We even bought a new ps3 console, thinking that was the problem. The consoles work fine on other t.v's but not our Sony t.v. This is my son's christmas present and I need to get a solution to this problem!!!
Hi.
You will probably have to make sure the video output settings are set up.
Make sure the PS3 is turned off and make sure that the HDMI lead is properly connected, also make sure you have selected the correct source on the TV.
Press and hold the power button until you hear 2 beeps. That will allow you to set up the desired video output.
If you still have a blank screen then I would change the HDMI cable as that could be faulty.
Good luck!!
Regards.
Someone had a suggested solution to my problem and now I cannot find that solution anywhere. It was very detailed about resetting outputs....plugging into AV output and HDMI......something like that. I NEED to find that solution!!!!
