Question about Brother LS-2125 Mechanical Sewing Machine
Tangled bobbin When sewing the thread in my bobbing gets tangled I assume because when I remove my material there are two extra threads that have been sewn into my machine. I have tried numerous times and the same thing happens over and over again.... Any advice?
  • dianelutz Oct 17, 2008
    When I TRY TO SEW THE BOBBIN TANGLES
  • 3 Answers
Are your bobbins wound tight? allso do you have dust caught in the bobbin case at the bottom of your machine?make sure and clean out all bits of dust and fabric. as this will cause problems like this one.
unscrew the needle plate. dust it all out. allso use a small lcoin to unscrew the sewing plate. saves time.
Posted on Oct 26, 2008
I keep getting error E6 on Brothers CS 6000i- I cleaned the thread several times and when I try to restart sewing it happens again. I've removed the bobbin and re-threaded and it keep jammin and beeping....
The motor locked up because the thread is tangled.
Solution:
Remove the tangled thread before continuing the operation.
Clean the bobbin case to remove the tangled thread.
After cleaning the bobbin case, insert the bobbin case properly.
If the needle is bent or broken, replace the needle.
Then, thread the upper thread properly, and continue the operation.
Dec 21, 2013 | Brother CS-6000i CS6000i 60-Stitch...
My bobbing thread keeps jamming
Make sure you are putting the bobbin in right side up. Some times it will do this if your needle size is incorrect to the fabric weight.
Jan 13, 2013 | Janome Sewist 500 Sewing Machine
Lower bobbin thread gets tangled
try changing the needle --make sure the needle is the right one
for the fabric being sewed
try a different thread
make sure the bobbin is not over filled
make sure the bobbin is turned the right way in the bobbin case
make sure the thread has not come off the thread take up lever
Oct 04, 2012 | Brother XL-3500
Machine is showingE6
The motor locked up because the thread is tangled. Remove the tangled thread before continuing the operation.Clean the bobbin case to remove the tangled thread. After cleaning the bobbin case, insert the bobbin case properly. If the needle is bent or broken, replace the needle.Then, thread the upper thread properly, and continue the operation.
brother sewing machine
Sep 22, 2012 | Brother CS6000i Computerized Sewing...
Top thread tangled in bobbin.
try changing the needle---flat side goes to the back side of the machine
also check the top tension
depending on the fabric your sewing on--the needle & thread have to work
with the fabric--example light fabric needs a different needle & thread than
a heavy fabric
check to see if the thread is coming off the thread take up lever when you
sew.
Apr 04, 2012 | Singer 8280 Mechanical Sewing Machine
Thread is tangling on the lower bobbin
check the needle first.Bent or spurred needles will result in this action.
May 30, 2010 | Brother XL-3510 Mechanical Sewing Machine
Thread tangled in the bobine
I had this same problem yesterday. I took apart the needle tension casing and now it doesn't get tangled or stop. The only thing is the bobbin is not sewing...it looks fine on the top, but the bottom is just loose loops.
Jan 17, 2010 | Singer 3116 Simple
Thread breaks
Hi!
Check to see if the lower thread be tangled. Also, the bobbin could be threaded improperly in the shuttle hook. Rethread the bobbin in the shuttle hook.
How to detangle a thread---
  • When a machine stops operation due to tangled thread, do not turn the pulley by force.
    If the pulley is turned by force then, lower thread might not be picked up correctly and stitches might not be formed correctly.
  • If threads get tangled, remove a needle plate and cut the tangled threads by scissors or cutter.
  • Do rate the solution if you find it helpful & useful.
    Thanks
    Rylee
    Jan 30, 2009 | Husqvarna Viking 1
    Upper thread getting tangled in the bobbin
    Always remember T-N-T. Thread, Needle, Tension. Assuming its threaded properly, is the needle all the way in and facing the right direction? These symptoms also suggest the bobbin may be in the bobbincase upside down thus turning in the wrong direction. Hope this helps.
    Aug 21, 2007 | Euro-Pro 416 Mechanical Sewing Machine
    Needle Thread and Bobbin Thread
    This is a timing problem and will have to be repaired by authorized dealer.
    Jun 18, 2007 | Euro-Pro 373 Mechanical Sewing Machine
    Brother LS-2125 Mechanical Sewing Machine Logo
    85 people viewed this question
    Top Brother Sewing Machines Experts
    Bargain Box
    Bargain Box
    Irene Tulloch
    Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
