Question about Sony Computers & Internet
The touch pad and 'click' buttons on my Sony VGN-A115Z laptop have stopped working since I had to use the recovery procedure due to loading what I think was some corrupt software. Is there a 'switch'or similar that needs to be activated to restore activation?
  • 33 Answers
Hello.
Your touch pad driver has probably not installed corectly.
I suggest you download the driver pack provided by sony here:
http://support.vaio.sony.co.uk/downloads/preinstalled/preinstalled.asp?site=voe_en_GB_cons&m=1674
extract the archive after download and run Apoint.exe from the PointingStickDriver directory
Hope this helps!
Posted on Oct 01, 2008
Problem with touchpad sony vaio vgn-ns295d my touchpad is only works when i touch it with two fingers, otherwise its not, and when i touch it with two fingers then i remove one and it works.. seems...
Thanks for asking Fixya !!!
Goto Start>>Run
Type
devmgmt.msc
press ok
in device manager doubel click Mice and pointing device and right click and uninstall the touch pad driver and uninstall
then restart the computer ..
Thanks
Feb 18, 2011 | Sony VAIO VGN-FZ240E/B Laptop
I have a VGN-CS118E and it's media touch buttons don't work, only the AV button works
The touch sensor buttons that control the AV Mode, volume, play, fast forward, etc. may stop working if the Synaptics Pointing Driver is uninstalled or if the file is corrupted. Follow this procedure to reinstall the Synaptics Pointing Driver.
Downloading and installing the Synaptics driver update available through the below link on this page will also resolve this issue.
http://esupport.sony.com/US/perl/swu-download.pl?mdl=VGNCS118E&upd_id=3783&os_id=28
After installing, reset the BIOS to its default values.
Click the Start button, and then click on Computer .
In the Computer window, under Hard Disk Drives , double-click on (C:) .
Double-click the Windows folder.
Double-click the DRIVERS folder.
Double-click the .EXE folder.
Double-click the Pointing Driver (Synaptics) folder
Double-click on the setup or setup.exe icon.
Follow the Synaptics Pointing Driver Installation wizard instructions to install the driver.
When the installation setup is complete, a You must restart your computer to apply these changes window will appear. Choose the Restart Now button for proper installation .
Thanks!!!!
Dec 27, 2010 | Sony VAIO VGN-CS118E/P NoteBook
I have bought a sony vgn-n38e anf i am not able to scroll up or down on the right hand side of the touch pad, i would like to know if there is simply a button to press to rectify this or if it is possibly...
So you need to update driver for this touchpad scrolling error.
Please click on the below link
ftp://download.sony.com/US/pc/ALDOTH-00199336-US.EXE
This will download the driver for your touch pad then you need to run the driver that you downloaded.
Then restart the notebook
Check whether it is working.
you can find other drivers for Sony Vaio VGN-A790 on the below link.
http://www.notebook-driver.com/sony-vaio/sony-vaio-vgn-a790-notebook-windows-xp-drivers/
Hope this resolve your query.
Kindly provide your valuable feedback for this answer
Thanks.
Nov 11, 2010 | Sony VAIO VGN-A790 Notebook
The left button of Mousepad(one on laptop, but not touch pad) is often not working and sometimes need to press hard. Model VGN-NR38M, Sony Vaio. please help
I had the same problem . The micro switch needs to be replaced . All push button micro switches have a certain amount of "clicks" before they loose ability to make a good contact . Your left click switch has exceeded its life and can no longer make a clean contact without more pressure . Eventually the spring in the switch will fail thus stick permanantly.You will have to take it to an authorized Sony Service center or maybe an office machine service department might have the replacment . I fixed my own with an old mouse microswitch .
Jun 26, 2010 | Sony VAIO VGN-NR385E Laptop
Left mouse button of Sony VGN-NR38M (nt touch pad) is not working often, and some times need to press hard, please help
mcdevito75 here, Bring laptop to Staples, Best buy for testing, sounds like that key could be hanging up. maybe some sort of oil needed.
Jun 25, 2010 | Sony VAIO VGN-NR385E Laptop
Touch Pad and mouse buttons
try it with toggle keys it may be work
May 03, 2017 | Sony VAIO VGN-N130G/W Notebook
My laptop left mouse button has stopped working
Common hardware problem. The correct solution is a replacement tracker pad and mouse, however you may be able to get the problem fixed by cleaning under the pad. Either way it requires taking the laptop apart.
WildeFalcon
Feb 06, 2010 | Sony VAIO VGN-NR498E/S Notebook PC
SONY VGN-FZ240E TOUCH PAD NOT WORKING
go to control panel , system , hardware, device manager & uninstall it then reboot
it will re install it's self.
don001996
Jul 19, 2009 | Sony VAIO VGN-FZ240E/B Laptop
Problem with hibernating mode
the hibernate mode is cancelled due to some motion in computer aplication for example: when you press any button in key board than the sestem restart or else if the mouse is touched than the system comes out of hibernate mode. Your cause woud be of due to of mouse movement. so if you want to avoid it than you just need to cover the touch pad with a piece of cloth
Jun 15, 2009 | Sony Computers & Internet
Malfunction of the left button of the touch pad
I had the same problem . The micro switch needs to be replaced . All push button micro switches have a certain amount of "clicks" before they loose ability to make a good contact . Your left click switch has exceeded its life and can no longer make a clean contact without more pressure . Eventually the spring in the switch will fail thus stick permanantly.You will have to take it to an authorized Sony Service center or maybe an office machine service department might have the replacment . I fixed my own with an old mouse microswitch .Hey it's a Cheap laptop and uses cheap parts.
Jan 08, 2009 | Sony VAIO VGN-SZ330P/B Notebook
Computers & Internet Logo
96 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
