Question about Garden
Schematics for the drive belt for a poulan pro 300 ex
Try to put drive belt back on wont to see schematic
  • 376 Answers
SOURCE: drive belt diagram on poulan pro 19.5 automatic
Go to ... www.poulanpro.com Scroll down, on the right click on Download Manuals. Then enter the model number that is under the seat. Then you can choose the owners manual or the parts manual. The owners manual will tell you how, the parts manual will give you diagrams and part numbers. Dwain
Posted on Jun 14, 2009
harlan301
  • 205 Answers
SOURCE: belt is slipping off pulley
your should have a tension spring on the idler pulley. that maintains the tension on the drive belt. check to make sure you have the right belt and that is not worn or stretched out. also check to make sure your variable drive assay is working
Posted on Oct 11, 2009
fire sine
  • 382 Answers
SOURCE: Teac turntable belt came off.. help!
Through the 2 holes on the platter, lift the platter up. Take the belt, flip the platter over, and stretch it around the center ring. Flip the platter back over and turn to so one of the holes is over the spinning motor. With your finger or with a blackstick, stretch it back onto the motor head.
Also check the belt for wear....that should do it.
Keep me posted.
Posted on Dec 16, 2007
  • 156 Answers
SOURCE: putting dryer back together
if whirlpool are kenmore the pulley slides in tobottom of the dryer in front motor there a slot it goes in
Posted on Feb 28, 2008
dunnbiker
  • 8546 Answers
SOURCE: belt is off my audio-technica turntable at-pl50
WASH YOUR HANDS FIRST! Any oils on the drive belt may cause slippage.
This is from the manual:
A) Remove the record mat from the turntable platter
(Fig. 10a). Through an opening in the
turntable platter, visually inspect to see if the drive belt
is around the motor pulley (Fig. 10b).
B) If the drive belt is not around the motor pulley: Lift
and remove the turntable. Place a thumb into each of
the left and right openings on the turntable platter; and,
using the fingers to press down on the turntable housing’s
surface, pull the platter straight up (Fig. 10c).
Avoid pressing on the tone arm.
C) With the turntable platter bottom side up, place the
belt along the outside wall of the turntable platter's
drive rim, making certain that the belt is smooth and
flat all the way around (Fig. 10d).
D) Put the turntable back on the center spindle, make
certain it is fully seated, and align one of its openings
over the motor pulley position.
E) Through the opening, carefully hook the turntable
belt with a finger or with the original red ribbon (never
use a sharp object) and pull the belt over the motor
pulley (Fig. 10e). Make certain the belt is not twisted
between the pulley and the platter’s drive rim.
F) Put the record mat back on the platter.
G) While holding the tone arm in its rest position,
slowly turn the platter by hand clockwise at least 10
rotations to clear the mechanism’s automatic cycle.
Posted on Apr 24, 2009
Poulan pro 42 inch riding mower electrical wiring schematics, can't find my model number.
The serial number / model number plate is located under the seat.
Aug 10, 2017 | Poulan Garden
My poulan pro rider mower runs but won't move
Hi Kristy:
If you're lucky, the drive belt has come off.
If you're not so lucky, the drive belt has broken.
Most machines are similar to this.........
With the motor OFF, find a comfortable way to lie down and look under the machine. There will be a pulley under the motor, and a v-belt should be loosely around it.
The belt will go toward the back of the machine,past one or 2 idlers, and then around another pulley at drive.
If the belt is off any of the pulleys, put it back on.
Withe the motor OFF (I said that before but it's important), have a helper step on the Forward/Reverse pedals and watch to see what happens to the drive belt pulleys.
If the drive belt does not tighten up, try to figure out why. When you do, you'll be back cutting grass.
Jun 25, 2015 | Poulan Garden
2008 poulan pro 18.5 hp 42" cut 6 spd smokes bad when i put it in gear
check drive belt make sure its not rubbing against melt guied tabes
Aug 18, 2013 | Poulan Pro Lawn Tractor 2006 and Newer...
Hi, I need a schematic for a Studiomaster Powerhouse 300
For your requirement of the schematic for your model is not available now. But this schematic will help you. Visit http://www.studiomasterarchive.com/6-2-1sc.pdf and download the PDF. It will help you.
Jun 15, 2011 | Audio Players & Recorders
Replacing gas line
Your fuel lines are routed like the schematic below. I suggest you replace the filter, all hoses (2 different sizes), and the purge button (bleeder).
http://www.fixya.com/support/r3706813-2_cycle_fuel_system_repair
May 07, 2010 | Poulan ES350 16" Chain Saw
Changed belt, now its not working
Check the 1690 manual provided , there should be some picture there, models are almost the same
Jul 07, 2008 | Bissell 1697-7 Powersteamer Pro Deluxe...
need schematic of machine
replacing the brush drive belt
a item that looks like a valve dropped out and i need instructions as to where it belongs
Jul 04, 2008 | Bissell 1697-7 Powersteamer Pro Deluxe...
Garden Logo
1,304 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
