Question about GE Spacemaker JVM1640SJ Microwave Oven
Door Handle and Rusted Interior
My GE Spacemaker Microwave is 12 years old. The handle has broken. As it costs about $60 to replace, plus the inside of the oven is chipped and rusted in spots, should I replace or repair???
Is the rusting damaging to the food/health??
Thanks for your reply
  • 706 Answers
Hello SusanWargin,
In my opinion ( and that is all it is).. I have always stood by the old litmus test whereby : if the cost to repair is close to or exceeds the cost to replace, then replacement makes sense. From the description you've presented and considering your micro is 12 years old, there is a reasonable chance that other components ( magnetron, transformer et al) will begin failing and end up costing more and more. So.. I would support your decision to replace with a new one. (again, this is only my opinion but I say this with sincerety and some experience with these appliances) ...Good Luck deciding..
Posted on Oct 01, 2008
My counter top GE Spacemaker microwave oven's door handle is broken. Is there a replaceable door handle part?
Hi!!
Yes, there is. The part # for the HANDLE,DOOR -L is WB15X10119 and costs $15.25. You can order it from this site https://www.geapplianceparts.com/GEApplianceParts/Dispatcher?REQUEST=ACCESSORY use your oven's model # to make sure you have the proper handle.
Good Luck!! A HELPFUL - 4 THUMBS - rating for this solution would be greatly appreciated. Thank you for using FixYa.
Feb 15, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Door Handle broke off on a 20 year old GE spacemaker microwave over oven. It still works well and I would like to fix the broken door handle.
The door handle can easily be replaced on MOST microwave ovens by removing the inner door panel that goes around the perimeter of the glass. The following link explains how to access and replace the door handle:
http://www.fixya.com/support/r3696942-microwave_oven_door_handle_replacement
The average cost for a replacement handle (if required) usually runs about $20 - $40. Replacements may be purchased at the websites listed in the link I provided.
The door handle is a simple repair that can be done with the door in place, or with the door removed. You do not have to uninstall the oven if this is an over the range model.
NOTE: If you wish to remove the door, all you need to do on most models is open the door all the way and lift straight up at the hinges. You may have to remove the grille cover located above the door on some models to accommodate being able to lift the door.
If you have any questions, please post back with your MODEL NUMBER and let me know. I hope this helps you.
Oct 06, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Our GE Profile spacemaker 2.0 handle is broken. How can I change it?
The average cost for a replacement handle usually runs about $20 - $40. Replacements may be purchased at the websites listed in the link I provided.
May 31, 2010 | GE Profile Spacemaker Over-the-Range...
I have broken handle on the GE Spacemaker Model JVM130H. Can this be replaced and how?
The door handle can easily be replaced on most microwave ovens. You just have to remove the inner door panel that goes around the perimeter of the glass. The following link explains how to replace the door handle:
The cost usually averages about $20 - $40. Replacements may be purchased at the websites listed in the link I provided. However, price and configuration of your oven also depends upon the MODEL NUMBER. If the model number is correct, the part number(s) for a replacement door handle is WB15X10119 and WB15X10120. The door handle on this model has two pieces.
If you have any questions, please post back with your model number and let me know. I hope this helps you
Jan 14, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Broken door handle
The in side door panel ( at total pain) must come off
If the damage to the bottom is not too bad.
On mine I took the cover for the handle loose from the bottom ( it pops off, but be careful).
and put screws at the bottom
Jan 12, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
GE Model Spacemaker Microwave Model #JVM1650WB008 handle broken.
Appliance Repaired: General Electric Microwave
Model: g
Age Of Appliance: 5 - 10 years
took a screw driver and pride off plastic on inside of door. be carfule not to break it. only one of two screws that go into handle were visable. had to drill a hole in metal braket to get at second screw. you can just bend the metal braket back inorder to use drill. bend it back when done. took off handle and replaced it. snapped plastic piece I took off back in place and finished.
ge told me i needed to replace whole door. which they nolonger stock and I could not find a whole door for my model on web. found handlw on this website and did it my self
Mar 26, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
I would like to replace the microwave oven handle.
The inside of the door has a Black Plastic frame about 1 inch wide. This frame can be removed by placing a thin screwdriver between it and the outer door frame and gently (very gently) prying it away from the door. It takes a little wiggling of the frame but it will unlock. On each end of the handle is a philips head screw that holds the handle to the door.
Jan 27, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Bottom of GE interior door microwave is burnt/rusted
just use sand paper to clean the rust then use some high temperature paint (sold in tins) eg spray paint but it must be labeled high temperature and spray 2 to 3 coats . your microwave should be safe again
Nov 17, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
I have a GE Profile Microwave and the handle is broken....
I have the same issue. The Handle broke off my GE Microwave Oven (Model JVM1190SY 001). GE does not sell the handle seperately from what I can tell. I just ordered a new door. It's rediculously expensive. I tried to replace the handle with a nice drawer pull but couldn't find a size pull to match and I broke the plastic cover trying to get access to the screws for the handle, which is why I decided to buy the new door. Hopefully installation is not that difficult. This oven was manufactured in 2001, seems the handles have a 7 year life span.
May 28, 2008 | GE JVM1190SY/WY/AY/BY Microwave Oven
Fixing Microwave door handle
pop the plastic off inside door you will see 2 screws that hold handle on or if your trying to get the door hinges off unscrew bottom panel to access bottom hinge screw and vent at top to access screws for top hinge
Aug 30, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
107 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
