Question about Electronics - Others
RV Generator Power Cutting In and Out
We have a 1997 Safari Class A with an Onan 6.3 propane genset. Latelywhen we have been running it, certain appliances will lose power andthen regain power. It's mainly been the microwave and kitchen outletthat we've noticed. Sometimes while using the microwave, we've had itshut off 5 or 6 different times, but it's always regained power shortlyafter.
But today the microwave/ kitchen outlet will not poweron when the genset is running. It has power from the inverter, but assoon as the transfer switch cycles power to the gen, we have no powerthere.
The funny thing is that we still have power in otherplaces. The fridge runs on shore ,and I can even run both AC units, butstill nothing to the micro.
I've checked the genset breakers, main breakers, and any fuses I could find and still nothing.
Any ideas?
From what I can tell we have 2 GFCI outlets, one in the kitchen and onein the bathroom. The kitchen outlet is the one that is not working whenthe generator is on.
The test button on the outlet in thebathroom will not work until the generator is on, then it will test andreset and the outlet will work.
The test button on the outletin the kitchen works correctly and resets when the inverter is on, butwhen we turn the generator on, the test button no longer works andthere is no power.
I'd say you probably have to have the gfi receptacle replaced. The gfi recepts can be pretty touchy sometimes. The test and reset buttons sometimes stick or do not reset due to just being old and not used very often. I am an electrician and we see this alot. I try and test mine often as I can remember to do it. If you are not qualified or experienced with this type of work please find someone who is. If you do attempt the change out, just please do it with the power to the outlet off!! Be careful around electricity! Good luck, I hope you find the right solution!
Posted on Mar 12, 2009
What is the point gap for model:CCKA-S/25830?
Spark Plug # RS17YX for Onan 167-0272 on RV Gensets ...
www.partsfortechs.com > Home > Generator Part
Generator Parts Spark Plug # RS17YX for Onan 167-0272 on RV Gensets ... for this plug require the spark gap to be set at .025" (25 thousandths of an inch).
Onan Gen HGJAB What is the best spark plug and gap? - Heartland ...
https://www.heartlandowners.org/.../39632-Onan-Gen-HGJAB-What-is-t...
Jun 8, 2013 - 3 posts - ‎3 authors Also what is the the correct gap on the plugs? ... brands · Generators; Onan Gen HGJAB What is the best spark plug and gap? ... Gap: 0.025
Nov 04, 2015 | Watts Onan Portable Generator - 4000 ,...
My onan emerald 1 genset is not transfering charge to the battery
Assuming your generator has the battery charger option?
Measure the battery voltage at the battery lead in the generator, without the unit running, or the motorhome ignition on. It should read approx 12V after the unit has been sitting a while. Then start the generator, it should rise to approx 13.8 with a good battery. If it does not then the stator windings and charge rectifier in the generator should be checked. If the voltage is 13.8 approx with the generator then you problem lies further upstream, and possibly with an isolation solenoid. If you generator does not have a battery charge winding/option then charging comes from the line voltage via a motorhomes inverter, check the inverter.
Sep 08, 2012 | Onan RV QG, 2500W GenSet, LP Gas
I need a manual for onan 6500 lp genset
You can buy a service and or operator manual from advanced-power-technologies.com
Aug 13, 2012 | Onan Cummins RV QG 6500 Generator, 6500W,...
On my 9 hp onan genset it runs fine but the 20 amp breaker on makes it shut down is there short or abad breaker
To determine if it is from the breaker use a
Tong Tester
These would indicate what current is being consumed by the load.
Jun 28, 2012 | Watts Onan Portable Generator - 5000 ,...
I have a Onan 7000 genset in my rv It starts and
Either you have a kill wire ( if I remember it is the brown wire) that is disconnected on one end or the other Or your in coach switch is bad.
Check the switch this way
Remove the switch from the dash/ mounting surface unplug the brown wire - start the genset - ground the brown wire - it should kill the motor
If it kills the motor your switch is bad
Mar 07, 2010 | Watts Onan Portable Generator - 5000 ,...
Onan Marquis Indiana 5000 generator
You MAY have blown the rotating diodes on the rotor.
This would require servicing.
Sep 05, 2009 | Yamaha 4500 Watt Electric Start Generator...
Onan genset generator in rv is running but no power to rv...circuit breaker has been checked and main breaker in rv has been checked still no power
on your generator ther is a reset if thats not it check for fuses if still no then u neda check the wires in the pluges if no then ur generator it self needs re bilt
Aug 29, 2009 | Watts Onan Portable Generator - 4000 ,...
6.5 RV Onan generaotr wont kick in when loaded. checked automatic transfer switch and excited it manually, worked one time but never again,
1. Does the generator stay running when you start it the first time?
2. What color is the housing on this generator? Try to get the model number and serial number.
If the genset is shutting down on the first try, then your probably not creating voltage. However, if this is an older unit then the genset may stay running although no voltage is created. Place a volt meter on the genset to check for output voltage.
Mar 08, 2009 | Watts Onan Portable Generator - 5000 ,...
Onan microlite 4000 generator no output
Hi, The 4000 rv unit unit is equipped with full diagnostics, and is indicated by the status light blinking. The blinking sequence, blinks a code as to the fault. If your unit runs and the status light is on without blinking, it is either the circuit breaker on the genset or in your distribution panel that needs to be reset. Good Luck, this should Fixya!
Mar 02, 2009 | Watts Onan Portable Generator - 4000 ,...
Electronics - Others Logo
201 people viewed this question
Top Electronics - Others Experts
Brian Sullivan
Brian Sullivan
Are you an Electronics - Other Expert? Answer questions, earn points and help others
