Zenith C27A24T 27" TV
Problem for Zenith C27A24T 27" TV
56" Zenith Projection TV....wierd problem
By Gary10 - usenet poster
I am encountering a strange problem when viewing my tv.After about an hour of watching,the screen becomes distorted.Screen is 3/4 the size of screen and wavy.I turn my tv off for like a half hour,than back on,and it is fine for another hour,than same thing happens.Also,seems like I'm losing blue color.Anything I can fine tune or does it sound like a board problem?Thanks for any info.
btw...I had a board replaced last year due to loss of blue color.Maybe same problem.
Solution #1
posted on Jun 09, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
I can't turn on the tv it alway say stanby
Solution #2
posted on May 30, 2006
Not Rated)
LiZzIe
Rank: Apprentice
Rating: 0%, 0 votes
replace the 110k ohm resistor. Located beneath larger 3watt resistor found where daughter board meets main board near horizontal yoke connectors on 9-1674 module. If you know what you are doing this should cost about 30 cents , if you dont, abiut $300.00.
Was this helpful?
Yes
No
Solution #3
Not Rated)
Mini Me
Rank: Apprentice
Rating: 0%, 0 votes
It sound like your power supply/defection board has a themal problem might be as simple as a cold solder connection or a componemnt breaking down after heat up I would sugest you call a service tech to fix it before your set completly fails and requires a major board replacement.
Regards
Was this helpful?
Yes
No
Popular Solutions for Zenith C27A24T 27" TV
Questions and Unsolved Problems for Zenith C27A24T 27" TV
Do you recommend Zenith C27A24T 27" TV?
Answer
Answer
My tv lost it's color, and I don't know how to fix it. Is it possible to fix? It's a Zenith 24in I... (More)
Answer
I have a older Zenith TV, Model # C25A24TF. The original remote will not work. I have digital cable... (More)
Answer
i can't get my tv to go up & down with the remote
Describe your Standard Televisions problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Standard... Experts
Top TV Repairmen
in , MD
(316) 283-8873
Zenith
(316) 838-0811
Authorized Warranty On Rca,Integrity In Sales...
Zenith
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
