Question about Gaggenau GI936-760 Dishwasher
Gaggenau dishwasher model GM- 915-710
The dishwasher motor keeps running when turned on, and the display has an "F" lit in it. There is no description in the manual for an "F"!!
There is no water circulating and no parts moving inside, but the motor is running.
thanks
    President:
  • 1,462 Answers
I suspect you are hearing the drain pump working due to the antoflood being actuated.
remove the bottom front panel and bottom tray is exposed and it is probably full of water. mop water out and machine will work. if fault reoccurs, then you have a leak
Posted on Oct 03, 2008
How do you "reset" a Gaggenau dishwasher model GI240760/01 when it does not turn on via the touch pad?
then I would call the same place again . writing down the instructions this time .
Jun 08, 2016 | Gaggenau Dishwashers
My gaggenau dishwasher GM 954-110 is not working. when i switch it on the display panel shows 2H.
Hello, welcome to FixYa.
The dishwasher you're speaking of (provided it is indeed a Gaggenau GM954) is built by Bosch as you may or may not know.
To address your concern regarding the 2H in the display actually needs to be done in two parts. I'll start with the basic info associated with the 2H displayed.
This can be simply indicating the previous cycle exceeded a 2 hour wash cycle, not necessarily an error and can be attributed with too cold water entering the dishwasher (below the recommended 120F), a longer than normal drain time (due to partial blockages, kink etc. hence longer time needed to complete the cycle) or inproper water circulation during the cycle.
Aside from these issues, it (2H) can also mean the unit has a heating error and if left long enough will show another error of "1" in the display, extremely long wash times, etc.
**The first thing I'd suggest before attempting any repair is running an additional cycle while making sure the water inlet is hot (120F optimum) and the unit does indeed drain fine.
**A fair indication of proper draining is to start a cycle and once washing begins (2-3 minutes) activate the "cancel" and the unit should adequately drain in the 2 minute time allowance.
**To identify proper water circulation, place an empty cup in the upright position in the top rack, start a cycle and inspect the cup after 2-3 minutes and it should be full of water.
After trying and posting the results of these thing's we can move forward with potential heating errors, the cause, and how to remedy them. Let me know what you find and I'll continue to assist you in any manner possible going forward. Good luck.
Regards,
Macmarkus :)
Jun 30, 2011 | Dishwashers
Dishwasher will not run, 2 lights on display panel are lit, but dishwasher won't run.
Jump out the door interlock switches. You will have to seperate the inner panel from the outer door to gain access to these switches. Be sure to turn you household breaker off before removing the first screw. A shorting door switch will allow voltage to pass through but very minimal current. This could possibly be the reason you get lights but not enough current to turn on heaters and motors.
Feb 04, 2011 | Frigidaire Dishwashers
My bosch dishwasher control panel displays 0H on the time delay. When I start it the OH go to 2H. It then starts running and does not stop. The cycle minutes don't display. It's model number SHU5302UC...
check to see if your unit has a recall on it because if it does you will get a free control module from bosch.
your problem is the control module. thermador .com is the site to lookup. gaggenau,bosch,thermador they are the same ccompany. let me know if this helps by sending a 4 thumbs up post
Feb 27, 2010 | Bosch 24 in. SHU53 Built-in Dishwasher
Gaggenau dishwasher keeps running
press the intensive and crystal buttons @ the same time, the display will change to 0. Close the door the pump will run for a while when the pump stops the dishwasher is reset.
May 26, 2008 | Gaggenau GI936-760 Dishwasher
F message n Gaggenau 936-760
Prime the dishwasher by pouring a large glass of water into the filters on the floor of the dishwasher. Then close and run the dishwasher as usual.
Nov 23, 2007 | Gaggenau GI936-760 Dishwasher
Gaggenau GI 936-760 dishwasher
Buy a new one and sell me the door. I have been looking for this model's door for a long time!
williamduck@comcast.net
Aug 02, 2007 | Gaggenau GI936-760 Dishwasher
Gaggenau GI936-760 Dishwasher Logo
791 people viewed this question
Top Gaggenau Dishwashers Experts
Are you a Gaggenau Dishwasher Expert? Answer questions, earn points and help others
