Tried to install my dell photo printer 720 and the error message i keep getting is not able to spools not operating.
    Novelist:
  • 169 Answers
Click "Start", then "Run". Type services.msc
Scroll down the right side and double-click "Printer Spooler". If not set to "Automatic", set it. If the service is started already, click "stop". If not started, then click "Start".
Reboot.
Pending any virus/spyware infections, that should fix you up :)
Hope this helps - remember to rate :)
Posted on Oct 02, 2008
Dell 720 printer not spooling
printers download the data in bursts from a memory stored in the computer
this spooling of tasks allows a single printer to print the next job and not mix up jobs as they are entered for printing
for this to work you have to install the driver for the printer into the computer and set printer priorities from other print sources
Nov 26, 2015 | Dell Inkjet 720 Printer
I have a Dell Inspiron 6000 with windows XP, McAfee Security Suite, and a Verizon USB for internet. When I turn it on I get an error message: dlbcserv.exe has encountered a problem and needs to close. ...
This error message is a result of your Dell printer software functioning improperly.
This is a 'quick fix' to get rid of the error message:
  1. click 'Start'->'All Programs'->Startup
  2. Right click on dlbcserv.exe and click 'delete'
PS: dlbcserv.exe is a Windows process installed alongside Dell Photo Printers and provides additional configuration options for these devices. Although it is not an essential process for the operating system, you should not remove & uninstall it unless it is causing serious problems and errors.Dlbcserv.exe is a Windows file created by Dell. The file is usually found in Program Files\Dell Photo Printer 720\dlbcserv.exe folder. If you find it anywhere else, Please note that dlbcserv.exe could be a virus, trojan, worm, or spyware. Scan your computer with an antivirus software to make sure it is not infected.
Aug 10, 2010 | Dell Inspiron 6000 Notebook
Problem installing my 720 printer
This is the way of the gods and of course the mandrins at Dell.
Try going to the dell website, follow links to support and/or downloads to find the drivers and other software you need.
If you can't find it there, use there "contact us" links to 1) demand and explanation and 2) get the software you need.
May 12, 2010 | Dell Inkjet 720 Printer
Trying to connect my dell 720 photo printer to my inspiron 1525, but don't have the disk,can you help me?
Go to this page courtesy of Dell:
http://support.dell.com/support/downloads/driverslist.aspx?c=us&cs=19&l=en&s=dhs&ServiceTag=&SystemID=PRN_INKJET_720&os=WW1&osl=en&catid=&impid=
Choose your operating system, click on where it says Dell-Driver and download the file to your desktop. Then click on it and install the software onto your laptop. This will install your printer.
May 11, 2010 | Dell Inkjet 720 Printer
Can you help me install my dell 720 printer with the drivers download from dell? My 720 dell printer installation disk was lost and I have had NO success reinstalling the printer with the drivers download...
you can follow these steps:
1.Check if the firewall is blocking any printer services
2.Check what port the printer is using (reenable the bi-directional support) and if it's on online mode
3.Disable all the firewalls
4.Uninstall the printer driver and software
5.Delete any items under the ff keys:
HKLM\System\CurrentControlSet\Control\Print\Environments\Windows NT x86\Drivers\Version-2
HKLM\System\CurrentControlSet\Control\Print\Environments\Windows NT x86\Drivers\Version-3
HKLM\System\CurrentControlSet001\Control\Print\Environments\Windows NT x86\Drivers\Version-2
HKLM\System\CurrentControlSet001\Control\Print\Environments\Windows NT x86\Drivers\Version-3
Optional***
6.Delete any non default items under the ff keys:
Note: ONLY THE NON DEFAULT ITEMS SHOULD BE DELETED
HKLM\System\CurrentControlSet\Control\Print\Monitors
HKLM\System\CurrentControlSet001\Control\Print\Monitors
Default items are as follows:
AppleTalk Printing Devices
BJ Language Monitor
Local Port
PJL Language Monitor
Standard TCP/IP Port
USB Monitor
Windows NT FAx Monitor
7.Delete any items under the ff keys:
HKLM\System\CurrentControlSet\Control\Print\Printers
HKLM\System\CurrentControlSet001\Control\Print\Printers
8.Completely remove drivers by doing the ff: (Option for comm failure because of the upgrade from xp to vista)
Ensure there are no documents in queue.
Disconnect printer’s USB cable.
Click the Start pearl, then click All programs, Printers, Dell xxx (where “xxx” is the printer model number) and then Uninstall. Complete the uninstall utility.
From the start search box type spool and press .
The spool folder located at c:\windows\system32\spool opens.
Rename c:\windows\system32\spool\drivers\w32X86 to c:\windows\system32\spool\drivers\backup.
Rename c:\windows\system32\spool\prtprocs\W32X86 to c:\windows\system32\spool\prtprocs\backup.
9.Restart the computer.
