Question about GE XL1800 1100 Watts Microwave Oven
GE Spacemaker XL 1800 Model JVM1851BD002
Range light underneath will not turn off. Any suggestions?
  • LISAMAY770 Nov 05, 2008
    This provided no help
  • Anonymous Nov 24, 2008
    I can not get the microwave cooktop light to shut off or change intensity from normal light to night light. I had a breaker for the microwave trip. Not sure what caused it to trip. Reset the breaker and it seems to be working fine except for the light.
I have a GE XL 1800 that will not turn on. i changed both fuse but its the same result,what do i do?
Posted on Jan 06, 2009
Lights underneath will not turn off
Posted on Nov 02, 2008
How to fix a Samsung microwave turntable
The drive motor underneath probably has failed.
Nov 17, 2016 | Samsung Microwave Ovens
Replaced the bulbs underneath now they won`t turn off
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
The lights can can be inoperable or stuck on or stuck in "night light" mode. Sometimes this will similarly affect the fan operation or inside light, too.
The problem is on the controller assembly, which I regularly repair. Details are here.
I also have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
May 24, 2016 | LG LMV1813ST Microwave Oven
MICROWAVE WILL START THEN TURN TABLE STOPS LIGHT GOES OUT AND STOPS HEATING THEN COMES ON AND OFF ANY SUGGESTIONS
Check the door switches. If they are good check the thermal cutouts. Check the connections on the control board.
Nov 12, 2014 | LG Over-the-Range Microwave
Samsung manuals
switch off power, just open the metal cover , replace the bulb
Aug 07, 2014 | Samsung 1.8 Cu. Ft. Over-the-Range...
How to use oven in gas cooking range
turn the knob to 350 and wait til it heats up or try lighting the pilot light underneath the bottom oven rack
Sep 15, 2013 | Microwave Ovens
Ge spacemaker xl1800 vent fan
I'm betting your base model number is JVM1860, JVM1861, JVM1870, JVM1871, JVM3660, or JVM3670.
That's the automatic louver you're having trouble with. There are micro switches in the louver assembly which tell the controller when the louver is open or closed.
If one of those switches or the louver motor fails, the louver will not work correctly.
Did your cooktop lights recently fail?
Sometimes the surge from them shorting will cause damage to the circuit board, which can be repaired.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
There is a video here showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
May 03, 2013 | GE Profile Spacemaker XL 1800 36"...
My GE 1800 microwave turntable has stopped turning
There is a motor underneath the microwave that rotates the turntable. The motor may not be getting power or the motor may have failed.
Feb 11, 2013 | GE Profile Over the RanMicrowave....
GE spacemaker xl microwave oven will not heat
My guess is the magnetron is bad. It is rarely the transformer
Jan 04, 2013 | GE Profile Over the RanMicrowave....
GE jvm1653sh01 range lights won't turn off
Got a short at or in the switch assembly that is causing this and unit would have to be unpowered and checked to see if one or both switches are bad.
Oct 29, 2012 | GE Spacemaker JVM1640SJ Microwave Oven
I have a GE Profile Spacemaker XL 1800 JVM1860SD microwave that recently started making a zzzzzzzz noise whenever it is plugged in. The light also seems to be stuck on. The noise seems to be coming from...
That would be a defective electrolytic on the control circuit board.
We see and repair this problem often with our $39.95 service. Details are here.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Jul 09, 2011 | GE Profile Spacemaker 1.8 Cu. Ft....
GE XL1800 1100 Watts Microwave Oven Logo
472 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
