Question about Maytag Neptune MAH5500B Front Load Washer
Water is not draining
I can hear the pump running but the water is still in the washer
  • 943 Answers
Hi .thanks for the question .the problem is with the pump. could have a piece of clothing caught in the hose .check that .thanks the appliance doc
Posted on Oct 01, 2008
Didn't drain. Won't spin.
Hi Kat, let's see if I can help your with this. The washer will not spin when it senses water inside so we'll start first with the drain. When the machine was finished washing, did you hear the drain pump attempting to discharge water? Try selecting the "Spin Only" or "Rinse and Spin" cycle, you should be able to hear whether or not the drain pump is attempting to operate. If you do hear it running, but the water is not draining, it is possible that the drain filter is clogged. If you need instructions on how to clean the filter let me know. Otherwise, we'll move to the next step.
Mar 07, 2015 | Samsung WF203ANW Front Load Washer
Nd error code, what does this mean
ND stands for No Drain.
It means that either your drain is plugged, the piping inside your washer to the drain pump is plugged, your pump is damaged, your control panel is damaged or a combination of the above.
If you can hear your drain pump operating, you should check for blocked piping. If you have water in the washer, unhook your washer hose from the back of the washer and lower down to the floor to see if water drains from your washer. If little water runs out there is a good chance that the hoses inside your washer are plugged with something. If water runs out freely, then there is a problem with your pump that will not allow it to pump water up to your drain hookup.
Oct 04, 2014 | Samsung WF220AN Washer
How do you get the water to drain in the Malber WD100 washer/dryer combo?
Hi. I''m assuming you are referring to a WD1000.
To initiate the drain cycle: Rotate far right knob CLOCKWISE to Position 4. It may take 30-45 seconds to recognize the knob's new position, but then it will begin an 11 minute Slow Tumble/Pump Out cycle. During this cycle you'll see the internal drum slowly rotate CW for 60 seconds, pause, then rotate CCW for 5 secs - then repeat. All this time the pump will run and you'll hear water running down the drain. When you hear no more water you can rotate same knob to "straight up", and stop the machine. To turn power off, press the rightmost button.
Sep 21, 2014 | Malber WD1000 Front Load Washer/Dryer
Washer wont drain showin IE
Sonia, you either have a failed drain pump, or something has bypassed the filter ( bobby pins are notorious for this ) and is jamming up the pump impeller. If you can set the washer to drain/spin and can hear the pump running, you most likely have a impeller that has broken off of the pump motor shaft and will need to be replaced. If you cannot hear the pump running, and can hear a slight humming noise, then there is something jammed in the pump. The pump can be removed and cleared of the possible foriegn object. I can provide instructions on pump removal if needed.
Apr 20, 2014 | LG Tromm Front Load Washer And Dryer Set
Washer WPSR3100WOWW Will wash but not drain and spin... Stops at the rinse Cycle
Christina,
Does it leave water inside the tub? There are a couple of possibilitys. One could be the drain pump. If this fails the wash/rinse cycle will stop as it can sense the water not being pumped out. Can you hear the light sound of a small motot running when it goes into rinse cycle? Listen down at the very bottom far right side or far left side. If you hear the drain pump motor running is there any water discharging out the drain tube going into the wall? You should easily hear the flowing water. If not you have a few possible problems: Drain pump has an obstruction in or around it or, drain pump is actually bad.
Oct 12, 2013 | GE WSXH208A Front Load Washer
I have an affinity washer and dryer. The last loand did not complete its cycle. It is partially full of water, but not enough to seap out. Itmakes a buzzing sound and will not spin. It is not the type of...
It sounds like the drain pump has stopped. If it still has water in it and you turn it on (in the spin only cycle) the drain pump should be running and you sould be hearing the water drain. The washer will not spin until the water is out. Depending on how handy you are determines whether you can access the drain pump and remove the obstrustion. There is also a trap to catch debries from going into the pump. This could be plugged, but normally you don't hear a buzz. You hear the drain pump working but no water going out. Good luck
Apr 23, 2011 | Frigidaire Affinity ATF7000E Front Load...
The washer filled with water and started washing but now it won't drain, the knob keeps going and then just turns off but the water won't drain..what should I do?
Do you hear the pump run when it is supposed to? If not, then the pump may need to be replaced (warranty?). If the pump runs, but nothing comes out, lower the drain hose to a pan or bucket on the floor to see if water will run out under gravity. If water does come out, the pump may be defective (the impeller in the pump is loose on the motor shaft). If nothing comes out of the drain, look for a pinched drain hose or the hose from the outer tub to the pump. It may also be an obstruction in the drain connection at the tub connection (a stray sock or similar). Hope this works!
Mar 16, 2010 | Tecnik TKL9260 Front Load Washer
Suds or blocked pump is a message popping up. the door to the front washer won't open as it says the water level is to high.
let it rest a while so suds can disappear then unplug the unit for 1 min then plug back in it should drain by its self if not do not select wash cyc but a spin/drain then you should hear the pump running if you don't hear the pump running you can get a wet/dry vac stick on the drain hose and empty the washer that way if water not come out you have to axcess the pump and pinch off the drain hose from the tub and remove the object from the pump be careful that you don't have a mess with water leaking from the tub good luck
Aug 27, 2009 | Bosch Nexxt Premium WFMC6400UC Front Load...
Water runs during final spin cycle
You have a blockage in the drain pump. Remove the front panel to access the drain pump.
Bail the water from the tub.
Remove the hoses on the pump and clean out the lint or garment from the pump.
Mar 26, 2009 | Frigidaire Washing Machines
Draining
if you select drain spin and you hear the pump running then check all the hoses for blockage if you dont hear the pump running then make sure your door is locking
Jan 19, 2008 | Maytag Neptune Washer
Maytag Neptune MAH5500B Front Load Washer Logo
24 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
