Connect one end of the game console's audio/visual cable into
the corresponding slot on the console if you have an older game
console. If you have a newer console, insert one end of an HDMI cable
into your console's "HDMI OUT" port.
Plug the red and white ends of the audio/visual cable into
the corresponding red and white audio inputs located on the back of your
Vizio plasma TV if you have an older game console. Plug the yellow
cable into the yellow "Video In" input. Depending on which model of
Vizio TV you have, the yellow input may be located either right next to
the audio inputs or it could be located a few ports away.
Plug an HDMI cable into one of your TV's "HDMI IN" ports, if you have a newer console.
Turn on your video game console and your Vizio plasma TV.
Press the "TV/VIDEO" button on your remote to cycle through the various
inputs. You should eventually get to an input that's displaying your
video game console's home screen.
Press and hold the on button. It will turn on, continue holding it, until you hear a single beep, then let go. This will reset the video settings, and should allow it to work through the AV cable
This will only work with a dvd player, PS3, XBOX 360, and other gaming consoles
You need: - 3 AV Splitters (2 Female 1 Male sides cord) - 1 Double sided Video and Audio Cables (Red, white, yellow cables)
Connect your consoles Video and Audio cables to the female sides of the splitters, next attach the Video and audio cables you bought to the splitters as well. Now plug in the video/audio cables you bought into your TV. If you did this everything properly this should work.
There might be a problem with the AV cables (Audio Visual) or theres more then 1 port for the AV cables to go. If there's more then one AV station on the TV try switching to the other ones.
Before plugging up any cables to your TV, look to make sure that you know the input number on the back of the tv if you have multiple inputs on your TV.
Make sure the video cable plugs into the video input on your tv, then the two audio cables, make sure they plug into the audio inputs on your tv and then make sure your tv is set to the right input and everything should be good, turn on the game system and enjoy.
This issue may occur for one of the following reasons:
The audio-visual (AV) cable is not connected correctly or is not plugged in to your Xbox 360 console.
The console is not detecting the cable.This issue does not occur if the AV cable is plugged incorrectly into a television, a stereo, or a VCR.
Note This issue occurs only on Xbox 360 consoles that do not have a High Definition Multimedia Interface (HDMI) AV port.
CAUSE
This issue may occur for one of the following reasons: The audio-visual (AV) cab...
loadTOCNode(1, 'cause');
This issue does not occur if the AV cable is plugged incorrectly in to a television, stereo, or VCR.
You are supplied with a Composite
AV cable which would typically look like the below image
Connect the AV Multi Out Connector
to the socket on the back of your PS3 Console.
Match the colors of the Jacks with
the connectors on the TV which says "Video in".
Connecting with an HDMI
Cable:
HDMI cable is not supplied with the PS3. You need to purchase it
seperately. This cable would enhance the audio-video quality of your
TV.
Just connect one end of the
connector to the HDMI OUT connector socket on the back of the console
Connect the other end to the
socket on the back of your TV which says HDMI IN.
Connecting with an
Optical cable:
You need to purchase an Optical cable if you wish to connect your PS3
console through a digital audio device (Home theater, AV receiver
etc.,). You need to connect Video ouput seperately with a help of Video
output cable (HDMI, AV Cable etc.,)
Connect one end of the optical
cable to "Audio Out" socket on the console
Connect the other end to the audio
receiver.
Note: You can also connect your console to the
Internet to use the Playstation 3 internet capabilities. Here's how
you do it:
The Playstation 3 only supports 10BASE-T, 100BASE-TX and 1000BASE-T type
networks. It needs a High speed internet connection. Do not connect it
to a standard telephone connection or cables that are not supported.
It might cause a malfunction or damage to the system.
