Question about HP Computers & Internet
I HAVE A 22"HP MONITOR WITH 1680 X 1050 RESALUTIONS.IT'S ONLY SHOWING 1280 X 960.HOW DO I GET IT TO 1680 X 1050?
  • 158 Answers
Check the cd that comes with your monitor and install it and change the resolutions or check the display drivers that installed properly
Posted on Oct 01, 2008
How to fix
tried to hooked up with other monitor just to ensure if the cause is your pc. if the monitor doesn't receive signal it will goes to stand by mode.
Sep 07, 2012 | HP W2207H 22-inch Widescreen LCD Monitor
All my characters are showing shadows is this a problem with the monitor or with the computer?
Hook a spare monitor to the computer, if okay! the problem is in the HP monitor. Now if symptom is the same on both screens, the Video Graphics Card is defective. Last thought replace the video cord from the computer to the monitor just to be sure.
Apr 03, 2012 | HP w19e 19" Monitor
Dual Monitors - why does my second monitor have bad picture?
As long as something isnt broken, using the HDMI and the D-Sub should be fine. From your fuzzy pictures I suggest that you want to double-check your cables.
Have you tried to switch it? If you put the second monitor on the D-SUB and the picture is still faulty, its very likely the problem is your monitor.
Dec 29, 2011 | LG 22" FLATRON LCD Monitor
I am in charge of a computer account here at work and have about 15 ACER 1916B monitors that are all inop...The monitors power up and show the ACER startup then show the windows startup to only go...
This problem is caused by 2 things, the computer is set to a higher resolution that the monitors can handle, so when the graphics card drivers kick in as windows boots the screen goes blank, this is normally the problem for people trying to hook there computers to normal lcd televisions not monitors, as monitors generally are able to show higher resalutions.
In your case because you are using computer monitors, the problem will be caused by the refresh rate settings on the windows, most desktop lcd monitors have a fixed refresh rate of 60hz, my guess is your computers are set as 75hz therefore as windows boots the screen goes blank because it dosent support that high a refresh rate.
To resolve this problem, just before windows boots press F8 on the keyboard, this should bring up a black command prompt screen, at the top you will see the safemood option, tab up to it and press enter, this goes to windows but dosent load any drivers including the graphics driver. Once loaded right click the mouse in the middle of the screen, and bring the display properties window up, in this window click on the settings tab, click on advanced on the bottem right of the window, this will bring up another window, click on the monitor tab, on this window you will see the screen refresh rste setting, click the small arrow and set this to 60hz and click ok, in the other window reduce the resalution down abit using the slider, click apply and close the window, then reboot the mechine as normal, the problem should now be sorted, any problems post me back. thanks and hope this helped.
Sep 22, 2010 | Acer AL1916W 19" LCD Monitor
When i turn my monitor on it shows no picture and it makes a sound like it is running the electricty went out and when it came back on thats when the trouble started thank you
It's time to spend $100 to buy a brand-new 19-inch LCD monitor,
or $200 to buy a brand-new 22-inch LCD monitor,
rather than paying a TV/CRT technician $50 to $75 per hour to try to fix the "antique" monitor.
Aug 05, 2010 | HP Compaq P 1220 (Carbon, Silver) 22" CRT...
No sound, checked control panel, all shows the
No sound, checked control panel, it shows all sound at the max.
Feb 25, 2010 | HP 22" Widescreen Flat Panel TFT LCD HD...
Screen is black. Power lignt is on. Mouse works.
Does it make a difference in Safe mode? Its Possible that your monitor or vidio are out of range Safe mode (f8) on botting will boot with the bare system settings, if safe mode works then reduce the resalution, Color and Possibly the monitor refresh rate
Nov 02, 2009 | Samsung SyncMaster 540N 15" LCD Monitor
When i goto cyberlink youcam i only get part of the screen
CHECK YOUR VEDIO DRIVE OR I MEAN THE MONITOR RESALUTIONS ON THE SCREEN, YOU WAND 32 OR 64 BIT ANY SIZE.
ROD
Feb 09, 2009 | HP Computers & Internet
Computers & Internet Logo
42 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
