen should no longer show a partition but simply have an entry "Unpartitioned space xxxxxMB." Select this with the arrow keys and press the 'C' key to create a partition on the drive. The next screen tells you the minimum and maximum sizes the partition can be and lets you pick the size. The default size is the maximum, but double check that the number entered is the maximum and hit enter.
6. Now you will again be back at the choose where to install Windows screen. But this time you will have a partition that looks something like this "C: Partition1 [New (Raw)]xxxxxxMB." Highlight this entry and press enter.
7. The next screen lets you choose which file system to format the drive with. Choose NTFS as it is faster and more secure. If the drive is brand new and has never been used before then use one of the options that ends in "(Quick)." Or, choose one of the lower down options. Use the arrow keys to select the proper one and press Enter or Return.
8. From here you are all set and the installation of Windows will proceed starting with a format of your drive. This will take a while (over half an hour) so you can take a little break
Thank you for using FixYa
Don't forget to vote thanks!!!
Nov 09, 2010 | Broderbund Family Lawyer 2003 Essentials...
How install xp in usb pen drive
Download the following files from Internet and follow the instructions bellow.
1. USB Formatter.exe
2. WinSetupFromUSB_0-2-3.exe
Instruction.
!!!!Set Up Intallation!!!
Note:
*If Required To format with HP Formatter use USB formatter and Donot Bypass the Instruction.
Note: When Formatting Choose NTFS ( this is the Most Important!
1.Install WinSetupFromUSB_0-2-3
2.Follow the Instruction
3.Browse the Source XP cd
4.Click GO. ( note: when making bootable USB! dONT Press or check anything just GO only )
5.Wait until System Process Finished.
*******Before Installation******
!!!!After Finished!!!!
1. Exit the USB.
2. Safety ReMoved!
******Final Installation for Setup*****
!!!Installation to your Netbook/Laptop/Desktop!!!
1. Insert to your Laptop or NetBook USB HUB!
2. In the BOOT SCREEN! bott from CD/DVD?USB. drive
3. Press Enter
***** the Screen will boot Dont Press anything let the program Run for Installation!!!
4. You will see that the System Prompt installing The PART - 1
Let System Continue and Donot Press Any KEY. until its. Finished!!
Enjoy.....
This is new Version for XP to make XP USB Bootable for your Netbook or any other computer..
Aug 25, 2010 | Computers & Internet
HOW DO YOU BURN A DVD ON A SONY DVD RECORDER RDR
Make sure your Sony input signal is on L1 or L3 (the inputs in back of recorder) or on L2 which is for inputs for cameras(located in front).Once you get a signal, you're where you need to be. Choose your recording mode for recording speed (pull down the flap on the remote control for this button and also the input button).
Choose from between1 hour and six hours. To archive really important stuff, stick with the first 3 speeds. TV recording can be on 3, 4 or 6 hour mode.
Push the record/pause button once. This will put the recorder into the record/pause mode and then it awaits you pushing it again to start recording immediately. Just pushing record will force the machine into a 3 to five second delay before actually recording anything so you might mess up and miss the first few seconds of your input. Suggest you use a dvr-rw or dvd+rw to practice on.
When your recording is done, just push the pause again. It stops recording but allows you to add more on to the first recording without starting a new chapter if you want. Just continue to release the pause button to continue.
If you are satisfied that you are finished, then push the pause button to stop recording. Wait for the info to be written(flashing message on screen). When it stops, you may play the dvd.
Notice- since the dvd has not been FINALIZED, you may only play it back on this unit without finalizing. It will not play on other dvd players unless you finalize it first.
To finalize, look on remote for the TOOL button. Press it once. Now push DISC INFO once. Use arrow keys and enter button on remote for the following. Scroll down to FINALIZE and press enter.
Use arrow keys to scroll to OK. push the ENTER button. Finalizing should take between 30 seconds and 2 minutes.
Warning- if titles or chapters are to typed in, it must be done BEFORE finalizing. Finalizing afterwards cannot be done.
Erasing can be done in part or all if using an RW+ or RW- disc
Dave
azsnoopy1@cox.net
Nov 19, 2009 | Sony RDR-GX300 DVD Recorder
Keeps rebooting, how do I do a master reset
The T-Mobile Dash™ includes a button sequence which can be utilized to perform a hard reset. This method is much more difficult to do but it will perform the reset if the menu options are not available.
Note: Before attempting this procedure make sure to backup your data using ActiveSync. All unsaved data will be lost.
Hard Reset
1. Power the device off by pressing and holding the Power key.
Note: If device is unresponsive remove the battery.
2. With the phone off press and hold both soft keys (The two keys directly under the screen, used to open menus.)
3. While continuing to hold the soft keys, press and hold the Power button for 1-2 seconds.
4. Continue holding the soft keys until you see a message that starts with This operation will delete….
5. Release the soft keys.
Note: If you see the standard boot up screen load steps 2 and 3 were not performed correctly.
6. A boot splash screen will appear, followed by a black screen prompting: Press Send to restore factory defaults, Other keys to quit
7. Press the Send key.
8. When prompted to powercycle device, select Ok
Note: Once the hard reset is performed it could take up to a few minutes to completely boot back up.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Jun 14, 2009 | T-Mobile Dash Smartphone
Pause at bios/ XP welcome screen P4S800-MX
Replace M/board BIOS battery its flat and when you power on it takes a while for it to operate BIOS
Sep 30, 2008 | ASUS P4S800-MX Motherboard
Finalize a CD
Put the cd back and press finalize...Wait a minute until finalizing time is displayed...After that press the pause button and it will start finalizing....It will count down until it is finished...
Jul 21, 2008 | HHB BurnIt CDR830 CD Recorder
Shuttle MS51N Motherboard Logo
75 people viewed this question
Top Shuttle Computers & Internet Experts
Iqbal Husain
Iqbal Husain
David
David
Alun Cox
Are you a Shuttle Computer and Internet Expert? Answer questions, earn points and help others
