Question about Eureka Altima Upright Vacuum Model 2996AVS Vacuum
Eureka Altima I have a Eureka Altima vacuum and can't get the dust cup out.
  • sgstutts Jan 20, 2009
    I would say this vacuum cleaner sucks but this would mean it actually picks up stuff. I know can't get the dirt cup out.
The dust cup has a small gray tray that appears to be part of the cup, but is not. I made the same mistake also and almost broke the stupid thing trying to get it out. Simply push the lock to the left to unlock. Gently lift the dust cup and not the gray tray and the cup will slide out easily.
[IMG]http://i294.photobucket.com/albums/mm88/SteelNET13/vacuum2.jpg[/IMG]
[IMG]http://i294.photobucket.com/albums/mm88/SteelNET13/vacuum1.jpg[/IMG]
Posted on Mar 06, 2009
  • 4 more comments
  • mikul lewellyn Mar 06, 2009
    Sorry, the imbed didn't work so here's the direct link to the pics:
    Hope this helps!!
    http://i294.photobucket.com/albums/mm88/...
    Sorry, the imbed didnt work so here's the direct link to the pics:
    Hope this helps!!
    Hope this helps!!
    Hope this helps!!
    Hope this helps!!
    Stupid 5-posting. Sorry, wireless connection is a little rocky! =(
How do I remove the dust cup and clean it?
Hey, this is Tristan with Crucial Vacuum,
In order to remove the dust cup, there's a designated lever that you slide to the left in order to pull the dust cup out. This slider is above the HEPA filter (the four holes near the bottom of the vacuum). After cleaning, you slip the dust cup back and slide the slider to the right to lock it back into place.
Below I have attached a link to the users manual for the Eureka 2997-2999 series. You should refer to page 4 to view the diagrams pertaining to my suggestions.
http://www.manualslib.com/manual/49521/Eureka-2997-2999-Series.html?page=4#manual
You can purchase replacement parts for Eureka direct from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/eureka.html
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Tristan Clausell
Crucial Vacuum Customer Care
Sep 13, 2015 | Eureka Uno 2998AZ Bagless Upright Vacuum
MAINTAINING A EUREKA BAGLESS VACUUM
Helo Reader,
You can purchase replacement parts directly from Govacuum with an exclusive 11% discount coupon only for Fixya.com readers, use code: FIXYA11 at checkout to avail the offer. We also offer free shipping over $35.
Eureka Style U Belt - https://www.govacuum.com/products/eureka-u-extended-life-belt-set-of-2
Eureka HF7 Filter https://www.govacuum.com/products/genuine-eureka-premium-hf-7-hepa-filter-with-arm-hammer-61850c-1-filter
Hoover parts - https://www.govacuum.com/collections/hoover
Jeethu
Govacuum Team
https://www.govacuum.com9_17_2017_3_49_04_pm.jpg
Oct 04, 2014 | Eureka Altima Upright Vacuum Model 2996AVS...
Can not get the dirt cup off of my eureka altima 2993
I have a similar model but I believe the solution would be the same. My dirt cup wasn't coming out after turning the lever so I wedged a butter knife between the clear dirt cup and the grey plate under it and pried the two apart. With the knife pushed in between the two pieces came apart easily. Now the cup slides out with no problem. _395.jpg
Dec 30, 2010 | Eureka Altima Upright Vacuum Model 2996AVS...
I'm having trouble getting the cup to remove. Once we did get it to come out and we put it back in. When we turned it on dust blew out of the vacuum where it should have been sucking in.
The dark gray plastic slide is separate from the Easy Empty Cup. Just slide the release tab all the way to open position, and then pull the Easy Empty Cup straight up. With a little effort, the cup will dislodge from the dark gray plastic platter.
Nov 09, 2010 | Eureka Altima Upright Vacuum Model 2996AVS...
I can not get the dirt cup out to empty it.
Just slide the dark gray release tab, located just below the cup, all the way to open position, and then pull the Easy Empty Cup toward you.
Jul 10, 2010 | Eureka Altima Upright Vacuum Model 2996AVS...
How do you empty the easy empty cup
sometimes the platform the cup sits on needs to be pushed down away from the cup then it slids out easily
Mar 23, 2009 | Eureka Altima Upright Vacuum Model 2996AVS...
CHANGING THE FILTER
You have to install the filter in the dust cup lid first, then put it in the dust cup. There are some clips that filter will fit into on the lid. Also, take a look at the maual. http://www.eureka.com/service/manuals/75287_eng.pdf
Feb 26, 2009 | Eureka 431A Optima Bagless Upright Vacuum
Eureka Altima Spitting dirt back out
your intake is clogged at the bottom and your filters are dirty not letting it create suction.is the dirt cup full
Oct 24, 2008 | Eureka Altima Upright Vacuum Model 2996AVS...
Eureka altima bagless
I experienced the same problem of being unable to remove the dust cup. Inspection of the dust cup appeared to indicated two tabs on the bottom of the dust cup preventing it from sliding straight out as illustrated in the instructions. However, after much fiddling, I assumed that the dust cup with the tabs was probably a slightly different part than actually intended for that particular model (2996avr) and so decided to force the cup out, reasoning that if the tabs broke in the process, that was necessary for removal of the cup anyway, and therefore not detrimental.
HOWEVER, upon forcing the cup out, the cup broke away from a plate upon which it is designed to sit. The cup had apparently become stuck to the plate after much use without sufficient care and cleaning. The plate is what the tabs are attached to, and so by breaking the cup free of the plate, the tabs were not an issue, and the cup easily slid in and out of the housing, as intended. It was also observed, upon removal of the cup, that there is a very slight lip on the front of the plate to secure the cup in the proper position; this would likely act as an additional hinderance if the cup was also stuck to the plate by old cemented grime.
May 16, 2008 | Eureka Altima Upright Vacuum Model 2996AVS...
Lost Manual
You didn't mention brand or model #, but try going to the manufactures web site and see if they offer manual downloads.
Oct 31, 2007 | Euro-Pro Shark SC-505 Handheld Steam...
Eureka Altima Upright Vacuum Model 2996AVS Vacuum Logo
234 people viewed this question
Top Eureka Vacuums Experts
charlesjo336
Level 1 Expert
JoeVacs
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
