Question about GE DCVH515GF Gas Dryer
GE DRYER MODEL # DPGT650GHMG
I just purchased a new GE Gas dryer and have purchased the LP conversion kit (part # WE25X10014) . The kit came with a propane selector plug and an orifice and a diagram. The orifice fit just fine but we cannot find anywhere on the control panel where the selector plug goes and the diagram looks nothing like what the inside of the control panel looks like. Please help!!!
  • Anonymous Oct 01, 2008
    hkjkjkjkjkjjll kkjk
3 Suggested Answers
  • 10865 Answers
SOURCE: how do i get to gas valve to install lp gas
call your lp provider as they often will send out a tech to do this conversion for free. after all you will be buying the gas from them.
Posted on Aug 17, 2009
Controlfrk
  • 304 Answers
SOURCE: how to get into dryer to convert to LP
Disconnect power. Turn off gas.
Open the door and look along the front upper edge of the door opening. In the top left and right rounded corner of the door opening you will see screws going upward into the top. Remove both screw and raise the top.
Look down inside the open top dryer from above on each left and right edge there will be a screw holding the front assembly to the case of the dryer. Remove 1 on each side.
The dryer front can now be pulled toward you about 3 inches at the top and then lifted off the bottom clips and swung away to the right from the case. Be careful not to strain any wires connected between the case and the front.
This will expose the underside of the dryer along with motor, Gas valve and venting for checking and vacuuming. Be careful of the ignitor. It is very brittle and can be easily broken
Gas service should should be done by professionals only as improper servicing can cause fires, explosion or death from asphyxiation. TEST for leaks after reassembling gas parts.
Perform thorough vacuuming and reverse the above process for reassembly. Good Luck
Posted on Sep 11, 2009
Testimonial: "Thank you...looks like great instructions. I'll try it."
How to convert a gas dryer to propane?
Go to an appliance parts store or contact GE for an LP conversion kit.
Aug 13, 2014 | General Electric DHDSR46GGWW Gas Dryer
I need to convert this GE spacemaker back to natural gas. How do I do it
1e72cd65-81c6-4987-8438-377a9b970679.jpgLet's begin with the brass
plug with a little nylon pin
sticking out of it (see the
conversion kit picture above).
That white nylon pin is called
the blocking pin. Unscrew the
plug on the valve, called a
leak limiter, and replace it
with the new one that has the
blocking pin. This changes the
gas regulator pressure setting
for propane.Next, change the
orifice metering plug in the
burner. This controls the
amount of gas that enters the
combustion area.
One point of technique here.
Both the metering orifice and
the blocking pin plug are made
of brass and going into a
steel valve body. Brass is
softer than steel and will
make a gas-tight seal without
having to use gorilla force.
When you screw these brass
fittings in, don't go nuclear,
just snug 'em down.
Do this in reverse LOL
Sep 24, 2013 | GE Clothes Dryer LP Gas Conversion Kit -...
How to perform LP conversion for DLG5002 dryer I
you first need to turn the screw on the gas valve clockwise to close it,then replace the l.p. orfice to the propane orfice on the burner tube and put the enclosed sticker on the gas valve that it is now set for propane gas operation
Jun 12, 2011 | Whirlpool LGR5636L Gas Dryer
Brand new roper dryer MOD RGD4440VQ1, Its gas and has a LP fitting how to change the LP fitting to PRopane. I have the conversion kit but can't find out how to install it
According to the roper site you may not change to LP gas yourself. You will need to get a licensed LP technician to make the conversion. The reason why is that they will need to adjust the flow of the Lp so that the dryer will work right. If you do not get a Lp technician to do the work then you will for fit the warranty on the Dryer.
May 28, 2011 | Roper Dryers
Maytag Dryer conversion From LP Gas to Natural Gas
Get a nat gas conversion kit using your model number. Now this link shows how to convert nat to LP you would do the opposite.
Basic Dryer conversion 101
Aug 21, 2010 | Maytag MDG2706A Gas Dryer
Need to change from LP to propane. How do I get access
Gas to Propane requires a Propane Certified technician. These technicians are provided by the company that provides Propane that they will be using.
You may need to get a Propane conversion kit, for technician from the Propane company to install.
You can certainly double check on this...Hope this helps.
May 01, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Open Questions:
GE DCVH515GF Gas Dryer Logo
155 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
