Question about Kodak Office Equipment & Supplies
Does a kodak slide projector hook up to a pc - Kodak Office Equipment & Supplies
    Novelist:
  • 170 Answers
No way! Kodak discontinued its slide projector line long before computer interface. The projectors are mechanical and analog. Maybe you can connect your remote control cord to some kind of computer interface. I know there are dissolve units available that will perform basic functions, but none that are PC-compatible as far as I know.
Posted on Nov 19, 2008
Kodak carousel 750H slide projector power cord missing
Detatchable power cords for KODAK Carousel Slide Projectors can be purchased from: www.micro-tools.com
or: www.vinevalleyimaging.com
Good Luck!! jim
Sep 13, 2013 | Kodak Carousel 4600 Slide Projector
I need a power cord for kodak carousel 800.
To purchase a detachable power cord for old KODAK Slide Projectors, contact: www.micro-tools.com
They are the source for Kodak Slide Projector Repair Parts.
Apr 01, 2013 | Kodak 4200 Slide Projector
Kodak Ektagraphic AF -2 carousal not rotating
Given the age of the projector, I suspect that the solenoid link is broken. The link joins the solenoid plunger to the cycle lever. The good news is you can still buy parts for your projector. www.micro-tools.com purchased the entire projector parts inventory from Kodak a few years ago. They can also help you with instructions to install the parts, or if you prefer, hook you up with a trained service technician to perform the repair for you. Good Luck! Jim
Nov 28, 2012 | Kodak A Ektagraphic 35mm 140 Slides Rotary...
Shutter stuck on Ektagrahpic III projector
First of all, the shutter will only open IF there is a slide in the gate. Assuming there is a slide in the gate, there are 2 things that could be preventing the shutter from opening:
1. Most likely - the shutter is spring-loaded. If the spring unhooks or is missing, the shutter will not open.
2. There is an adjustment that needs to be made after the spring is replaced or re-hooked (or just is out of adjustment. Refer to the Kodak Ektagraphic Service Manual @ the Kodak web site: http://resources.kodak.com/support/pdf/en/manuals/slideProj/manual/ektagraphic_sm.pdf
Good Luck! Jim
Aug 18, 2012 | Kodak Ektagraphic III ATS Slide Projector
The lens shutter doesn't open to display picture
If this is a Kodak Slide Projector, it is equipped with a "dark shutter", to keep blinding the audience with white light when there is no slide in the optical gate. The shutter is spring-loaded, and there is an adjustment required in order to make the shutter operate correctly. Your projector either needs a spring, needs the spring re-hooked to its mount or and adjustment to the trigger. Kodak still has service manuals on their support website, or contact: www.micro-tools.com for parts and assistance (they purchased all Kodak's repair parts). Good Luck!
Sep 01, 2011 | Office Equipment & Supplies
I have an old Kodak 760 carousel projector with 140 slide rotary. Can I get replacement rotary slide holders?
You can buy new & used Slide Trays for Kodak Slide Projectors from: www.vinevalleyimaging.com They have amazing connections with slide projector users!!
Oct 15, 2010 | Kodak BC-4401 Slide Projector
What is the correct carousel for a kodak 760 H projector?
A KODAK Carousel 760H is designed to be used with either KODAK 140 or KODAK 80 Slide Trays. The KODAK 80 Slide Tray has wider slide compartments, which tend to be more forgiving for older, slightly warped slides.
Oct 02, 2010 | Kodak Office Equipment & Supplies
Model 760 H projector-- Carrousel advances, but slides do not
My guess is that your slides are in a 140-slide tray.
Over time, with repeated cycles of humidity & drying, slides warp slightly. The compartment width in a 140-slide tray is quite narrow, and it takes very little warping to make slides stick in their individual compartments. If you move the slides to a KODAK 80 Slide Tray you should be in much better shape.
Feb 24, 2010 | Kodak Office Equipment & Supplies
Kodak 410 Projector/Viewer - no lite through projector or viewer
These projectors were designed & made by Telex for Kodak.
If the screen stays black when you push a slide down into the "gate" (in either viewer or projector mode), then the trip mechanism that opens the shutters when a slide is detected has a problem. It could be an adjustment, a broken or out of position spring or hardened lubrication.
There is no good way to proceed unless you are trained in the service of these projectors. Contact a factory-trained repair dealer. Happy New Year!
Nov 16, 2009 | Kodak Open Box BC-4601 Slide Projector
158 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
