Question about Dacor PCS130 Preference Electric Single Oven
Dacor preference oven
My dacor preference PCS130B electric oven will not turn on. I have done all the trouble shooting procedures sugested in the manual. Now what?
  • ARDESS Oct 03, 2008
    That did't work...any other ideas?
Did you turn off the circuit breaker for 30 mins?
Posted on Oct 03, 2008
My oven flashes and beeps F 4. What does it mean?
F4 on a Dacor oven is a bad temperature sensor.
The temperature sensor is inside the oven up high on the back wall
Mar 29, 2011 | Dacor PCS130 Preference Electric Single...
Our Dacor ECS130SBK convection oven no longer heats, after using the broiler and leaving the door open.
The element is probably failed. Using an oven in this manner (turned on with the door open) is not good.
The element is replaceable, and will require some electrical tests to confirm the failure.
Dec 10, 2009 | Dacor ECS130 Epicure Electric Single Oven
Dacor ECS230 Epicure Electric Double Oven
You probably tripped a safety thermostat in the back of each oven. If you turn off the breaker and find a way to pull the units out you could probably remove the rear panel and reset the thermostat by pushing in a button on the back of the open thermo. Some thermo's aren't resettable though so you'd have to buy a replacement.
Sep 22, 2008 | Dacor ECS230 Epicure Electric Double Oven
Dacor Oven
Depending on your model it is usually at the top behind the "grill" of the oven that is not working. Take out the screws aournd the oven latch (usually for cleaning) and slide out the grill. The limit switch is either over the latch or to the side. If it popped, just put it back with a screw driver. If that is not the issue, then it it could be a bigger issue.
Aug 12, 2008 | Dacor ECD230 Epicure Electric Double Oven
Dacor ECPS130 fan won't shut off
Hi, Dacor has a Technical Manual that may help you with your problem. It has a ECS wall mount oven but does not list a ECPS. Is your listing of the model correct? Here is a link to download the Technical Manual. https://www.scribd.com/doc/14008662/Dacor-Technical-Manual
Hope it helps.
Mar 20, 2017 | Dacor PCS130 Preference Electric Single...
PCS 130 Keypad
Dacor probably won't cover anything. F1 is either the touch pad or ERC (clock). If it stops beeping when the touch pad is uplugged from the ERC then the touch pad is the problem if not it is the ERC. Call Dacor Customer service to get a price on the parts and to voice your displeasure.
May 22, 2008 | Dacor PCS130 Preference Electric Single...
Dacor CPO130W F4 fault
f-4 on decor ovens mean the oven temp sensor is bad. replace the oven temp sensor and it will be fine
Nov 27, 2007 | Dacor ECS127 Epicure Stainless Steel...
Dacor Oven - convection fan stays on while on "bake" setting
Question: does the unit appear to hold the correct temperature? Most convection units only turn the heating elements on and off...not the fan. If the unit is reporting operating temp and then taking other direction...and it is cooking right...you're done.
Nov 14, 2007 | Dacor ECS127 Epicure Stainless Steel...
Open Questions:
Ovens Logo
287 people viewed this question
Top Dacor Ovens Experts
Dan Webster
Dan Webster
Vitaliy Gins
Vitaliy Gins
ashburton
Are you a Dacor Oven Expert? Answer questions, earn points and help others
