Question about Homelite ZR10926 16 Chain Saw
Craftsman 358.352070-14 chain saw start problem
Have cleaned carb and replaced gas oil mixture. seems to not be getting fuel to the carb. does the carb **** the fuel in or is their a pump that has to be replaced. i can see a filter in the tank attached to the fuel line. how is the best way to analyse fuel problem. thank you, mac
  • 76 Answers
You could try and prime the carburetor and start the saw. If the saw starts for a short while, but dies, than it probably isn't getting fuel into the carburetor, which means that the carburetor either needs to have a rebuilt kit installed, or adjusted or both. This could especially be true if the saw has been around for a while and used quite a bit.
The filter in the tank usually doesn't go bad, but it doesn't hurt to replace it. Usually it is obvious when they are dirty and need to be replaced.
Posted on Oct 05, 2008
No fuel going to carb
Either you have a air leak fuel inline or at fuel tank or a plugged up carb- sour aged fuel or foreign debris
Jun 12, 2013 | Craftsman Sears Chain Saw Manuals Model...
Craftsman chain saw 358.350870 starts but will not continue to run
look for gas tank vent. if clogged it will cause a vacuum in the gas tank and not let gas flow to Carb.
Dec 17, 2012 | Garden
MY HUSQVARNA 36 AIR INJECTION chain saw does not get gas to the spark plug. Checked and cleaned the fuel filter and line and it seems to be clear....??? What else would prevent gas from getting to s
this new gas is a carb killer you will need a new diaphragm for the carb and there is a little screan next to the needle and seat that can be cleaned. about a 5.00 repair if done right.. use marine gas
Feb 03, 2012 | Husqvarna Craftsman 36cc, 16 In. Gas Chain...
Saw has lost power. Consumes a lot of fuel. Runs good from half full to empty but it surges during this time. I checked and cleaned all around the and drive, the air filter, and checked the spark plug....
There are very few things that will increase fuel consumption, blocked spark arrestor in the muffler ( metal gauze in the exhaust out let ) blocked air filter, part blocked exhaust port ( remove the muffler and check ) if the fuel tank is seperated from the chain oil tank with a gasket you may have a leakage between the two ( is the chain oil getting thinner and smell of fuel, other problems may be in the carb, leaking inlet needle, this will require a carb pressure test to prove, if you have a small bulb pressure tester, remove the fuel hose from the carb and connect the tester, put approx 2 psi in, the carb should hold this with no pressure loss.
Feb 07, 2011 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
Jonsered 2171 no gas going to carb. Put gas in carb run for few sec's. Blew out fuel filter seems to be fine. Not much use on saw.
the reason is you need to clean out the carb,if they dont get used much the oil/gas mixture turns to a varnish in the small carb ports and fuel can no longer get thru the carb
Mar 28, 2010 | Garden
Gets hot, sizes up.
Clean carb. Pull apart and soak in carb cleaner. Blow dry with air nozzle. Make sure air filter is clean and plenty of air. Make sure spark plug is not gapped wrong and running to hot. Make sure oil/fuel mixture is accurate
Nov 12, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Im trying to find out the mixture ratio of oil to gas for my craftsman 55cc 18 in bar chainsaw
Fuel oil mixture is deturmined by the brand of mixed fuel you use, not the machine. The machine will state what it's recommended oil brand states. Example a stihl chain saw will be 50:1 with stihl oil but if using echo oil it would be 35:1.
Mar 29, 2009 | Saws
Saw will not start Husqvarna 350
An engine needs three things to run(fuel and air mixed together in the correct proportions,compresion of the fuel/air mixture and ignition).Make carb adjustments,check the compression and the spark from the sparkplug.Priming the engine(put some gas into the sparkplug hole).Try to start the engine.If engine is running only the gas from the cilinder,the chain saw has a fuel delivery problem.Disassembly the carb and clean the inner parts.Check the fuel and air filters,fuel hose and gas tank ventil.
good luck!savumihai71
Dec 04, 2008 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Chain saw starts with starting fluid only but will not run.
Hi lwhssh:
Suggest you drain the fresh gas/oil and add a fresh batch but first add a gas stabilizer to your batch of gas/oil in the storage container. You will probably still need to use starting fluid for a few times When 2 cycle engines sit for a long period of time, the gas/oil mixture undergoes a change and tends to leave a residue on the delicate parts of the carb. The gas stabilizer will help that.
I always do the following for 2 cycle engines when I put them up for the winter. Empty the gas container on the device and then start it to use up any gas left in the fuel lines and carb. this keeps any residue from forming.
Hope this helps Good luck Loringh PS please leave a rating if appropriate. Thanks
Nov 28, 2008 | Garden
Homelite ZR10926 16 Chain Saw Logo
1,590 people viewed this question
Top Homelite Garden Experts
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
