1999 Jeep Cherokee Logo
Anonymous Posted on Oct 01, 2008
1999 jeep grand cherkoee-air bag light on then chimes
Codes read Driver Squib Open circuit, whats the that mean
Marvin
Level 3:
Top Expert:
  • Jeep Master 85,242 Answers
  • Posted on Oct 01, 2008
Marvin
Jeep Master
Level 3:
Top Expert:
Answers
85242
Questions
28
Helped
29052396
Points
266281
Check the rotating contact (also known as the clock spring) under the steering wheel, this is the weak link in all airbag systems.
Anonymous
Level 1:
Problem Solver:
  • Contributor 7 Answers
  • Posted on Oct 05, 2008
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
7
Questions
0
Helped
6056
Points
12
Where is the clock spring?  rough idea would be great
  • Anonymous Nov 16, 2012
    remove steering wheel....right under it....unhook your battery for 20 minutes and remove the airbag fuses before you start playing with these things...
Trouble codes for 2006 ford foucos
p2258 - Secondary Air Injection System Control 'A' Circuit High
Possible causes - Faulty Secondary Air System Relay - Secondary Air System Relay harness is open or shorted - Secondary Air System Relay circuit poor electrical connection - Faulty Secondary Air System Pump
B1934 - Air Bag Driver Inflator Circuit Resistance Low on Squib
B1935 35 Passenger Air Bag Circuit Resistance Low Go To Pinpoint Test K
B2232 - Air Bag Driver Circuit Open - Loop #2 0 ' Add Comment Possible causes - Faulty Clock spring
Possible symptoms - Air Bag Warning Light ON
Hi i have just changed steering wheel on fiesta zetec 2003 for a ST150 2005 steering wheel will the air bags and connections be compatable with each other.
. Were did you check for codes ? an what are you checking with ? you need a factory scan tool to check for those type codes ? or the light flashes codes
Lamp Fault Code (LFC)
When the RCM detects a fault, it will cause the air bag indicator to flash a coded sequence called a LFC. The code is one digit. The digit is indicated by a number of flashes with a 0.5 second interval between pulses. There is a 5 second pause between each display of an LFC.
Each LFC is flashed five times after which the air bag indicator will remain lit as long as the key remains in the RUN position. If there are multiple LFCs, each LFC will flash in order of priority.
Each LFC has one or more associated DTC.
  1. Press TRIGGER. The RCM will run the On-Demand Self-Test and display On-Demand DTCs (reflecting hard system concerns) on the screen.
Restraints Control Module (RCM) DTC Index DTC LFC LFC Priority Description Action - Continuous 1 Air bag warning indicator is illuminated continuously Go To Pinpoint Test B . B1231 Continuous 3 Longitudinal acceleration threshold exceeded (Crash Occurred) Go To Pinpoint Test C . B1318 Continuous 4 Battery voltage low REFER to Section 414-00 . B1342 Continuous 2 RCM is defective DIAGNOSE and REPAIR other DTC(s) that are present. CLEAR the DTCs. REPEAT the self test. When or if DTC B1342 alone is present, INSTALL a new RCM. REFER to Restraints Control Module (RCM) in this section. CLEAR the DTCs. REPEAT the self test. B1462 N/A N/A Safety belt switch circuit failure Go To Pinpoint Test AN . B1869 Continuous or Tone 39 Lamp air bag warning indicator circuit open Go To Pinpoint Test AJ . B1870 Tone 41 Lamp air bag warning indicator circuit short to battery Go To Pinpoint Test AK . B1876 4 24 Safety belt driver pretensioner circuit failure Go To Pinpoint Test T . B1877 4 23 Safety belt driver pretensioner circuit open Go To Pinpoint Test S . B1878 4 22 Safety belt driver pretensioner circuit short to battery Go To Pinpoint Test R . B1879 4 36 Safety belt driver pretensioner circuit short to ground Go To Pinpoint Test AF . B1880 4 27 Safety belt passenger pretensioner circuit failure Go To Pinpoint Test W . B1881 4 26 Safety belt passenger pretensioner circuit open Go To Pinpoint Test V . B1882 4 25 Safety belt passenger pretensioner circuit short to battery Go To Pinpoint Test U . B1883 4 38 Safety belt passenger pretensioner circuit short to ground Go To Pinpoint Test AH . B1885 4 37 Safety belt driver pretensioner circuit resistance low on squib Go To Pinpoint Test AG . B1886 4 39 Safety belt passenger pretensioner circuit resistance low on squib Go To Pinpoint Test AI . B1915 3 10 Air bag driver circuit failure Go To Pinpoint Test F . B1916 3 8 Air bag driver circuit short to battery Go To Pinpoint Test D . B1920 3 13 Air bag passenger circuit failure Go To Pinpoint Test I . B1925 3 11 Air bag passenger circuit short to battery Go To Pinpoint Test G . B1932 1 9 Air bag driver circuit open Go To Pinpoint Test E . B1933 2 12 Air bag passenger circuit open Go To Pinpoint Test H . B1934 1 29 Air bag driver inflator circuit resistance low on squib Go To Pinpoint Test Y . B1935 2 31 Air bag passenger inflator circuit resistance low on squib Go To Pinpoint Test AA . B1936 3 28 Air bag driver circuit short to ground Go To Pinpoint Test X . B1938 3 30 Air bag passenger circuit short to ground Go To Pinpoint Test Z . B1992 5 14 Driver side, side mount air bag circuit short to VBATT Go To Pinpoint Test J . B1993 5 32 Driver side, side mount air bag circuit short to ground Go To Pinpoint Test AB . B1994 5 15 Driver side, side mount air bag circuit open Go To Pinpoint Test K . B1995 5 33 Driver side, side mount air bag low resistance on squib Go To Pinpoint Test AC . B1996 6 17 Passenger side, side mount air bag circuit short to VBATT Go To Pinpoint Test M . B1997 6 34 Passenger side, side mount air bag circuit short to ground Go To Pinpoint Test AD . B1998 6 18 Passenger