Question about Frigidaire Gallery Series GLHS269ZDB 36" 26.0 Cu. Ft. Side-by-Side Refrigerator w/ 7 Button Dispense...
Frigidaire Gallery Series Oven Locked
I leaned over the oven across the bar and somehow locked the oven door. I hit cancel and nothing happened. There's a little picture of a lock opening w/ the # 3 in it but I have no idea what this means. It's a new oven and is digital. Any ideas? Really need to unclock it.....
  • 2 more comments
  • Renee Bueckert Oct 14, 2008
    My oven is LOCKED too. Accidentally pressed something and now even pressing 'cancel' does nothing. I unplugged the stove, waited a minute, and plugged back in... still locked. Any suggestions?
  • Anonymous Nov 02, 2008
    How do you get it out of cleaning mode?
  • Anonymous Dec 26, 2008
    Help I have the same problem...
  • Anonymous Jan 08, 2009
    how do i turn off the cleaning
Ok i just hold clear off button for ten seconds itll beep then the lock icon snf words will blink then hit start button then itll all shut off then go cook something lol ... gl hope it helps
Posted on Oct 30, 2009
  • D. G. Sep 06, 2013
    This happened to us. We called Frigidaire and they said we needed a service tec. He came out held in the oven light button for ten seconds and fixed the problem. Shame on Frigidaire for not telling us to try this. A $68 dollar lesson. I hope this will save some one else the service call.
It's probably in cleaning mode.
Posted on Oct 19, 2008
Fridigaire range FEF389wjcc
cleaning lock light will not go out
Posted on Jan 31, 2009
Accidentally hit clean button on a Frigidaire Gallery Oven. Hit Cancel button. Oven door won't open.
I appreciate your post, C Maury!
From my understanding your hit the clean button on your Frigidaire wall oven and now the door will not open. I would hold down the cancel button for at least ten seconds, this should unlock the door. If that does not help I would recommend disconnecting power from your wall oven by flipping the household circuit breaker for ten minutes. I hope this information was helpful to some degree. -Matt
Nov 20, 2014 | Frigidaire 30 in. Electric Gallery Series...
I have a frigidaire gallery wall oven (2003). We set the self cleaning and then canceled. The door is now locked and the fan is running. I tried to reset breaker and it is still locked. How can I get the...
If tripping and turning the circuit breaker off for about 10 minutes does not work, contact Frigidaire. Sounds like the control board and/or door switch will need replacing.
Aug 07, 2012 | Frigidaire 30 in. Electric Gallery Series...
F8 error and bottom door locked
Here is Frigidaire's suggestion to your problem:
Oven Control Beeps
and Displays an "F"
Error Code
Electronic control has detected a fault condition. Push CANCEL pad to clear the display
and stop the display from beeping. Reprogram the oven. If a fault reoccurs, record the fault
number, push the CANCEL pad and contact an authorized servicer.
Jul 26, 2011 | Frigidaire 30 in. Electric Gallery Series...
How do I self clean my gallery series fridgidaire?
Some of the self cleaning ranges require that the door be locked before the self-cleaning cycle will work. If your oven door has a manual locking lever then make sure it is completely latchedthen press the self-clean button. Also make sure the dooris completely closed because if there is not a manual latch then it will be a auto latching system. If not then there could be a problem with the button on the control panel for the self cleaning option.
Jan 14, 2010 | Kitchen Ranges
I have a Frigidaire Gallery Oven Professional Series, I don't have the model number. In trying to self clean my oven, I accidentally pressed something that engaged the oven door lock. Now I can't close...
If your oven door has gotten bent or warped (maybe you rested something heavy on it…), you need to remove the door, disassemble it, and straighten it. You can lift most oven doors off of their hinges by opening the door several inches to its first "stop," and lifting the entire door straight up.
If the hinges have become worn, damaged, or bent, you probably need to replace them. I recommend replacing both hinges at the same time, to prevent uneven wear of the undamaged hinge.
Sep 04, 2009 | Ovens
Not familiar with this particular stove, but it sounds like you activated a child protection lock. To turn these on and off, you have to hit that lock icon and hold it for 4-8 seconds for anything to happen. This is so that the kids won't have sense enough to unlock it, assuming that you locked it to keep them out!
Also, frequently they work  in stages. Hitting it one time (for 4-8 seconds) will lock the panel, hitting it another time will unlock it, hitting it a third time might lock the door, and so on. So RTFM, or just keeping hitting it multiple times for 4-8 seconds each, and see what does what. But the manual should tell you everything you need to know. You can go to the GE website, or to managemyhome.com, which is maintained by Sears, and you should be able to find a PDF copy of the manual if you don't have the manual that came with it.
Feb 03, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Cannot unlock oven frigidaire electrolux gallery series
Hello, what to do is to start another self clean cycle let the unit clean for about 3 minutes then push the cancel button.This should unlock the door if not a tech will have to come to advance the lock motor . good luck
Dec 20, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Oven door "locked" in open position
Just hold in the oven light switch around the oven door area, then press the cancel button and wait a few seconds.   It will reset.
www.applianceoutletservice.com to chat with me live Bill
Oct 19, 2008 | Frigidaire FEF336BC Electric Kitchen Range
Oven door will not unlock
try pushing in on the oven door and push cancel. you should hear the unlock motor unlock the oven door
Apr 10, 2008 | Frigidaire Gallery Series GLHS269ZDB 36"...
Frigidaire Gallery Series GLHS269ZDB 36" 26.0 Cu. Ft. Side-by-Side Refrigerator w/ 7 Button Dispense... Logo
1,050 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Steve
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
