I have an Acer 5601AWLMi, when i boot up with the battery, the laptop is frozen and i can't do anything. Also the battery does not charge. Everything works fine when plugged into the mains. Any help or advice would be greatfully received. Thanks
Thanks patreg, that's what i first thought, but i've turned off the ACPI control driver for the battery, although now it doesn't show the battery status, everything seems to be working fine running on battery power. So now i'm not so sure. I tried reloading the driver too, in case it was corrupt, but that made no difference.
Posted on Oct 01, 2008
  • 152 Answers
You may have a defective battery. It no longer delivers the required voltage to make your laptop work optimally. Some components will not work when those do not receive enough electricity. When you insert the plug to the mains you get the required power to make the components of your laptop work. You may try to remove your battery and plug to the mains. If this works without problems, then you must change your battery.
Bumped my Acer Aspire 5601AWLMi rather hard. Everything froze and after hard booting it will not come on.
Sounds like this is most likely a hard drive issue... You may have scratched your disks with the bump. When you boot up your computer, you should hear a beep - this is your POST (bios startup). If you hear this beep, but the computer does not boot any further, it is almost certainly a Hard drive issue. Some computers don't always play an audible 'beep' but if your computer shows the initial boot screen then goes black, or freezes up during the OS load, you can expect that you will need a new drive. If this is the case and you have experience in a fresh installation of an Operating System as well as experience in installing a hard disk drive into a laptop, then you can buy a new hard drive and DIY. If you do not have experience in these areas, I strongly suggest taking your computer to an expert to have it fixed.
If you don't hear the beep or the initial boot screen never displays, you may have a major issue with the motherboard itself. Either you have dislodged a necessary connection between components or you have broken a circuit. In this case, unless you are a seasoned hardware professional, I suggest bringing your computer to an expert to have it looked at.
Sep 13, 2011 | Acer Aspire 5601WLMi Notebook
Acer Aspire 5602WLMI water in keyboard
Here is a great deal on a replacement keyboard:
To replace it, first of all, remove the power connector and the battery before you do anything on that laptop.
remove the 3 screws in the middle cover. remove that middle cover by putting a screwdriver in one of those holes which are covering the displaybrackets. pull it up slowly. same thing goes for the opposite side.
remove the 2 screws which are holding the keyboard and the cable to the mainboard.
Reassembly is the reverse of dissasembly, be careful with the ribbon cable as its fragile, and there is a little plastic piece that either pulls up or pulls out that releases the cable.
One of the easiest repairs to a laptop there is.
Jul 06, 2010 | Acer Aspire 5602WLMI Notebook
My Acer Aspire 9805 battery was replaced. For
It could be an AC adaptor issue.
It should boot when connected directly to the power outlet through the laptop adaptor. If it is not boot, then the adaptor might not be supplying the needed power to boot it up.
If it is possible, try to isolate the issue. Charge your new battery using another laptop. Then plug it in your laptop to see if it works. If it will work, then it is the AC adaptor of your laptop that is defective. If the charged battery still won't make the laptop boot, then there is something wrong with your laptop hardware. If could be a motherboard issue of your laptop.
Feb 23, 2010 | Acer Aspire 9805WKHi Notebook
Keypad and mouse frozen!
if you have no input device that work, try attaching an external keyboard and mouse
Dont forget to rate the advice.
Aug 03, 2009 | Acer Aspire 5100 Notebook
I have an acer aspire 5601AWLMi notebook and recently installed the windows vista OS and the osd controls for volume controls doesnt work with Fn key. Rest all of the Fn key options work except for the...
WELL I THINK U HAVE A PROBLEM WITH COMPATIBLILTY SO u need to uninstall the lateset driver then u need to clcik right click of ur lastest driver chen check the compatibilty to windows xp sp2 then apply it then try to install it again
Jun 06, 2009 | Acer Aspire 3610 Notebook
Cant power up acer aspire 3690 laptop
did you try booting with just the power cord in (battery and all other devices disconnected) if it boots then put in battery and make sure its charged. then try the video recorder wit out any other devices connected
Dec 25, 2008 | Acer Aspire 3690-2196 Notebook
Acer laptop/all keys and buttons frozen after boot up in any mode.
try to repair the OS using the window xp media centre CD
thank you
all the best
Sep 07, 2008 | Acer Aspire 5500 5570-2609 Laptop
Frozen mouse and keyboard on acer 3100 notebook
acer notebook- froozen keyboard and touch pad.......any help
Jul 01, 2008 | Acer Aspire 5100 Notebook
Acer has stopped!
Are you ableF2 to get to CMOS/BIOS setup? for Acer that's F2 during post.
Jun 16, 2008 | Acer Aspire 5100 Notebook
Computers & Internet Logo
61 people viewed this question
David Payne
David Payne
