Question about Samsung HLR5667W 56" Rear Projection HDTV
No picture and no sound
I was watching TV and suddenly I heard a loud noise from the back side of the TV and it went off. If I start the TV it keeps making some nose and unplug is the only answer to stop it. Also the Lamp light blinks. Do you think it is only a lamp or something else is going on here.
Thanks
Muttu
  • 1 more comment
  • eSapient Oct 16, 2008
    I have the same problem. What is the solution?
  • msv1 Oct 29, 2008
    Thanks for all th ecomments, It was just a bulb I replaced it and it is working like a new now.
  • whytry68 Nov 15, 2008
    I have the same problem I think.... My 56" DLP was bought in Sept 05, and the it worked great until last night. It all of the sudden made a wierd noise and then the picture was black and gray lines more than anything else... I turned it off and now it will not turn back on, I get the Samsung power on noise but then all I get it the Lamp/Timer/Standby lights all flashing and a humming noise from the tv when I try to turn it on.. Is this the same problem? If so can I get the part numbers or is it pretty easy to figure out at sumsingparts.com? Or another vendor if you got one...
I fixed my problem by following the five videos in YouTube starting with http://www.youtube.com/watch?v=Cx4pbNjsxfU .
You can confirm that your color wheel needs replacing if the high-pitched whirring-whistling noise stops immediately on powering off the TV. If a noise persists for a while, it is the fan.
You can order part (samsungparts.com) and replace yourself.
Also, check this out: http://www.jangro.com/a/2006/07/24/samsung-dlp-replace-color-wheel/ .
Posted on Oct 29, 2008
You need a coler weal if it macks noise.
  • 1 more comment
  • manslayerdbz Oct 29, 2008
    its not as hard as looks .
    it some times meses up the lamp if the noise is on for a long time ,so you may also need a lamp but that is only if you leav it on for a wieal .
    i had the same problem and the a new color well fix it.
It sometimes makes a static nose and the picture is dark i have tried messing with the color and back light settings and it doesn't do much
Samsung LCD TV with no video and high pitched sound - Digital TV ...
www.tomsguide.com/forum/54120-4-samsung-video-high-pitched-sound
Jan 7, 2010 - 26 posts - ‎15 authors
Hi, I have a Samsung LN40A550 LCD TV which I have had for just over a year. ... I was watching TV yesterday and all of a sudden the picture went all. ... started makinga very high pitched buzzing sound with no picuture coming on. We did have a bunch of green vertical lines, but now just a black screen.
Samsung LCD Green Screen - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - TV hooked up to basic cable and getting green screen picture. ... I was getting green static in the dark areas and green fuzz down the left hand ... where can you find the white ribbion, i have a lg rt-32lz50. it works sometimes, but i goes green. Samsung LCD TV screen went black (audio on, no picture)
Jun 11, 2015
Samsung LCD TV Has Flickering Horizontal Lines (Pic Inside ...
Jun 11, 2015
Samsung DLP crackling/static noise
Jun 11, 2015
LCD TV making clicking/cracking sounds
Nov 24, 2006
More results from www.cnet.com
Samsung LCD Loud Noise and Green Vertical lines at Start up ...
www.badcaps.net > ... > Troubleshooting TVs and Video Sources
Feb 03, 2016 | Samsung Ln40e550 40 1080p Lcd Tv ln40e550
Tv went blank and started making a clicking noise
Main board fault. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/
Aug 01, 2014 | Proscan PLED4274A 42" LED TV 1920x1080, 60...
Smoke from plasma TV
Sounds like you will need a new power supply board you can get the power boards from www.tvrepairworld.com which also has instructions for replacing the board. Just hit the contact us button on the right side then enter your model number and symptoms a samsung tech will respond via email to assist you with the issue.
Jan 23, 2012 | Samsung 50 in. Plasma TV
We were watching tv and all of a sudden we heard a
I had the same problem. We replaced the Y Sustain board. It was under $200 and not at all hard to do yourself. Remove the back of the tv. Make sure you watch what screw goes where. You will see the board on the left side. The number should be on the bottom right corner of the board. Just watch how you removed the board making small notes as to what goes where. Its really not that hard and you can save 600$ or more
Jun 06, 2009 | Zenith Z50PX2D 50 in. Plasma HDTV
Tv went out after loud pop and has clicking noise does not turn on
If you have a Sony DLP, then the loud pop you heard is your lamp.  The lamps last approx. 4K-6K viewing hours.  Read your manual for replacement part number to reorder and very simple to replace yourself.
Apr 22, 2009 | Televison & Video
Samsung DLPTV bad picture and buzzing sound
You color wheel blew a bearing. You need to replace the color wheel.
Mar 28, 2009 | Samsung DLP HL-P5663W 56" TV
No picture do have sound
i think you have a blown tube.if theres no pic but sound youve got a blown tube
Nov 03, 2008 | Akai PT5598HD 55" Rear Projection...
Whistle noise? POP? Black out
sounds like the lamp has shattered. check the lamp
May 18, 2008 | Samsung HLN5065W 50" Rear Projection...
No picture, hear sound, television will shut off after a few seconds.
Lamp life is only a few thousand hours. Hopefully its only the lamp that made to noise. Don't turn on again until lamp is replaced.
Nov 05, 2007 | Toshiba TheaterWide 52HM84 52" Rear...
No picture
Bad IHVT ( flyback transformer)--need complete service
number off back for part #-----------Let me know...T.
Oct 15, 2007 | GE 46GW947 46" Rear Projection Television
Samsung HLR5667W 56" Rear Projection HDTV Logo
191 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
