Question about Vacuums
Riccar 1500p vacuum won't start
I saw another Riccar vacuum that would not turn on and it had a reset button, I have looked everywhere on mine and cannot find one. Is there a reset button on the Riccar 1500p? or what else can I try?
  • MargoW Oct 02, 2008
    When I looked in the manual -- it said to unplug and leave for 20 minutes which I did, but it still did not work. About an hour later it was working again.
    Thanks
    Problem Solver:
  • 17 Answers
It has a thermal fuse that shuts it down if it over heats. Check the hose , wands and floor tool for blockage and check your bag and filters as well.
Posted on Oct 02, 2008
Riccar r30d I have checked the hose and tried the reset. The bag was just put on and I took it off and put on again. When I plug it in now the lights turn on but nothing at all happens.
When you press the reset button you must make sure to push it in far enough. You may need to use a small tool to make sure you are getting it reset. Your Riccar vacuum is still under warranty. If it is not the reset button I suggest you take it back to your dealer for repair.
Jan 08, 2017 | Riccar Vacuums
Why does the riccar vacuum reset button not depress?
In my experience the Riccar requires reset when it has ingested something that jams the roller such as the fringe of an Oriental carpet. Be sure to clear any such obstruction, then I use a ball point pen to press the button. It does not move very far to accomplish a reset.
Jun 18, 2014 | Riccar 8955 Upright Vacuum
Reset button power
Reset switch is located on the back of the vacuum and close to the back wheels.Press a reset switch a few times and vacuum should start. Check also cord plug . Many times metal prongs are broken at the end of the cord (usually one of them)
Nov 28, 2013 | Riccar 4812 Vacuum
The switch to my Riccar 1500p hose is broken for the 2nd time. I don't want to replace the entire hose again, where can i get the switch and leads?
Take the screws out to take the handle apart. Remove the switch and take it to your hardware or local vacuum to to get the correct replacement.
Apr 03, 2013 | Riccar 1500 Simplicity S24 And S20...
Stopped running. Filter was clogged. Cleaned filter and changed bag, but still won't start. Motor was warm when it stopped.
Hi There,
This sounds like the Thermal Switch in your motor tripped. All Riccar vacuum cleaners have a motor reset switch, that will shut the motor down when it gets hot. Usually it's caused by a full bag, clog, or dirty filter.
Try resetting the thermal switch first. If this doesn't work, you may have done some more serious damage to the motor, and it might be a good idea to take it into a local Riccar dealer in your area.
Here's a step by step guide on how to check the reset switch on your Riccar 8850:
To reset the thermal fuse:
  1. Unplug the vacuum cleaner
  2. Check for problem – over–filled bag, clog in hose, clogged filters, etc.
Remove the vacuum bag, and see if you can visibly see any obstructions, or replace the bag if it's full:
Also inspect the Secondary filter while you have the vacuum bag removed from the machine. If the filter is clogged or dirty, rinse under warm water, and air dry completely before reinstalling it into the vacuum. It's best to wash this filter every 30 days, and replace after 4-5 washings.
Here's a link to the secondary filter on our website if you ever need to purchase one:
Riccar 8800 Series Secondary Filter
Your Riccar 8850 also has a set of exhaust filters that are on the front of the vacuum, near the bottom where the upright body meets the agitator housing. These filters when clogged may also cause the thermal switch to trip. These filters are recommended to be replaced every 6-12 months, and are not recommended to be washed.
Here's a link to 2 sets of the exhaust filters for the Riccar 8850 on our website:
Riccar 8850 Exhaust Final Filters, 2 Sets, 4 Total Filters
It's also possible that you may have clog in the suction port inside of the agitator housing. Remove the bottom plate from the vacuum, and look for the tube that runs on the left hand side from the tray to the rear of the agitator housing. Make sure that this tube is clear from obstructions:
Locate "tripped" fuse – the small white button located on the bottom of the back side of
the main body (roughly one inch to the right of the left wheel)
Using a pencil, paper clip or other pointed object, push the reset button in, you should hear a clicking noise when it resets.
Plug the vacuum cleaner back into the wall, and try turning the vacuum on. It should come right back on. If not, it's best to take your machine into a local Riccar authorized repair facility for further more advanced diagnosing.
Please feel free to ask any follow up questions by adding a comment to this repair, I'm always more then happy to answer any and all follow up questions if you need some clarification. If this was helpful, please rate the repair helpful or leave some feedback for me. Thanks so much,
Chris Jones
Govacuum.com
May 22, 2010 | Riccar 8850 Vacuum
Where is the reset button on the Riccar 8995
The reset button on the Riccar 8955 is located on the back of the vacuum cleaner, at the very bottom, right above the rear wheels. You can push the reset button with a ball point pen or something similar.
Feb 15, 2010 | Riccar 8955 Upright Vacuum
Where is the reset button located?
Greetings from GoVacuum,
The reset buttons on the Riccar vacuum cleaners are located at the bottom of the vacuum cleaner in the back, underneath of where the wand sits on the vacuum cleaner.
Here's a picture of a Riccar 8925 which replaced your 8850 a few years ago, but the reset switch will be in the same exact location on all Riccar uprights;
Here's a closer look of the reset switch;
I hope that I was able to answer your question. You can avoid the reset switch flipping in the first place by always ensuring that you change the bags frequently and when full, as well as the motor filter that sits underneath of the bag. Also keeping the vacuum from clogging will prevent this.
If you found this repair solution helpful to you, may you please click the 4 Thumbs Up Icons in the top right hand corner to help me out here on Fixya? I really do appreciate it, thank you so much.
Chris
GoVacuum
Jan 15, 2010 | Riccar 8850 Vacuum
Replacing power cord. How does cannister come
I found the hidden screws under the cord rewind and power buttons.
Oct 09, 2009 | Riccar Vacuums
Riccar 8750
I have an 8625 and the button is now white not red. Probably fadded. Thanks that was the reset button and it solved my problem.
Oct 23, 2007 | Riccar 8650/8625 s Vacuum
Vacuums Logo
668 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
