Question about Sony Playstation 3 (PS3) Console
Ps3 hard drive not working - Sony Playstation 3 (PS3) Console
  • 2 more comments
  • josie625 Oct 01, 2008
    I need help with my ps3 hard drive not working
  • chattgangsta Oct 15, 2008
    when i turn my ps3 on a screen comes up saying my hard drive is corrupted ! Then it tells me to press x and it will be restored and it does the same thing over again.Do anybody know how to fix this.
  • Anonymous Jan 30, 2009
    My hard drive has the same problem, i had took out my hard drive and saw what looked to be scratches on the disk-like object. Does anyone have a solution?
  • Anonymous Mar 29, 2009
    yes hard drive not detected thats what it says at hte main screen
    Scholar:
  • 125 Answers
Do you get any sort of message on your display when you turn on your ps3 like hard drive not detected anything like that ?
Posted on Oct 02, 2008
Turning on unit, display of "cannot start the correct hard disk was not found" I tried reseting it by holding the pwr button for ten seconds, didn't work. What can I do?
The only thing I can think of is if you know anyone else who has a ps3, try using your hard drive in their ps3 to see if it works, if not you may have to buy a new hard drive. I don't have a ps3 so I am not sure if the hard drives are removable or not, but I do have an Xbox 360, and the hard drives are removable, and are very easy to remove.
Sep 18, 2011 | Sony Playstation 3 (PS3) Console
My ps3 i tried to restore its def a hard drive issue I just dont know to remove and installm hard drive and which hard drive the best suitable money not object can i get a walk through on what i need to do...
Ok, changing the hard drive on a PS3 is pretty easy. First, on the left of the PS3 there is a little cover that you can flip out with a small flat blade screwdriver. When this flap is removed you will see a small blue screw. Remove this screw. There will be a little clip that unfolds from the side of the hard drive casing. Hold on to this and pull the hard drive towards the front of the PS3 and then pull is sideways. You must keep the metal frame that the hard drive is secured into. There are 4 screws that hold the frame onto the hard drive. Remove these and the hard drive will come away from the cage.
As to what hard drive to use, really any SATA 2.5" drive will do, it all depends on what sort of data you want to keep on it. I have heard of people installing up to 500Gb hard drives, this is probably the maximum size you want to use. Some people supply hard drives already formatted to PS3 standard, but any drive will work. When you first plug the drive back into the PS3 it will say that it needs formatting, just agree to this and everything should work fine.
Hope this helps.
Aug 02, 2011 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console My PS3 hard disk is corrupted, It say to restore i put restore and nothing had been restored Bid
Corrupted hard disk? Lets see....
You could attempt to boot up the PS3 in safe mode and restore the file system (should delete any corrupted data). Describing how to start up your PS3 in safe mode would just be confusing, so instead here's a link to the official page on the PS3 Safe Mode feature.
Follow the instructions, and then I'd say try options 3 (Restore File System). If that doesn't work, try 4 or 5 (Rebuild Database or Restore PS3 System).
If that fails, you could just replace the hard drive. The PS3 uses standard 2.5inch SATA laptop/notebook hard drives (5400 or 7200 RPM). They can be found online at any computer parts website; for example, Tigerdirect.
If somehow the new hard drive doesn't fix it, or you don't feel like buying a new hard drive, you could send the PS3 back to Sony. If you're under warranty it's free; otherwise it's expensive (150$ I believe).
If you request the repair service, they send you a box, you put the PS3 in it and ship it back to them. A month or 2 later they send you a fixed/different PS3. Simple, but takes forever to get a working PS3 back which is why I suggest you try a new hard drive first.
Anyways, hope you get it working soon!
Mar 22, 2011 | Sony Playstation 3 (PS3) Console
Ps3 says hard file disk corrupted and has to be restored but it just keeps doing this and has restored like 15 times and has not fixed itself. what can i do
1. Restore File System
Enter Safe Mode and select "Restore File System". "Restore File System" will attempt to repair damaged files on the hard drive. If this does not work, try the next step.
