Question about Maytag Washing Machines
High pitch noise when Maytag washer is in spin cycle, sounds like metal on metal
  • 943 Answers
Hi. thanks for the question. the problem you are having is with the water pump . some piece of metal or plastic is in the pump .check the water pump. thanks the appliance doc
Posted on Oct 01, 2008
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Dec 03, 2015 | Washing Machines
Kenmore - high pitch noice during spin cycle
Sounds like bearing squeal,providing no leaks or shake leave meantime
Jul 01, 2012 | Kenmore Washing Machines
High pitched buzz/whine during wash cycle only, spin fine
1) Make sure valve is open all the way 2) some machines have a screen inside of the hose hook up which could be clogged. 3) last check to see if it is the hot or cold by switch your selector switch on your machine to hot then cold. If one of these positions eliminate the noise then the valve in the machine is bad.
May 16, 2009 | Maytag Atlantis MAV8000
High pitched screeching noise when in spin cycle
Sounds like the belt is worn and might need to be replaced. Let me know if I can do anything else. thankyou for asking.
Mar 03, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer only spins in the rinse cycle
the top loaders have bad tub seals which allow water on to spin bearing and then gum up everything.take the frount cover and look for water .if so and you have no service contract it will be expensive.aslo google your model to look for re calls
Dec 31, 2008 | Washing Machines
Maytag atlantis mav6000
sounds like the carbon brushes need replacing in the motor, they can cause a screeching sound as they wear down.
Oct 26, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Atlantis won't agitate. Will spin.
hi thanks for the question if it was making a high pitch noise that's the transmission buy new washer but not a maytag a roper is good same ae kenmore thanks the appliance doc
Jul 23, 2008 | Maytag Atlantis MAV6451 Top Load Washer
Maytag Washer Model: > LATLAT9457AAM Problem experienced: > High pitch sqeaky noise during spinning (draining) cycle. > Rubber burning smell(from transmission belt?) > Pulleys move OK with...
Most probably the bearings heating, which in turn heats the rubber seals and causes the belt to slip.
If there is no noise of metal on metal, you may be able to grease the bearings to get some more life out of them.
Taking the drum out is not an easy job though.
Jul 07, 2008 | Maytag Washing Machines
Maytag Epic Washer high spin shaking, AND high-pitched sound coming out of washer
When someone reports severe vibration during spin on a brand new washer, the first question always has to be whether the transit brackets have been left in.
Washers are designed so that the drum and motor float on a collection of springs and shock absorbers. To prevent damage to these during shipping, a set of brackets is used to bolt the floating assembly to the case. If these aren't removed before first use (the manual will say how to do it) havoc ensues.
The irritating whine is a new one on me.
A.
Jul 04, 2008 | Maytag EPIC MFW9700S Front Load Washer
High Pitch sound during spin cycle
sometimes the high pitch will come from rear bearing open door pull up on basket see how far it moves up down also ck the pump for thngs in it
Feb 24, 2008 | GE WPXH214A Front Load Washer
Washing Machines Logo
94 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
