Question about Ionic Pro TURBO Air Purifier
No clean air smell/crackling & static
Bought the pro turbo in July 08 worked perfect until 4 weeks ago. Crackling and static and no clean air odor. Called customer Service and was told to soak the blades for 20 min, etc, and 3 days later should have no problem. Problem slowed down but still no clean air odor and crackling. Shut it off at night and when put back on sometimes clean air and most times not. On hi all the time, and I have to get down to the unit to smell the clean air. I'm cleaning the blades every day. I called them today again and now it's going to cost me $29.95 to return it plus shipping to get another unit. Can't find a tel # to call the co. direct. Very unhappy, & cranky.
  • ptas375 Oct 05, 2008
    My ionic pro turbo have a crackling/static sound and I'm afraid it may catch on fire when I'm not at home. I have cleaned this numerous times and it still makes this noise. I bought this in December 2007 and loved it because den
    smelled so cleaned. After about 3 months it started making this noise and it doesn't seem to work like it did when I first got it. What do I need to do to get it back working like it should. I haven't used it for several months but since winter is coming I would like to be able to use it.
  • higle75 Oct 10, 2008
    I've had this thing for less than a month, and it's already crackling static. Like another user said, the static's so bad I'm afraid the thing will catch fire if left alone. It's supposed to last a long time between cleaning. What a piece of junk!
To stop the crackling sound, you need to remove all of the dust particles from the wire in the back. Sometimes when the unit is extremely dirty you can see sparks emanating from the wire, this is what causes the crackling sound. The unit has a built in cleaner you can lift up and down to perform this task, located on the top, but this doesn't work extremely well.
I usually take a can of compressed air and blow as much of the dust I can off the wire and all surrounding internal areas as I can. This along with a thorough cleaning of the blades should eliminate the crackling noise. Of course, make sure the device is unplugged before performing any cleaning.
Not sure about the smell though. Mine has started to smell a little strange and I haven't figured out how to fix that problem.
Posted on Nov 28, 2011
Where is the ionizer wire?
On the opposite half as the plates. Look for but don't touch the big insulator at the top. The wire run from it to the bottom of the machine. Older ones have a cleaning bead and you must turn the entire machine upside then right side up several times to clean it. Mine had a latch on the back top with a label, " pull up to clean if crackling". I pulled it up and observed a wiper sliding up the big wire inside. I did it up and down several times and that fixed mine.
Jun 23, 2014 | Ionic Pro TURBO Air Purifier
Crackles even after blades are cleaned
I usually take a can of compressed air and blow as much of the dust I can off the wire and all surrounding internal areas as I can. To do this, approach the unit from the front, and turn the blade door slightly so the wire can be seen. This along with a thorough cleaning of the blades should eliminate the crackling noise. Of course, make sure the device is unplugged before performing any cleaning.
Oct 19, 2011 | Ionic Pro TURBO Air Purifier
My Ionic Pro keeps making a static-y noise when turned on. What is causing it and how can I fix it?
Hi jackieelling,
I work for the Ionic Pro company. Make sure you are also cleaning the ionizing wire. If that does not help, please call customer service at 800-875-8577 and they will be happy to assist you. Thank you, Mary
Feb 05, 2011 | Ionic Pro TURBO Air Purifier
I have cleaned the blades but it keeps telling me I have to clean it and will not work.
Hi mystic9491,
I work for the Ionic Pro company. Make sure you are cleaning the ionzing wire too. Is that does not work, please call customer service at 800-875-8577 and they will be happy to assist you. Thank you, Mary
Feb 03, 2011 | Ionic Pro TURBO Air Purifier
Why does my ionic pro turn off for 2 seconds and demand to be cleaned even though it's been cleaned and dried and reset correctly?
I work for the Ionic Pro company. Please call customer service at 800-875-8577 and they will do some troubleshooting with you. Thank you, Mary
Dec 27, 2010 | Ionic Pro TURBO Air Purifier
My ionic pro turbo air purifier keeps buzzing even after I clean it
Hi lsalazar113
I work for the Ionic Pro company. Make sure you are cleaning the ionizing wire too. If that does not help, please call customer service at 800-875-8577 and they will be happy to assist you. Thank you, Mary
Dec 19, 2010 | Ionic Pro TURBO Air Purifier
Ionic Pro TURBO Air Purifier Logo
736 people viewed this question
Top Ionic Pro Air Purifiers Experts
Paul Cox
Level 1 Expert
Shehu Pro
Shehu Pro
Thomas Perkins
Thomas Perkins
Are you an Ionic Pro Air Purifier Expert? Answer questions, earn points and help others
