Question about LG L246WH-BN TV
LG L246WH Just purchased this monitor,and the words " CHECK SIGNAL CABLE RGB " are shown on the screen and it will go no further. Thank You. Alan Ross.
    Sergeant:
    Champion:
  • 223 Answers
I know this is not the right way to do this but try installing the drivers for your new monitor while using your old monitor the re-boot the computer still with your old monitor attached. When you are satisfied the new drivers are in a location easy to find turn off and attach new monitor. If you are still getting that message try it with another computer. If this message still persists there is a fault with the RGB cable input board so if you can return it or have a competant technician have a look. Hope this helps.
Posted on Oct 01, 2008
How can i exit analog power saving mode from lg flatron desktop
If possible, attach analog and DVI cable together from one single graphics card.
Just to test your monitor is due to old age or component failure.
Jun 04, 2014 | LG Flatron L1750S 17" LCD Monitor
L246WH blinking light problem
Probably the power supply is failing but periodically recovers briefly.
Jan 05, 2014 | LG L246WH-BN Monitor
Lg l246wh
The problem is the power supply.
Open it and verify the fuse and after that check the capacitors.
Dec 11, 2013 | LG L246WH-BN Monitor
Ibm thinkpad wont connect to LG TV
Lower the screen resolution to 720 dpi.
Another issue is the reference to RGB. Is it the 3 cable (YPBPR) or the standard 15 pin VGA? You may need a converter.
Oct 08, 2012 | IBM ThinkPad T40p 2373 Notebook
Trying to hook my home PC into my LG TV gets me the message Invalid Format, what can I do to get the signal or can i use this tv for my monitor with a dell PC
Connect VGA (D-sub 15 pin) cable from PC to TV (RGB PC) input jack. Connect audio cable from PC to TV. Set screen resolution on PC to be compatible with TV, such as 800 X 600 or 1024 X 768 etc. Select on the TV, the PC INPUT using the TV remote when ready to use as monitor.
Under PICTURE on the TV select SCREEN (RGB-PC). You can AUTO-CONFIG or you can set resolution manually to the same you set PC to. Other adjustments can be done here as well to get optimum picture on TV from PC.
Mar 01, 2011 | LG 26LG30 26 in. LCD TV
I'm trying to view my monitor on my LG 32" using the RGB port but can't get it working? I've connected the monitor cable to RGB port, selected the RGB menu in Imput and keep getting "NO...
I too am having the same problem. It works fine on my Samsung TV but no signal on my32lG60. If you find anything let me know. Larry mebehe.Larry@gmail.com
Dec 01, 2010 | LG 32LG30 32 in. LCD HDTV
When monitor is turned on, the words 'Check signal cable' appear. What does this mean? Thank You
Hey!
If you get that message on your screen. It is possible that there is no communication from the tower to the monitor.
Please make sure that the cable that is connected from the monitor to back of the tower is properly connected.
Also check if the lights on the tower are on and try to check if they're the ones that you normally see when you use your computer. It could also be possible that the computer is encountering a problem.
Hope this helps! :D
Sep 09, 2010 | LG Computers & Internet
Lenovo T60 interfacing with Vizio HDTV using RGB cable
The X1400 supports Full-HD resolution. Full-HD/True-hd (1920x1080)
The best output would be via DVI but you are limited with the VGA port.
I would purchase a Grand Hi-Wire PC to HDTV converter from www.globalcomputer.com. Item # G126-1036 @ $139.99
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 04, 2008 | Computers & Internet
LG Monitor Display Problem
1. Mostly Loose contacts in video section that means CRT Neck board dry points checke it.
2.Pl check VGA Cable RGB signal pins 123 to ground 75 Ohms (on OK condition).
3.check 5v supply
4.check SDL and SCL signals.
Oct 05, 2008 | LG Studioworks 563N 15" CRT Monitor
VERY DARK COLORS ON THE SCREEN..
check power section the brightness control transistor could be open.The voltages are ok on rgb.check heater voltage
Hope this be of initial help/idea. Pls post back as requested, how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FIXYA.
Mar 07, 2008 | Samsung 793S 17" CRT Monitor
LG L246WH-BN TV Logo
170 people viewed this question
Computer Repairing
Computer Repairing
