Question about Refrigerators
Hinges on side by side refrigerator/freezer
Freezer door on side by side Crosley seems to want to "spring" open.
  • 943 Answers
Hi. thanks for the question .look at the bottom fridge hinge. that part needs to be replaced. thanks the appliance doc
Posted on Oct 01, 2008
Freezer door opens
This sounds like an alignment problem. Loosen the hinges slightly and place the door in the closed position and duck tape it in place. Tighten the hinges and check it for seal. Door is heavy by itself so empty it first and work with some help.
Apr 01, 2014 | Maytag MSD2732GR Side by Side Refrigerator
SAFELY REMOVING DOORS FOR SHIPPING
Good Morning Jill,
I see that you are trying to remove the doors on your Frigidaire refrigerator, model# FRS23R4A, for shipping purposes. Below are the instructions you will need to follow for both the refrigerator and freezer doors.
DOOR REMOVAL INSTRUCTIONS:
If it is necessary to move the refrigerator through narrow doorways, follow these steps to remove the doors.
IMPORTANT: Before you begin, turn your freezer and fresh food controls to "O" and remove electrical power cord from the wall outlet. Remove any food from the door shelves.
1. Disconnect electrical supply.
2. Open both doors, then remove toe grille.
3. Close doors.
To Remove Refrigerator Door:
1. Remove top hinge cover screw on refrigerator door and remove cover.
2. Trace around hinge with soft lead pencil. This will make it easier to realign doors when they are replaced.
3. Remove top hinge and lift refrigerator door off bottom hinge pin. Set door aside.
4. Remove bottom hinge, if necessary.
5. Reverse this procedure to reinstall refrigerator door.
To Remove Freezer Door:
1. Disconnect water line coming from lower hinge of freezer door at connection located under front of freezer: Press outer ring against face of fitting, then pull to remove tube.
2. Remove top hinge cover screw on freezer door and remove cover.
3. Disconnect wiring harness connector plug at top hinge: place your thumbs on flat sides of each connector and bend both parts back and forth, then with firm grasp, pull both pieces apart.
4. Trace around hinge with soft lead pencil. This will make it easier to realign doors when they are replaced.
5. Remove top hinge, allowing wiring harness to pull through hinge and lift freezer door off of bottom hinge pin. Lay door down flat to avoid kinking water line.
6. Remove bottom hinge, if necessary.
7. Reverse this procedure to reinstall freezer door.
When both doors have been reinstalled, connect water line by inserting tube and push until mark touches face of fitting, replace toe grille and plug in electrical power cord. Turn both temperature controls to center position. Adjust settings as necessary. Hope this is helpful.
-Best Regards-
WP
Mar 14, 2014 | Frigidaire FRS23R4A Side by Side...
Side by side kenmore refrigerator no suction on produce side
There is no suction normally. The door has a spring type mechanism to keep it firmly closed, and the magnetic seal takes up the slack. Check the door/ hinge is straight and tight and look at the top of the hinge. There is a small cylinder about 5mm high with a number of dimples in it. One of these should have a pin in it that operates the spring mechanism; if it is missing the door will not close well.
Also make sure there is nothing in the fridge protruding, stopping the door from closing and the seal sticking!
Apr 18, 2012 | Kenmore Refrigerators
Refrigerator door will not shut. Seal is clean and free of debris. 2 joints at top and bottom also seem fine, but pops open the minute it's closed. Any ideas?
At the top or bottom,one of the hinges is spring loaded.It varies from brand to brand.Try removing the door from it`s hinges.Then manually move the hinges to the closed position.Replace the door,that should work.
May 15, 2011 | Kenmore Side by Side Refrigerator
Crosley side by side. freezer/refrigerator. Has ice maker/water. Question is why is the fridge side freezing things. Its on lowest setting? I tried cleaning out the coils that were under the fridge.
there is a damper control on the top left of the fridge compartment that may be stuck in the open positin open the fridge door and turn off the unit completely you should be able to here the damper door close. if you do not it may need to be replaced,and or your thermostat for the fridge needs to be replaced.
Feb 23, 2010 | Crosley CFFH10W Top Freezer Refrigerator
Changing the opening side of the door
You will need to reverse the hinges, it should be the top for the freezer, and the one in the middle support, both the freezer and the large door, you will not only move this to the other side but you may have to turn it over, and the bottom hinge just move it to the other side. You will need to start with the large door, because the hinge support the bottom and top door, the bottom first, next the middle hinge, place the freezer door on the middle hinge and the top hinge to sesure the freezer door, move the handles, the holes for the screws will be on the other side with a little cover that you will have to remove just have to pull them out.
Nov 25, 2009 | Maytag MTB1891AR Top Freezer Refrigerator
Refrigerator top freezer door slightly rubs to inside freezer bottom while closing the door that opens on right side. Due to this after closing the freezer door, the door opens less than a mm near the left...
I think I can help. Usuly the doors have been swapped around in this case. look closely at the freezer door on hinge side. there should be a small metal piece that covers the hinge to prevent anything from jamming hinge. this shield also serves as a spacer. this is what sets the door at the correct height. if the piece is missing you can have your local appliance dealer order one for you. it only takes a few minutes ts to install. you will need to remove the freezer door to do this. Hope this helps and good luck.
May 07, 2009 | Whirlpool ET1FHMXLQ / ET1FHMXLT Top...
My freezer door will not stay shut. Dometic Model RM2453. This is the model with the freezer compartment inside the unit. Springs in freezer door seem weak or broken.Can I safely remove the plastic spring...
yes you can.remove two screws from under one side pull it away slightly and it will come away.you will then have one housing on both sides left in the fridge wall,they will have a little pressure on them from the springs. just prise them away. you will need help to replace them, as you need pressure against the spring to keep the door closed. you can buy springs and housings seperately from camec there is left and right housings.give me a call if you need to ..
Apr 22, 2009 | Dometic RM2452 Refrigerator
Ref. side by side
IF IT SEEMS BROKEN IT PROBABLY IS GOOD NEWS YOU CAN GET NEW HINGE FROM DEALER AND IT ATTACHES SIMPLY WITH SCREWS EASY TO REPLACE HOPE THAT HELPS
Aug 20, 2008 | Frigidaire FRS3R5EMB Side by Side...
Freezer door opens just a tiny bit when i shut the fridge side anybody know how to fix this
to be honest with you, close the door more gently. there are air vents between the frig and the freezer, when you close the frig door its forcing air into the freezer which in turn forces the door open some. the air has to get out so thats what it does. i hear this complaint alot.
Nov 27, 2007 | Frigidaire FRS3R5EMB Side by Side...
Refrigerators Logo
73 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
