Sears Front Loading washing machine Model 45991 400
My washing machine is locked, I cannot find my manual, and need to open it
Thank you
Marj Suter
msuter@yourlink.ca
  • rich7847 Apr 02, 2009
    Washer lock does not work properly. Sometimes it wont lock and sometimes it wont unlock and currently the door lock is in the locked position with the door opened.
Go to wwww.managemyhome.com and look for Search Product Manuals on the home page. Input Kenmore as brand and 45991 as model.
Posted on Oct 02, 2008
Keeps Stopping and saying UE
uE error code 79631512210 Kenmore Elite Washer - Sears ...
www.searspartsdirect.com > Ask an Expert
Jan 10, 2014 - uE error code 79631512210 Kenmore Elite Washer ' SearsPartsDirect. ... After unloading the washer completely, the machine attempts to rebalance the .... to ensure proper fit and to keep appliances running for years to come.
UE Error code on my front loading Kenmore washing machine
www.shopyourway.com > Manage My Life > Questions
Jun 13, 2011 - I have a Kenmore 3.5 cu. ft. front loading washing machine (model #4027) and it is 1 year old. ... what does the F35 error code on my kenmore elite front loading washing machine mean? F13 code on Kenmore Elite HE3 front loadingwashing machine.
Jan 21, 2016 | Kenmore Washing Machines
How do I get a Sears Kenmore front loading washing machine door unlocked. Model # 796.4027 with code dE. The locked door display is not lit.
Remove top should be 2 to 4 screws hold it on slide it back and off than reach down at front right hand side there a small loop pull tab down and door will unlock unplug first. Its a very tight area .
Jun 28, 2015 | Kenmore Washing Machines
Door won't open and is jammed.
We have an electronic Sears front load model with which that happened. . If this is a Sears machine contact the service number located in your manual and they should be able to talk you through it. For us it ended up being a door switch that had become misaligned. Make sure the machine spins the water out of the tub before you try to open the door if it is a front loader.
Apr 02, 2012 | Amana Washing Machines
The machine is locked and can't open with clothes washed inside,. Add garment light is on and the time is flashing'
Whirlpool-made Front Loading such as the Kenmore Elite washing machines use a door lock and switch assembly having a tab that can be pulled manually for emergency opening of the door. This tab can be accessed with the removal of the lower front access panel. Disconnect power to the washer and drain the water from the tub before accessing it. The link below contains the detailed instructions on manual unlocking of the door.
Manual Unlocking of Whirlpool Duet and Kenmore Elite Front Load Washing Machines
Aug 26, 2011 | Kenmore HE2 Plus Front Load Washer
Maytag front loader 2000 series code LF followed instructions in manual and has no power. Outlet works
Hi, is this a new washing machine? If not, then these Maytag front loading washing machines use a paraffin locking switch in the front panel to lock the door during operation. Now, if the switch has gone south and trip the the lock switch without locking the door. Then the washing machine want turn on.
What is a parfin locking switch work is a small container with paraffin (wax) in it with a heater. When the washing machine is turn on. The control board indicate that the machine is in operation and a small amount of current is applied to the paraffin switch to the heating element. This make the parfin to expand trip the locking mechanism and locking door during operation. Keep the door lock from accidental openings. It will take about 4 minute after the washing machine has quite it running operation to open the front loader door. The paraffin needs to cool down to release the locking mechanism. stewbison
Aug 20, 2011 | Washing Machines
How to operate the washing machines front load washer brandt bf850
  • Open the front door and load the clothing into the washing machine. Check the owner's manual for the maximum load size. Overloading the washing machine may interfere with its ability to spin the clothes and rinse them clean.
  • Fill the detergent receptacle on the front of the washing machine, making sure not to fill it past the indicated line. Always use a liquid detergent that is designed for front-loading washing machines.
  • Add bleach or fabric softener, if needed. Most front-loading washing machines have a section for fabric softener inside the detergent receptacle. Check the instructions on the bleach to find out when it should be added to the washing machine.
  • Close the front door of the washing machine and make sure it locks into place. The machine usually will not turn on unless the door is securely locked.
  • Check the owner's manual to find out how to select the different options and wash cycles. As a general rule, use warm or cold water for most types of colored clothing. Hot water should only be used when washing white cotton items.
  • Start the front-loading washing machine and let it run through the entire wash, rinse and spin cycles before opening the door to unload the clothing.
  • Please rate this solution. Regards.
    Nov 04, 2010 | Brandt WFH1176 Front Load Washer
    Tub smells like mildew, how do i get all the sludge out from the rubber lining, no matter if I run the tub clean cycle, it does not remove any of the sludge!!!!
    You need to manually wipe out the inner seal(lining) every time you finish with the washer. This is one of the main complaints with front loading washing machines. You also neep to leave the door open(ajar) after you finish washing so the machine can completely dry out inside otherwise you will get a buld up of mildew. Also run a dishwashing packet like cascade(yes the stuff for the dishwasher) when you run the clean cycle. It is the same as the expensive washing machine cleaning packets that the appliance servicemen from sears sells to customers.
    Nov 29, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
    Control lock
    look closely at the control panel there is a button marked"control lock hold for 3 secs." probably a small pic of lock on it as well, simply hold for 3 secs to release it,
    Jan 10, 2009 | Washing Machines
    Front loading wash machine
    It sound like door lock unit is broken or removed from the door. Good luck !
    Jun 17, 2007 | Kenmore 44042 Front Load Washer
    Washing Machines Logo
    179 people viewed this question
    Top Washing Machines Experts
    Gerry Harvey
    Gerry Harvey
