Question about HP OfficeJet 6110 All-In-One InkJet Printer
Lost ink cartridges
When i removed cartridges to have them refilled i needed to use machine once more, i replaced both cartridges in machine and when it was aligning my cartridges disappeared. i have looked and felt where the ribbon aligns cartridges at but cannot find cartridges, it's as if machine ate them HELP PLEASE !!!!!! thank you
  • 234 Answers
Try these links bellow to locate the ink cartridges:
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&docname=c00004340&dlc=en&product=79477
If not unplug the power cord from the All-In-One when there is still pawer in the All-In-One,
Open the cartridge access door.
Now if you see a Metal bar that is where the carriage moves (Carriage is the one which holds the cartridges) Check in the extreem left or right and allpy little pressure and slide the carriage an check to see if you still have the ink cartridges
Good Luck
Posted on Oct 03, 2008
Print cartridges would not move to center when opening lid so that ink could be replaced
There could be a paper jam in the printer head clearning system. If the head cleaning system is not completing the cleaning motion cycle the carriage will not move the catridge to the centre.
Dec 15, 2014 | HP Photosmart Premium C309A All-In-One...
Tip
Why your inkjet printers last only one year
Inkjet ink is glycerine and alcohol
Inkjet printers need to be used. You cannot leave an inkjet on a shelf and print only once a year. Use the thing occasionally. Use the same page, both sides, just to run it once in a while. Once a month will usually do.
Inkjet machines that have replaceable individual ink
DO NOT LET THE INK RUN OUT. Have a standby ink for all colours or go and get ink as soon as it runs out. Today will be good. Next week may be too late. Do not remove the ink cartridge until you have a spare to install NOW.
Inkjet with all colours in one cartidge, black with a metal bottom, black and colour with a metal bottom on each.
It does not matter if these run out of ink. The whole cartridge must be replaced. If you refill your ink at a store, place the cartridge in a ziplock bag and seal it. Take the cartridge in the same day for best results.
If you refill your own cartridges, do it right away for best results. Press the refilled cartidge head on a clean paper half a dozen times to see if you get nice clear bands.
Replaceable print heads separate from the ink
You don't want to buy one. $$$. A clogged one can be sometimes restored by soaking in PURE alcohol (99%). Swish it around a bit up and down to help clean the head pores. Dry it off and try in the machine.
on Mar 20, 2010 | Office Equipment & Supplies
How to remove ink
http://support.dell.com/support/edocs/systems/PRN810/en/index.htm#online_documentation
Jan 20, 2011 | Dell 810 All-In-One InkJet Printer
How to refill the cortrideg hp deskjet f4288.
Hi
the most important is to remove all
the air from the cartridge that has
left inside durring refilling that is why
professionals are using special machines
that refill in 0 air πρεσυρε using vaccum pump
you can check here a video on how to refill
with out any special equipment
Hope I had help you
Dec 08, 2010 | HP DeskJet F380 All-In-One Printer
Replaced ink cartridge still shows ink low needs to be replaced but is printing? Can it be reset?
  1. Remove your current empty cartridge from your Dell printer. Turn on your printer and lift the cover and top half of the unit. You can suspend it in place by lifting the blue plastic lever and securing it to hold up the top of the printer. At this point the ink cartridges should move to the center of the printer and be easy to access. Follow the instructions locate on your printer to remove the cartridges. You can do this by pressing on the blue tab to remove the colored cartridge or the black tab to remove the black cartridge. Once you press the tab, the cartridge cover will pop open. Carefully pull out the exposed cartridge from it’s setting. Save the empty cartridge so it can be refilled.
    Remove the sticker from the newly refilled Dell ink cartridge. Follow the directions on the opened printer to insert the cartridge. Hold the cartridge so the writing is on the top and the ink spot is on the bottom. Gently push it into the opened setting until it is securely in place. Close the cover of the cartridge holder by pressing down on it gently until it clicks into place. Remember that the black cartridge goes into the black setting and the color cartridge goes into the blue setting. Close the top of the printer. You will hear the ink cartridges move back into place.
  2. Test your newly refilled Dell ink cartridge and load your printer with paper.Print a document so either in color or black and white (depending on the type of cartridge you had refilled). Review your printed document to make sure the color is consistent and you are pleased with the outcome.
    Repeat whenever you run out of ink.
Apr 30, 2010 | Dell V305w All-In-One R840635AU InkJet...