10.Check th services status
Start-Run- Type Services.msc and Click on Open
You will see long list of services
You need to make sure following 4 Services are set to Automatically start
Remote Procedure Call RPC
Remote Procedure Call RPC Locater
LexBce Server
Print Spooler
11.Reinstall the latest printer driver
12. Make sure the driver you downloaded from support.dell.com is compatible with the operating system that you're using, for example windows xp or windows vista.
Oct 01, 2009 | Dell Inkjet 720 Printer
Dell laptop print spooler service is not running
go into control panel under administrative tools and go to spoiler and enable it
Mar 29, 2009 | Dell Inspiron 6000 Notebook
Print Sooler not installed
HI
If you are receiving SPOOL.SVC or PRINT SPOOLER ERRORS when trying to uninstall/reinstall your printer, or when trying to print a document or access the printer properties, please follow the steps below.
The following are examples of some of the messages you may be receiving:
Spool.svc is not running. Make the service active and try again.
Printer Properties cannot be displayed. The print spooler service is not running.
Printer cannot be removed. The print spooler service is not running.
Windows cannot print due to a problem with the current printer setup.
(When clicking Add Printer) Operation could not be completed.
NOTE: Only these types of errors warrant the troubleshooting steps clearly defined below.
Resolution:
SPOOL.SVC is an operating system function which carries files through the operating system for printing. It must be STARTED (active) to be able to print or access any printer's functions. This file usually starts automatically with Windows, however operating system issues may cause it to become stopped. You cannot uninstall or reinstall a driver while this service is stopped.
Please try the following to start the service again:
1) Click on START, right click MY COMPUTER, left click MANAGE.
2) On the left column, double-left click SERVICES AND APPLICATIONS, then click SERVICES.
3) Locate and highlight the PRINT SPOOLER on the list of Services.
4) Click START THE SERVICE.
If errors occur and the service cannot be started, there is another issue within the operating system itself.
Nov 08, 2008 | Dell Inkjet 720 Printer
Loading Software
install the printer driver first (do not connect the printer yet until installation procedure asks you to connect the printer)
then set it as your primary printer
Nov 04, 2008 | Dell Inkjet 720 Printer
I cannot connect a dell 720 printer to dell laptop Inspiron 1501 (Vista). It says it is installed but a message comes up that communication is not available.
First, shut down your computer and priner. Unplug both from the wall outlet, Unplug the printer from the computers USB receptical. Next, plug both the computer and printer back into the wall, and turn on ONLY THE COMPUTER. After the computer is fully initialized, plug the printer into the computer's USB socket and turn printer on. A small window on your screen should say:NEW HARDWARE FOUND. it will ask if you want it installed, click on YES. and just follow the onscreen instructions, and make sure your printer driver is compatible with VISTA..To check, go to http://support.dell.com and left click on WINDOWS VISTA SUPPORT. Left click on LATEST VISTA DRIVER UPDATES, and follow the onscreen instructions to check what you have now, and what you may have to download.. If, after downloading and installing VISTA COMPATIBLE SOFTWARE,you still get the communication message, try this: On the windows screen, left click on START. left click on CONTROL PANEL, then left click on PRINTERS. Find your Dell printer icon and RIGHT CLICK on the icon.. On the drop down menu, left click on PROPERTIES. On the Properties window, left click on the PORTS tab. Make sure USB VIRTUAL PRINTER PORT FOR DELL is checked. If no, select that port, left click on the check box, also check ENABLE BIDIRECTIONAL SUPPORT and ENABLE PRINT SPOOLING boxes. Then left click on APPLY, then Ok. The Dell printer icon should show READY. Try a test print to check operation.
Aug 11, 2008 | Office Equipment & Supplies
My Dell 962 Photo Printer gives error when trying to photocopy.
The issue you are experiencing with your printer i.e error 2200 is related to "Scan Carrier Stall error" I believe the steps mentioned below will fix the issue,
1. Unplug the power cord from the wall socket.
2. Disconnect the power supply from the back of the printer.
3. Wait 15 seconds.
4. Reconnect the power supply to the back of the printer.
5. Plug the power cord back into the wall socket.
  1. Go to www.support.dell.com.
  2. Click on Drivers & Downloads.
  3. Under Option 2: Select a Product as printers .
  4. Locate the printer(s) 962 printer and click Go.
  5. Select an Operating System that is installed in your computer then choose downloads and look for Firmware.
  6. Download and install the firmware, then restart the computer and the printer, however please make sure that you do not restart your computer and the printer when the download and the installation is in progress.
I would appreciate if you could let me know if you have refilled the black cartridge, cause Dell printer often give error messages if the cartridges are refilled and not replaced with an original Dell one. If you have done so please replace the cartridge with a genuine Dell cartridge.
Regards
Malik Khan
Jan 24, 2008 | Dell 962 Photo All-In-One InkJet Printer
k24674
jasbo
jasbo