side, side mount air bag circuit open Go To Pinpoint Test N . B1999 6 35 Passenger side, side mount air bag low resistance on squib Go To Pinpoint Test AE . B2117 5 16 Driver side, side mount air bag low capacitance on squib Go To Pinpoint Test L . B2118 6 19 Passenger side, side mount air bag low capacitance on squib Go To Pinpoint Test O . B2141 5Hz 6 NVM configuration failure RECONFIGURE the RCM. REFER to Section 418-01 . B2226/ B2227/ B2855/ B2856 N/A N/A Front crash sensor failure Go To Pinpoint Test AR . B2228/ B2230/ B2232/ B2234 N/A N/A Air bag driver, 2nd stage fault Go To Pinpoint Test AL . B2229/ B2231/ B2233/ B2235 N/A N/A Air bag passenger, 2nd stage fault Go To Pinpoint Test AM . B2433/ B2434/ B2435 N/A N/A Buckle switch, driver failure Go To Pinpoint Test AO . B2437/ B2438/ B2439 N/A N/A Buckle switch, passenger failure Go To Pinpoint Test AP . B2477 Continuous 7 Module configuration failure Check for correct RCM for this vehicle. RECONFIGURE the RCM. REFER to Section 418-01 . B2853/ B2854/ B2873/ B2873/ U2027 5 20 Left side crash sensor internal fault/short to ground/VBATT/ID fault Go To Pinpoint Test P . B2852/ B2874/ B2875/ U2028 6 21 Right side crash sensor internal fault/short to ground/VBATT/ID fault Go To Pinpoint Test Q . C1947/ C1948/ C1982 N/A N/A Seat track position sensor, driver failure Go To Pinpoint Test AQ .
1helpful
Air bag light and the diagnosis said: Right Curtain or Seat Squib Circuit Open.
Circuit open means either something has come unplugged or that you have a broken or open connection. I would start by looking at the seat belt pre-tensioner to see if it has become unplugged. If not you will have to start removing trim panels to get to the curtain connectors.
B0106 squib circuit
did you google(using toyota directives>?)
Air bags bad.
get the FSM and read every word and the extreme dangers messing here.
no year stated
no model car. no car actually stated? wow.
no country.
SSDD.
ok go to alldata.com and read.
or buy the FSM.
Squib is the explosive device, is faulting.
a squib means a low power explosive.
used in big guns to test fire , or clear a barrel or for parades ,etc.
name was stolen to car industry.
in Viet Nam we called it a short round ( it was , short)
in the car they are shot gun load sizes, and are to be respected at all times. killed many a would be mechanic.
the bad reads open circuit , or the wire is cut or the connector bad
or the bag is SHOT.
random toy , i guessed for you .
http://library.worldtracker.org/Car%20Manuals/Toyota%20Echo%202000-2002%20Approved/techinfo.toyota.com/ileaf/02toyrm/02toypdf/02rmsour/2002/02echorm/di/rs/cib01065.pdf
FSM , DTC index list
Trouble Code Conditions:
* Open circuit in P squib wire harness or P- wire harness of squib * P squib malfunction * Airbag sensor assembly malfunction
Possible Causes:
  • *Front passenger airbag assembly (P squib)
  • * Airbag sensor assembly
  • * Wire harness
tread lightly fooling with air bags or BOOM.
2helpful
Opel Vectra B, 00031 - Driver Airbag Squib Circuit High Resistance presence
It sounds like you have a bad clock spring unit located behind the steering wheel.What are the OBD11 codes.You have to be very carfull when servicing Air Bag systems you can set off the air bag and hurt yourself with static elec spark.
2helpful
1999 Jeep Grand Cherokee - drivers side squib switch ( air bag system ) where is it?
the squib is the explosive charge inside the drivers airbag. It is not serviceable and is part of the airbag, however, the squib circuit includes the clockspring and wire harness and they are serviceable.
Check out this website. The purpose of this website and company is to help peoplediagnose and repair airbag problems themselves without taking them to thedealer (if possible). It offers all thephotos and data you need to understand your airbag system, read the codes andreset the light. It's a pay site, but itcertainly is worth the money ($14.95 for 1 day full access) There's a place to check if your car is listed on the homepage This is quite a complete website with pictures, descriptionsand factory fault code charts as well as a working demo that shows just howeasy these repairs can be. Although itdoes not give step by step instructions, there is enough information in thepictures and the "how-to" pages that most people can do itthemselves. Lots of insurance companies and body shops use this site forthe information they need to repair your car. Lastly, there's a page in this site that tells you whichcars need a scan tool and which ones can be done without one http://www.airbagsolutions.com http://www.airbagsolutions.com/vehicles_list.aspx http://www.airbagsolutions.com/demo.aspx http://www.airbagsolutions.com/scanlist.aspx
AIR BAG LIGHT AND CHIME RINGS PERIODICALLY
I have a 2002 jeep grand cherokee Limited and Had similar problem. Found out that a wire/connection harness had gotten cut under PASSENGER seat.from seats moving back and forth. It's part of the airbag system, it tells airbag system if seatbelt is fastened and if occupant is in seat. Since the wire is broken, it can't report back to air back system and activates the light. try this, hope it helps.
Air bag light
What sensors do they refer to? crash?, the most common cause of the light based on my expearience is the clock-spring contact under the steering wheel has an open circuit, the part is cheap, but is is a little hard to install since the steering wheel must come off.
Top Jeep Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
john h
Are you a Jeep Expert? Answer questions, earn points and help others
