there are many cracks in the stucco covering the outer walls of my house causing rain water, pushed against the walls by the wind, to drip on the back of the drywalls and enter the house from the bottom under the baseboards.
i had gutters and downspouts installed but it didn't help.
i would like to paint the stucco, which now has a natural color finish, with a waterproof paint. i've been told by a friend (not an expert in painting) that he thinks that the process involves applaying first a "base coat" for the waterproof paint to stick to the stucco, then applay the "waterproof" paint which i understand is very thick and finally applay a "sealer" to protect the waterproof paint color against fading since i live in florida. by the way, the present stucco faded after only few years. its color is light yellow and will only one coat of a darker yellow be enough. the house was built 8 years ago and there were no expansion joints installed.
please, i need advice on how to do a good and lasting job.
also, what are the types and names for the "base", "waterproof" and "seal" paints and the recommended name of a company that has developed such types of paints.
finally, how to apply (spray, brush, roll), the approximate amount of square feet a gallon will cover, and the cost of each "base", "waterproof" and "seal" paints's type.
thank you very much. sam
-   I have the exact same problem here in New Orleans. My stucco
Spanish style house was built in the 1940s and the stucco is leaking in
lots of places. I do not have the money to replace the whole
thing so I want to waterproof the old stucco. Is this
doable? Could I replace the bad stucco with stucco-style
hardiboard and make it blend in with the old stucco?
-   AngieRlly
I'd try sealing the cracks first then priming... check with your local Home Depot type place and see if they have any ideas... also it doesn't hurt to just call the experts... sometimes you get that one guy who is willing to tell you WHAT you can do...
If the cracks are NUMEROUS.... then you may need a full re-do of the whole wall. especially if you have internal water damage. you should also ask about interior wall sealing.. there is supposed to be a plastic seal between the outside and inside no matter what your exterior finish is.
I bought a display unit of a Tradesman 10" compound miter saw, model #2124014. It didn't have...
(More)
I bought a display unit of a Tradesman 10" compound miter saw, model #2124014. It didn't have a manual, and the store says they don't have one and can't order one. I've tried to find one on line with no luck. Also, where can I get a dust bag for it?
warped fence. Bows so when you lay the straight board accross there is a gap where the blade comes...
(More)
warped fence. Bows so when you lay the straight board accross there is a gap where the blade comes down. No Idea how this could become warped.
I am trying to connect battery cables for an electric start to my EQT tg 5000 generator. I have...
(More)
I am trying to connect battery cables for an electric start to my EQT tg 5000 generator. I have misplaced my maual.I can't pull up the companies web site to get a pdf manual. The company is called eastern equipment and tools.
