Question about Palm Tungsten T3 Handheld
Pairing tungsten t3 with newer cell phones
I have a t3 which I want to pair with my bluetooth samsung u740. Is there anyway to this either through the bluetooth or some physical connection?
  • nortiz108 Nov 01, 2008
    I want to do the same only my cellphone is the Samsung SGH A707. I have never paired my T3 to my cell phone before
I use Bluetooth to synch to my Sanyo cell phone, so I would think you could do the same. I maintain my Contacts in Outlook and synch with my Palm. I then synch my Palm to my phone.
1. Make certain that your Contacts (in Outlook, Palm Desktop, or whatever you use as your source to feed data to your Palm) contains ALL the phone numbers you want in your phone.
2. If, like me, you have a lot of contacts and a limited number (500 in my case) of contacts that can be stored on your phone, you will want to erase all contacts on your phone first.
3. On your Palm, go to Preferences
4. Select Bluetooth -- Bluetooth should be ON, Discoverable (Yes) and Connectable (Yes)
5. Turn on your Bluetooth-enabled cell phone -- I believe the range is 20-30 feet but I have not tested that. When I synch, I have them both on my desk because I want to see that it is working.
6. Select Trusted Devices. Hopefully, your Palm will detect the cell phone. When it does, add your cell phone as a trusted device.
7. Select Contacts on your Palm and use the pull-down menu to select Send Category.
8. Select Bluetooth
9. Select your phone
10. Your phone will probably indicate that it is receiving data. You should soon have all phone numbers stored on your phone without using a direct-connect cable.
Posted on Nov 28, 2008
How to pair phone to samsung bluetooth headset wep301? I do not have my user guide.
Bluetooth Headset
Pairing Instructions
1. When you turn on your Samsung Bluetooth
headset for the first time, it proceeds into pairing
mode immediately.
2. If you have paired the headset with other
Bluetooth devices, make sure that the headset
is off. Press and hold the Multi-Function button
until the blue indicator light stays solid blue after
blinking.
3. Set your Bluetooth phone to discover the headset
by following your phone's guide. Typically, the
steps involve going to a 'Setting', 'Connection',
or 'Bluetooth' menu on your phone and then
selecting the option to discover Bluetooth devices.
4. Your phone will find the Samsung headset and
ask if you want to pair with it. Confirm this by
pressing the Yes or OK key.
5. Enter a passkey or PIN, 0000 (4 zeros), then
press the Yes or OK key.
6. If pairing was successful, the indicator light will
flash in blue 10 times rapidly before going to
flashing every 3 seconds. If unsuccessful, the
light remains on, and you will need to re-attempt
pairing.
7. When you turn on your headset after pairing
with the phone, the headset is automatically
connected to the phone.
8. When you turn on your phone after pairing with
the headset, the phone is connected to the
headset by pressing the Multi-Function button.
Jun 01, 2011 | Samsung SGH-U600 Cellular Phone
Bluetooth cannot pair with other phones samsung S3653
Hi, it may happen if you have more paired list in the Cellphone. Please delete which you have already paired devices. Then try pairing new device. If it is not pairing then check whether you have selected Visibility in the Bluetooth settings.
Mar 30, 2011 | Samsung S3650 Corby / S3650 Genio Touch...
My new phone a Samsung Gusto is not pairing to my Plantronics 233 bluetooth? Is it compatible?
Hi, to be sure if the blue tooth wll be compactible with Samsung Gusto, you will need to use the below instructions first after trying out the instruction and still does not work,that means it's not compactible with it.
instruction:
Read the owners manual for your bluetooth device. You will need to find the code to pair your headset to your phone. This code is usually 0000 (those are zeroes) but verify before you proceed.
Enter your bluetooth option on your cell phone. These can be found in your menu under "bluetooth," "connections," "settings," or something similar.
Turn on your bluetooth headset and put it in pairing mode. Pairing mode means the bluetooth is ready to be found by your cell phone. To pair your headset, follow the owners manual for your specific bluetooth model.
Select "add device" or "search for new device" from your cell phone. Your cell phone will then search for your bluetooth. Once it is found, or discovered, you will need to enter the pairing code (most likely 0000, check your manual to verify).
Select "connect" to finalize the connection if the bluetooth headset didn't connect automatically after the pairing code was entered. Make a test call with your bluetooth in your ear to ensure it is connected properly.
Good luck..
Feb 23, 2011 | Plantronics Explorer 230 Bluetooth Headset
How do I pare my Samsung SGH-A867 cell phone to mr new Beetle H-3ST Bluetooth Headset? TIA
It all depends. When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
When pairing both device, you will ask for pairing code, You four digit numbers(default code(0000). and pair.
After pairing both device, you detected paired, you can now use the blue tooth device with your phone.
there are no special code for pairing Blue tooth device.
Normal codes used are any four digit, four numbers you want to use.(0000, 1234).
Take care.
Sep 25, 2010 | Cell Phones
I just bought a samsung soltice phone and I have a scala-600 bluetooth but I cant seem to get them to connect have any suggestions and I have used a bluetooth befor.
Take care.
Sep 12, 2010 | Cell Phones
How do i work bluetooth on a samsung n150
Take care.
Aug 25, 2010 | Samsung SCH-n150
How do I setup wep301 headset to a simple at&t phone
Follow the steps to connect your WEP 301 bluetooth headset to phone.
1.When you turn on your Samsung Bluetooth
mode immediately.
blinking.
by following your phone’s guide. Typically, the
steps involve going to a ‘Setting’, ‘Connection’,
or ‘Bluetooth’ menu on your phone and then
pairing.
Thank You
Aug 14, 2010 | Samsung Cell Phones
How remove paired bluetooth device from samsung F480
first go to bluetooth menu
activate bluetooth]
select the device you want delete pairing
scroll down and click on delete
pairing would be deleted
Feb 18, 2010 | Samsung Tocco F480 - Pay Monthly Cellular...
I need to know the Bluetooth pairing code for a Samsung SGH-E900 Cellular Phone
When you are pairing with another phone, you set your own code, which is then requested from the other phone user.
If you are pairing with headphones or a handsfree unit these sometimes have their own pairing code which will be defined in their user manual.
The defaults are usually 1234 or 0000. Try these, if you have no luck consult the documentation for the device you are pairing with.
This code isnt defined by the phone
hope this helps
Dec 23, 2009 | Samsung SGH-E900 Cellular Phone
SAMSUNG SCH-u740
hi! Goto setting switch ON the bluetooth! install the bluetooth devices to the computer! insert the device in the computer! pair the mobile and computer!select the pictures and send through via bluetooth! and finaly u transfer mobile picture to the computer!
Thanking you.........
Jun 15, 2008 | Samsung SCH-u740 Cellular Phone
Palm Tungsten T3 Handheld Logo
Top Palm Computers & Internet Experts
Michael Vincent Cruz
Vuk B
Mister Danger
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
