How do you use sandisk cruzer mini 256mb - Computers & Internet
  • 35 Answers
Your problem is how to use pen drive
PEN DRIVE WITH DATA CAN BE INSERTED INTO AVAILABLE TYPE OF USB PORTS ON YOUR COMPUTER .
THE SYMBOL OF THE PEN DRIVE APPEARS ON YOUR MY COMPUTERB WINDOW .RGT CLICK .OPEN.Product Description
The Sandisk Cruzer Mini is a truly portable, truly useful pocket size data storage device that happens to look cool as well. Its stylish, diminutive design can be slipped into a pocket or purse for easy transport or data files, image files, video and audio, between home or office and virtually anywhere else. Fully compatible with Windows 98SE, ME, 2000, XP and Mac OS 9.1+, OS X v.10.1.2+
Posted on Oct 02, 2008
Can one old (greenhorn) load an opera mini on one scandiskcruzermirco (8GB)??
yes an old greenhorn can load an opera mini if its a program of less than the size of a cruzers capacity 8 gb
click start all programs accessories open windows explorer navigate to your opera mini files right click on the music right copy navigate back to the destination/cruzer drive right click select paste or hold the mouse cursor on the opera mini files drag them to folder
then drop them
or if you are downloading photos from the internet
once it starts downloading windows will ask whether you want to run or save it
a browse option will open you can save it into a folder in my documents or another
device floppy or a usb device
hope this helps
Aug 17, 2011 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
When I insert the USB it reads error 23. How do I solve this
  1. Copied all the files that came with the Sandisk device to another location (in case I need them again)
  2. Copied all the music I had put on the Sandisk since I got it to another location
  3. Using a Windows PC, I right clicked on the drive in Windows Explorer and selected "format"
  4. I re-formatted the cruzer mini to FAT 32, default size (yes, I know it was FAT 32 already)
  5. Copied the music back to the cruzer mini
  6. Plugged it into my radio and it works GREAT! instant access to any track
Before you do this: Reformatting the drive also gets rid of the software that makes the cruzer mini copy files super fast. It will take a lot longer to copy music to the drive
Dec 16, 2009 | Vehicle Parts & Accessories
I just bought a new computer and I need to transfer files
A SanDisk Cruzer Mini is a memory stick, like a modern floppy disk. Plug it into a USB port (a thin rectangular hole) - it may be at the back of your computer. Your computer should then recognise it and you can copy files onto it.
May 06, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Attaching Neck Strap to SanDisk Cruzer Mini 1.0 GB
There should be two holes to thread the neck strap through. I believe you have to loop them in a certain way so it stays there.
Jan 28, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Cruzer mini 2 gb
There is no drives required for detackting the drives it automaticaley it detact so please check the usb port are fit in your system.
Jul 22, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
I have a cruzer mini 256MB. After a long time of working fine it now is recognised as a ADIR ROM device and i cannot get to the data. How can I fix this or get it repaired ?
I just expereienced this same issue and this is what I did to resolve.
Step 1. Back up your registry.
Step 2. Look and see if you now have a key called HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Enum\USB\Vid_0781&Pid_1234 and a key called HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Enum\USB\Vid_0781&Pid_5150.
Step 3. Delete Both (Note the the latter is the one for your Cruiser but you should start fresh.)
Step 4. Reboot (Make sure you don't have the flash drive plugged in.)
Step 5. Once logged back on, install the flash drive. It will still go thru the routine of hardware1.gif discovery but most likely will not work correctly. You should notice that the key HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Enum\USB\Vid_0781&Pid_1234 is back but the later is still gone.
Step 6. Change the following keys to the values indicated..
HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Enum\USB\Vid_0781&Pid_1234\12345678
DeviceDescrip FROM ADirRom TO Sandisk Cruzer
LocationInformation FROM ADirRom TO Sandisk Cruzer
and ADD the Following
Driver {36FC9E60-C465-11CF-8056-444553540000}\0013
Service USBSTOR
Step 7
Remove the drive and reinstall. If you are as lucky as I, you may still get an initial message about can't find a driver for the Adir, but then the hardware detection will start anew and correctly recogize as a Cruiser Mini.
Mar 20, 2008 | Computers & Internet
I formatted my 2.0 cruzer mini usb drive
Hi lapigota,
I'm not sure what your question is here. Please go into detail and we can help you out.
Ben
Feb 29, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Can no longer save to SanDisk Cruzer Micro 256MB
First, have you tried it on another computer? Basically, narrow down the problem- is it the SanDisk, or something with the USB ports on your machine? Assuming it is the SanDisk, try formatting it. You should be able to format it under Windows Explorer...properties... Or, go into Control Panel... Administrative Tools... Computer Management... Disk Management If you had files on it- they will probably be history. You could Google for recovery utilities, but such getting your files is doubtful. Hope this helps!
Jul 24, 2007 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Computers & Internet Logo
113 people viewed this question
David Payne
David Payne
