Question about Cuisinart CWC-1200 Wine Cooler
Cuisinart Wine Cooler
My wine cooler is stuck at 77 degrees and won't cool!
  • 5 more comments
  • acraw Oct 03, 2008
    Wine cooler not cooling either. I even unplugged it for weeks and tried again; no luck. I can't find service repair without sending unit back to Cuisinart.
  • por911 Nov 15, 2008
    Same problem here. Ran fine for 9 months.
  • slocksykes Dec 29, 2008
    I've moved my cooler in different locations of the house to see if it was the temperature of the house, but no luck. It will not cool. What do I do? Please email me @ slocksykes@aol.com
  • Anonymous Jan 09, 2009
    I have the same problem. I have used my wine cooler for over a year now and it stopped getting cold.
  • condoking Feb 14, 2009
    My unit is about 3 months past the 3 year warranty and is not cooling. Fan runs but wine does not get cool. Temp on door says 74 degrees, I called consumer service and they said since it is past the warranty period I had two choices.
    1. Buy a new unit. They would give me a discount on one.
    2. Find someone local that might be able to repair it. They have no clue who that might be.
    Anyone come up with an answer?
    Lesson- Don't buy anything that can't be repaired if it brakes.
  • Anonymous Feb 19, 2009
    77 degrees...called the number and they need a serial number and model number and will replace under warantee if validated
  • Anonymous May 16, 2009
    Same problem as you all -- I was NOT happy to see that my wine "cooler" ended up at 77 degrees?!!
If you call (Cuisinart’s service center (800) 726-0190), they will send you a brand new unit for $10.00.
Happy Holidays,
AC Freeborn
Posted on Dec 02, 2008
It still works. (dec. 06 2009) The catch is that you have to pay shipping cost, 10 Dollar for the new unit and shipping and handling for the old unit back to them. Good news is that for Californians like me there are no shipping and handling cost for returns (since prohibited by law) sp I right now dont pay anything to get my new unit and the old one to them :) Happy Sunday and merry Christmas
Posted on Dec 06, 2009
    New Friend:
My Cuisinart wbc-1200 keep flashing 46 and doesn't cool what would be the problem?
Posted on Feb 18, 2013
Cuisinart wine cooler not cooling
Hola, buenos dias. Tengo 2 cuisinart cwc600 y no enfrian. Me dijeron que era la tarjeta electonica. Donde puedo comprarlas? Gracias
Oct 06, 2014 | Cuisinart Private Reserve CWC-600 Wine...
Wine cooler doesn't cool
I recommend that you maybe add more details to your question so it will be easier for Experts to understand the question and answer it.
Oct 06, 2012 | Kalorik WCL-20629 18 Bottle Dual Zone Wine...
Thermostat on wine cooler
Well, I'm not sure what your actually trying to do, but the whole purpose of a wine cooler is to cool, not to freeze and the temperature should really get no colder than 34 degrees F.
Jun 19, 2012 | Refrigerators
What is the best temperature for white wine to be in?
It is important to keep the wine cool and in stable temperature that doesn't fluctuate very often. Bright tart white wine: 48-52 degrees; sparkling wine: 50-55 degrees and rich white wines: 58-62 degrees.
May 29, 2012 | Furniture
My cuisinart wbc-1200 turns on and works but does not cool. how can i fix it?
I have the same problem. Fans worked fine. I took it apart and found bad thermoelectric cooling disk. Bought replacement on Ebay for $6.
Feb 01, 2011 | Cuisinart CWC-1200 Wine Cooler
I have my Emerson FR966T wine coller set for 60 degrees, but my cooler never seems to get the high. It always hovers around 58-59. When I heat my house up (never above 68) my cooler seems to warm up to...
Yes, because the fridge is a heat exchanger. The trade off for cooling the inside is a condenser coil on the outside which is warm. If you raise the temperature on the outside it will affect the inside a little. Having said that, the thermostat should keep the temperature within specifications. If you have it set for 60 and it is 58 or 59, to me it is within spec.The difference in 2 or 3 degrees Fahrenheit is tiny.
Also it should be pointed out this is a $63 cooler from Walmart. If you want a good one for storing thousand dollar bottles of Chateau Margeaux, you need a $600 wine cooler with a solid state digital thermostat and controls that talks to your smartphone when the temperature is one degree off..
Oct 21, 2017 | Refrigerators
What is the temperature setting for normal wine cooling?
It's between 55 and 65 degrees fahrenheit. If you're storing a lighter red wine, you'd want to keep it on the lower end (55 degrees). And for the darker (deep) red, you'd want to keep it on the higher end (65 degrees). All white wines should be on the lower end, and below. You can drop down to 50 degrees if you'd like. I hope this helps. Good Luck!
Mar 29, 2010 | Emerson (025806803716) Wine Cooler
Stuck at 77 degrees!
Hi
Do not assume the problem is related to the compressor or the sealed, hermetic system; these types of problems happen only rarely. Your unit may have dirty condenser coils, a door that doesn't seal tightly, or a defective temperature control.
1) Check the cold control. Be sure it is set to "cold." Normally, the temperature inside the unit should be about 37 degrees Fahrenheit.
2) Listen for the freezer fan inside the freezer. When the freezer fan is running, it means the defrost timer and the cold control in the unit are both set to cool.
3) Listen for the compressor fan, where the compressor is located (typically behind or beneath the refrigerator. When the freezer fan is operating, the compressor fan should also be working (most of the time).
4) If one of the fans is not working or the compressor is off, the unit will offer very little cooling or none at all.
hope you will be helpfull..
Thanks for contacting fixya.com
Sep 10, 2009 | Cuisinart CWC-1200 Wine Cooler
Cuisinart CWC-1200 Wine Cooler Logo
3,395 people viewed this question
Top Cuisinart Furniture Experts
Maxumized
Rabbit Brains
Rabbit Brains
Are you a Cuisinart Furniture Expert? Answer questions, earn points and help others
