There is a cd stuck in the slot loading drive. Using a straightened paper clip will start the mechanism however it will not spit out the disc.
    Novelist:
  • 169 Answers
You didn't go far enough in with the paperclip. Some drives, the eject mechanism is an inch deep or more. Just keep pushing it in and the CD will come out.
You won't damage it no matter how far you push it in ...the "barrel" for the emergency eject does not connect to anything electrical - it just has a switch somewhere down in the tube that you have to reach, which triggers the drive door to open.
Hope this helps - please rate :)
Posted on Oct 01, 2008
How do I remove the back of my Gateway ZX6971-UR30P. I have a cd stuck in the disc drive and the door won't open.
Have you tried to use a straightened out paper clip to eject the disc. You should see a small hole next to the eject button on the disc drive, just push the paper clip in that and the drive door should open.
Sep 11, 2013 | Gateway ZX6971-UR30P 23-Inch All-in-One...
Apple mac g5 power desktop dvd
If it is a tray-load drive, there is a small hole in the front. Pushing a straightened paper clip into this hole should unlatch the tray so you can pull it out.
Many slot load drives have the release tool entry way over on the left end of the slot. Push the straightened paper clip in there (it must go in perpendicular to the front of the drive, not angled in any other direction).
If you hit the target, you should feel something like a spring-loaded cam mechanism moving - it will take a moderately firm amount of pressure to start it, then it will unlatch and push more easily. Be careful - if the paper clip starts to bend on you, or it feels like you are bending something inside, you probably don't have the target. You should not need to apply anywhere close to the force to bend a larger-size paper clip with an end-on push.
If the computer is functioning normally, you should be able to remove the disk by starting the computer, then repeatedly pressing the eject key just before it starts the boot up cycle. To avoid having the disk pop out then pull in again while doing this (tray load), press once, pause for 3/4 second, then thereafter press twice rapidly and pause for 3/4 second. This will give you a good shot at hitting the time window between starting the optical drive and beginning boot-up and time to stop hitting eject when the disk starts coming out.
If all else fails, take the cover off of the drive (not installed or plugged in to anything) and study the mechanism. Tray loaders have a rack on one side of the tray driven by a pinion gear, either mounted directly on the tray motor or driven through a belt or gear train. You can manually turn the motor or an intermediate gear to unload the disk and run the tray out. Slot loading drives have a cage of curved bars with rollers at the edge of the disk - look for the mechanism that drives this cage and manually turn it as described for the tray load mechanism.
Do not try to pull the tray or cage directly - you'll damage the disk locking mechanism and may jam things up so the only way to get the disk out is to tear the whole thing apart. Always turn the disk load/unload motor, one of its reduction gears or belt-drive pulley (if present.
Jul 18, 2013 | Computers & Internet
Cd stuck in E: drive on my HP TouchSmart 300 PC
You will have to manually eject the disc. take a straightened paper clip and find a little hole near the slot where the disc goes in. Insert the paper clip and it should eject the disc. If there is no hole, you may need to access the disc drive by removing the back panel and/or disc drive faceplate.
Apr 12, 2013 | HP Touchsmart 300-1003 Amd Athlon Ii X2...
Stuck disk in Dell computer
If a CD/DVD disc that's stuck, get a paper clip and straighten it out. On the CD/DVD drive there should be a pinhole on the tray. Insert the clip to open.
Dec 28, 2011 | Dell Inspiron All-In-One Computer
Hello, my otiplex Gx620 cd/dvd drive will not eject the cd it in. Is there any way of releasing it ? many thanks hannah x
Hi and welcome to fixya!
Just follow these few steps and it should fix the problem (but if the problem keeps on happening, it maybe time to change the ODD).
    • 1 Locate the optical drive that contains your stuck disk. You'll see a small hole on or immediately below the disk tray.
    • 2 Straighten the paper clip.
    • 3 Insert the straight end of the paper clip in the hole and push. You should feel it catch inside the latch mechanism.
    • 4 Pull the paper clip out gently. The disk tray will come with it.
    • 5 Remove the CD or DVD and close the tray.
Read more: How to Eject a Stuck DVD/CD Drive ' eHow.com http://www.ehow.com/how_2324439_eject-stuck-dvdcd-drive.html#ixzz1RJn98iTa
Jul 06, 2011 | Dell for Optiplex GX620 CD-RW/DVD-ROM...
My DVD/CD Slot thingy is not opening, how do i fix it?
If you mean CD/DVD/ ROM drive then you will need a paper clip. Straighten out the paper clip and push it into the hole on the front of the drive (a little pressure is involved). This will eject the tray. This is usually occurs because the gearing is getting stuck. This usually doesn't get better, only worse over time.
Jan 31, 2011 | E-Machines emachines (emachinees) CD-ROM...
I don't know how to open the CD compartment on this laptop.
Open My Computer, right click on the icon for the cd unit and click Eject.
Dec 04, 2010 | Dell Latitude D600 Notebook
Cd is stuck in my dell studio 1555 laptop?can you help? ram
Look closely at the bezel of the disk drive, you should see a small hole.
Straighten out a paper clip and push it, quite firmly into the hole. This is the failsafe release.
Jul 08, 2010 | Dell Studio 15 Laptop
A dvd is stuck in the drive. It resists all attempts at removal including the ''eject cd'' command in Open Firmware. Can I manually remove it?
The iMac (Slot loading) computer's disc eject mechanism is electrical instead of mechanical. To eject a CD-ROM disc at startup that contains system software, press the mouse button until the computer ejects the disc. If the disc does not contain system software, wait for the iMac to start up and drag the disc icon to the Trash.
If either of these steps fails to eject the disc, push the drive's manual eject button with a small, blunt object like a paper clip. This button is located to the right of the CD/DVD slot as shown in Figure 1. The computer must be turned on to eject a disc in this manner.
ht3007_1.gifFigure 1 Manual eject button
Once the disc is ejected, it extends just beyond its center hole so you can remove it from the drive. If the disc fails to eject, while holding in the paper clip, use another CD to gently push against the inserted CD. This gentle pressure may help to release the inserted CD.
Important: After ejecting the disc with the manual eject button, you must restart the iMac in order for the CD-ROM or DVD-ROM drive to work.
DONT FORGET TO VOTE
Oct 10, 2009 | Apple iMac G4 Desktop
Cd Stuck
Look at the "door" or "flap" of the cd rom drive. You should see a small round hole. If you straighten out a paper clip and insert it in the hole, push in gently, that will open the door and eject the disk. Please rate this if it helped you.
Jan 17, 2009 | HP Media Center m7060n PC Desktop
Computers & Internet Logo
85 people viewed this question
David Payne
David Payne