2. Rebuild Database
Enter Safe Mode and select "Rebuild Data Base". "Rebuild Data Base" will erase messages, playlists, changes made on [Information] screens, trimming information for pictures in [Photo], video thumbnails, video playback history and video resume information. Then attempt to rebuild the PlayStation 3 database. The content that is erased will not be recoverable. If this doesn't work, try the next step.
3. Restore PS3 System
Please note this will erase all content on the hard drive and will not be recoverable.
Enter Safe Mode and select "Restore PS3 System". "Restore PS3 System" will restore the default settings and will format the hard drive. If this doesn't work, try the next step.
4. Re-seat the hard drive
If you have replaced the hard drive in the PlayStation 3, make sure it was installed properly. If the hard drive is not seated correctly, it may cause problems.
5. Try another hard drive (if possible)
There may be an issue with the hard drive that is installed. Try replacing the hard drive with another one.
Feb 10, 2011 | Sony Playstation 3 (PS3) Console
Ps3 console switches off within a couple of minutes of starting up. original 60gb phat model
it is the hard drive problem.Take a screw driver and remove the base of Ps3,also use a small screw driver.Just pull out the hard drive, Now for security reasons put a working hard drive and test it. if it works than put the original hard drive otherwise you will loose all your saved game data.I hope this technique will work.
Jun 12, 2010 | Sony Playstation 3 (PS3) Console
Took PS3 on plane as carry on, now I get a ?cannot find harddisk"
The X-Ray machine most likely wiped your hard drive. To check, take off the side door, take out the hard drive, put it back in and see if it recognizes it. If not, reformat the hard drive in your computer and return it to the PS3. If this still doesn't work, buy a new hard drive for the system. Any size 2.5" laptop hard drive will work.
Apr 29, 2010 | Sony Playstation 3 (PS3) Console
My files on my hard disk are corrupted whaat do i
You can try taking out the hard drive from the ps3 and hook it up to a computer that has SATA connections. Then copy the files to a flash drive. This way you can at least save the information from the hard drive.
At that point, put a new SATA hard drive into the PS3 and format the drive. Then at that point put the information that you saved to the flash drive onto the ps3 hard drive. Do this all in the computer after you format the new drive in the ps3 and then put it into the computer to copy the files from the flash drive into the new hard drive.
Dec 23, 2009 | Sony Playstation 3 (PS3) Console
Why wont my wd elements 1 tb hardrive work on my ps3??
1) It needs to be FAT32 PLUS it needs to be externally powered. I found out the hard way that the PS3's USB ports do NOT provide enough power for a standalone USB hard drive, so you need to add your own power supply.
Dec 09, 2009 | Western Digital My Book Essential 1TB...
Ps3 and 1tb hard disk
This one may only have one possible solution.
You probably have heard that the PS3 will support up to a terabyte hard drive. That is true for most of them.
However, depending on the version of PS3, you may have to see if it is possible to flash the BIOS of the PS3. I talked to a Sony representative about the hard drive and it will support a 1 terabyte hard drive.
Contact sony to see if it is possible to flash the PS3 BIOS so it will recognize the drive.
Jul 27, 2009 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
PS3 hard drive transfer
seagate eSATA 250gb hard drive, the PS3 uses a laptop sata drive, how you get this to work?
You have basically have 2 options you could try:
Use Linux for retrieve the data of get the original mainboard back.
The PS3 + HDD bonds together, so if you were to save stuff eg, online purchases, you need to have the same account for max of 5 downloads to 5 differenct units, BUT you cannot just swap out the HDD and expect it to work. The PS3 has a feature to backup from internal directly to an external USB hard drive but online limited to data, most purchased movies and/or MP3 will not be transferred, it sucks.
You can have as much HDD you want but only YOU can use them , cannot be shared with another PS3. I hope that helps a bit
Jun 16, 2009 | SimpleTech SimpleDrive Pininfarina 320GB...
Sony Playstation 3 (PS3) Console Logo
55 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
