Question about Xerox WorkCentre Pro 412 All-In-One Laser Printer
Having a problem w/start botton
Start button does not work
    President:
  • 2,072 Answers
Do all the other buttons function properly? If the numbers do not work etc then one of the other keys is stuck down, check them .
If only the start button is not working, then you have to remove the panel and check to see if it is broken or otherwise defective.
To remove the control panel, you have to remove the scanner. Here is how you accomplish that.
Open the front door as if you were changing toner or the drum. There are 2 silver phillips screws there, Remove those 2 screws.
Turn the maching around and remove the 6 screws holding on the back cover. Since this is a 412, you have to remove the back metal plate covering the main board, that is if I remember correctly 8 screws holding that metal cover on. remove the cover and set aside. Now look under the back edge of the scanner, there are 3 philips screws holding the back of the scanner it. Remove those screws. Then there is one ribbon cable connected to the upper part of the main board. Another plug just to the right of the white ribbon cable. Remove that, and also the green ground wire is screwed to the upper metal bracket. Remove the screw and the wire. to then remove the scanner from the back side of the machine, pull the scanner back and up to remove it. Then turn the scanner upside down and there are 3 screws holding the panel in, remove those screws and unsnap the pannel from the scanner, then remove the screws holding the circuit boards to the start assembly and check the switch.
Posted on Oct 03, 2008
My 2nd machine and same problem the start botton falls into the machine its a push botton 2months out off gareintee
you can remove the panel and look inside, the button is usually spring loaded. and u may be able to work with it to fix it? many times a build up of soap and softner can cause sticking keys
Mar 26, 2015 | Washing Machines
When I push the start button everything works as it should, but as soon as I release the botton, the drum stops turning.
Hi carleypiper...
Replace the start button...its defective
Please take time to rate me thumbs up
Sep 14, 2011 | Dryers
When trying to set my salt water system the down button works but when I push the up button it doesn't set the pool to 00
Are you holding the up arrow long enough Push hard and steady ti'll it beeps
Then it is short pushes on the up arrow to set time
Then down and up again to lock it
It will take 2-10 minutes for the second light to come on and start generating
Jul 19, 2010 | Intex Automatic Salt Water System for ...
The ice maker is not working and the top botton for control won;t work
The start device on some models of refridgerator for maytag and whirlpool have been recalled. If your appliance was manufactured in the last 5-10 years you may be having an issue with this component
Jun 10, 2010 | Refrigerators
What bottons do you press to remote start on a 4 botton
If im not mistaken, button 1 starts and button 4 stops
May 12, 2010 | Remote Start System
My left mouse button on sony vaio vng-nw150j isn't working
Generally, if a mouse button quits working, it requires the replacement of the touchpad assembly.
Boot to the safe mode, see if the button works there, if it doesn't, then it is a failure of the switch in the button
http://cgi.ebay.com/TESTED-Sony-Vaio-VGN-NW150J-LCD-Keyboard-Palmrest_W0QQitemZ120522991092QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item1c0fbae5f4#ht_1088wt_1165
Jan 29, 2010 | Sony VAIO VGN-SZ460N/C Notebook
I do not have a manual and need to know how to set it up and the code for a vizio tv.
On your remote you will find a setup botton and what i want you to do is hit set up then hit the tv botton and hit channal up and do that untell it turns off your tv are the channal if that works it tv botton again and your remote will work other wise in the back of your remote it well tell you a code number and go on line to philips and they will give your your codes for you.
Dec 09, 2009 | Philips Magnavox Learning Universal Remote
Nextar mp3 player button problems
i figured out how to use it without using the play/pause botton by going to browse it plays the song automatically instead of having to press play.
thank you for the help
Jul 28, 2008 | Nextar MA933A MP3 Player
L and R bottons
try cleaning them if nomal cleaning doesnt work spray a quik shot of wd-40. NOTE just a tap to loosen the gunk in the side of both buttons and let sit for an hour come back and press the button multiple times. NOTE:do not use very much pressure or you may further damage
Oct 28, 2007 | Nintendo DS Lite Console
Xerox WorkCentre Pro 412 All-In-One Laser Printer Logo
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