Getting error U043 "The following ink tank cannot be recognized. I have the correct tank. Pixma 520 ...tank # 5 PGBK
The little chips on the front of the cartridge create a trouble for people trying to refill the cartridge, as of right now, there is no way to easily reset the chips. If you refill them, they still register as empty, and therefore don't work.
If the following tips doesn’t help, you can try to install the original new ink cartridge following the instructions in the user manual. This can solve the problem.
Note :
Be sure to install the ink tanks in the correct order indicated by the label on the Print Head Holder. The machine will not print if an ink tank is installed in the incorrect position.
For information on the compatible ink tanks, refer to the back cover of the Quick Start Guide.
Tips before Replacing Ink Tanks : Important:
- To maintain optimal printing quality, we recommend the use of specified Canon brand ink tanks.
Refilling ink is not recommended.
- Once you remove an ink tank, replace it immediately. Do not leave the machine with ink tanks removed.
- Replace empty tanks with new ones. Inserting partially used ink tanks may cause the nozzles to clog. Furthermore, with such tanks, the machine will not be able to inform you when to replace the tanks properly.
- Once an ink tank has been installed, do not remove it from the machine and leave it out in the open. This will cause the ink tank to dry out, and the machine may not operate properly when it is reinstalled. To maintain optimal printing quality, use an ink tank within six months of first use.
- Color ink may be consumed even when printing a black-and-white document or when black-and-white printing is specified.
Color ink is also consumed in Print Head Cleaning and Print Head Deep Cleaning, which may be necessary to maintain the machine's performance. When an ink tank is out of ink, replace it immediately with a new one.
After replacing ink tank;
Turn off the machine, and unplug the power cord of the machine from the power supply. After five minutes or more, plug the power cord of the machine back in, and then turn on the machine.
If you would like to vote for the answer, this will help the others to see the similar problems solved and also will be a satisfaction factor for me to continue helping you.
All the best.
Mar 25, 2010 | Canon PIXMA MP520 InkJet Printer
I have the error message that it can not recognize the ink cartridge and it is blocking me from using the macine in any function. I have removed the ink cartrdige and it still says it cannot recognize...
An ink tank which has once been empty is
installed. Replace the applicable ink tank with
a new one.
Printing with a once-empty or refilled ink
tank can damage the print head.
If printing is continued without replacing the
refilled ink tank, press the Stop/Reset button
for 5 sec. or longer to record the use of a
refilled ink tank.
Oct 08, 2009 | Canon MP610 Photo All-In-One Printer
Dial says to remove cartridges and check. Have replaced cartridge
After cleaning cartridges and replacing refilled black ink, I removed blck ink and replaced with HP 58 photo ink. this aborted the "check cartridges freeze". I still cannot align cartridges after removing #58 and replacing with new HP 57. the operation starts but will not complete.
Any suggestions on how to align cartridges?
dunbarj730
May 02, 2009 | HP PSC 2210 All-In-One InkJet Printer
HELLO! I HAVE A SHARP FAX MACHINE (UXA1000- INK CARTRIDGE UX-C70B)AND I WANT TO KNOW IF I CAN GET THIS CARTRIDGE REFILLED AT WALGREN'S STORES LIKE MOST CARTRIDGES.
You should be able to, but the problem is this:
they only refill it, if there is a problem with the cartridge it doesn't help.
there is more to just putting ink in a cartridge.
1- you must clean the inside removing dried ink
2-you must clean the nozzles tomake sure the ink can flow
3-replace any pads inside
4-refill ink
I have heard complaints about Walgreens so take your chances, a better solution may be a company called Rapid refill ink ( they do all the above to their ink crtgs)
Jul 30, 2008 | Sharp Office Equipment & Supplies
Color
I am assuming from your brief problem description that you are getting bad colors when you changed your color cartridge. Are you using a new and certified HP ink cartridge? Are you doing a refill of your old ink cartridge or have bought one of those "re-manufactured" cartridges? The head in the cartridge is very sensitive - when they are damaged or poorly handled - it could result in cross contamination of the color inks. Hence - the brownish color you see could be the result of that cross-contam. My impression is that the remanufactured or older or continously refilled cartridges may be more prone to getting damaged - maybe bec of inherent wear out. Hope this helps.
Nov 30, 2006 | HP DeskJet 3325 InkJet Printer
HP OfficeJet 6110 All-In-One InkJet Printer Logo
19 people viewed this question
Seeker5211
Seeker5211
