Question about Gateway GM5048 (6304) PC Desktop
System recovery for Gateway GM5048
I had to do a system recovery, everything seemed to go well, but it never finishes loading drivers. Can NOT having the original speakers cause the recovery not to complete?
    Sergeant:
  • 268 Answers
No that should have nothing to do with it......
What I can recommend is manually installing the drivers rather then going through the entire recovery process again. All of the drivers that you would need you can find here :
http://support.gateway.com/support/drivers/search.asp?st=pn&param=6153
If you need help with anything more specfic feel free to leave a comment here and I can give you some more help!!
If you found this helpful , please leave a rating...thanks!
Posted on Oct 01, 2008
Gateway NV5105u Laptop. I have the Windows 7 disk. There is no recovery partition or drivers, I receive error & I've tried Diskpart to create a partition and I get a message no disk partition found.
My advice in this isn't expert.
I seem to remember when I loaded Windows 7 I was given the option to create a recovery partition. I didn't take that option and suspect whoever loaded your operating system also didn't.
I think your best option is to format the drive and reload everything. Formatting is best done by removing the drive and formatting with a separate computer.
Feb 08, 2016 | Gateway Computers & Internet
NEED RECOVERY DISC
You maybe be able to get a Recovery CD for your model computer from the Gateway WEB site.
May 15, 2012 | Gateway GM5048 (6304) PC Desktop
Gateway laptop reset
Gateway Direct systems went "media-less" back in September 2004. In the event of a system crash users could either 1) restore their systems from the Recovery Partition OR 2) from the backup media that they were prompted to create on first power-up -- which would provide them with up to 5 blank CD-R discs depending on their system's configuration.
On the factory load of the hard drive, the recovery partition will not contain operating system files. It only contains application and driver files.
The first time the recovery partition is used, it prompts the user to insert their System Recovery CD/DVD to copy files from the CD to the recovery partition.
The Drivers and Applications CD is not bootable and does not contain Operating System files.
The System Recovery CD/DVD is bootable but does not contain any application or driver files.
If the end-user erases the hard drive and restores the computer using the System Recovery CD/DVD and an Applications and Drivers CD, the recovery partition is not recreated.
This means that you will need the operating system restore disc FIRST then the recovery partition will work for you
Mar 14, 2010 | Computers & Internet
I didn't get a disk to restore to factory in the box. Do I need to buy that seperate, from the factory?
Here's the support page from Gateway for your model.
http://support.gateway.com/s/Mobile/2009/Ajax2/MD26/MD26nv.shtml
And here's the user guide link (which you can find at the page mentioned above)
http://support.gateway.com/s/Manuals/Desktops/8513015.pdf
and below are the steps from the user guide which to me seems like the solution for your question.
To create discs, click (Start), All Programs, Gateway, then click Gateway Recovery
Management. To create recovery discs for your factory-loaded hard drive contents (Windows
Vista, pre-installed software and drivers), click Create factory default disc or, to create recovery
discs for only the factory-loaded drivers and software, click Create driver and application
backup disc. Follow the on-screen instructions to finish.
Dec 19, 2009 | Gateway MD2614u Notebook
I cant get my gateway mt3705 to format,only three options setup available for boot menu,boot seq,setup and psx boot menu..no recovery disc either what do i do?
To delete everything on your hard drive and re-install all factory software: 1 If you can still run Windows: a Click Start, All Programs, Gateway Recovery Center, then click Gateway Recovery Center. The Gateway Recovery Center opens. b Click Recovery, then click Next. Your computer restarts. - OR - 2 If you cannot run Windows: a Turn on or restart your computer. b While the computer is starting up, repeatedly press F8 until the Recovery Options screen opens. If Windows starts to load instead, restart the computer and try again. 3 Press the arrow keys on your keyboard to select Repair Your Computer, then press ENTER. Gateway System Recovery starts, and the System Recovery Options dialog box opens. 4 Select a language and keyboard layout, then click Next. 5 Click the User name box to select a Windows user account, click in the Password box and type the user account’s password (if any), then click Next. The System Recovery Options menu opens. 6 Click Restore Application. The Welcome to Gateway System Recovery window opens. 7 Click Next. 8 To perform a recovery with data backup (recommended), click Recovery with automatic data backup, then click Next. Important Before your hard drive is recovered, your personal files will be automatically backed up to c:\backup. - OR - To perform a full factory recovery without data backup, click Full factory recovery, then click Next. Caution Continuing with the full factory recovery will delete everything on your hard drive. Make sure that you have backed up any important files you want to save. 9 Click Yes, then click Next. The Factory image recovery window opens, which shows you the progress of the system recovery. When recovery is finished, the Recovery is complete window opens. 10 Click Finish, then click Restart. Your computer restarts in its original factory condition. You still need to reinstall any software that was not pre-installed on your computer. If you selected Recovery with automatic data backup in Step 8, you can find your backed up files in c:\backup.
Sep 01, 2009 | Gateway MT3705 Notebook
My emachines w6409 restarts over over and over
There is either a virus or Malware that causes that problem. If you have a Win XP CD put it in and try do a system restore from the earliest possible time. Or do a system recovery; it re-formats your hard drive to like it was when new.
Aug 28, 2009 | Gateway Computers & Internet
I need to get a copy of the recovery disc for the Gateway GM5048
Gateway sells the cds. If you tell them your model no they will send you a recovery disc (with a tiny fee of course).
Here's their number 866-539-3901
You can also live chat here http://www.gateway.com/about/contactus/index.php
Also, check this site out might turn out to be helpful.
http://support.gateway.com/s/software/MICROSOF/vista/7515418/7515418su539.shtml
Jul 25, 2009 | Gateway GM5048 (6304) PC Desktop
Video card removal
Okay first things first make sure you have unlocked the card from the case. Most Gateways have a card lock on it. Once it is unlocked just pull the card out, sometimes they are hard to pull out but you can get a small screw driver and pry up at the case side and slowly work it out.
Hope this helps.
Feb 28, 2009 | Gateway GM5048 (6304) PC Desktop
Modem Problem
reinstall the sound driver
http://support.gateway.com/support/drivers/search.asp?ref=step&st=browse&platform=10021&model=11245&os=10406&type=10096
and the modem driver
http://support.gateway.com/support/drivers/search.asp?ref=step&st=browse&platform=10021&model=11245&os=10406&type=10080
Jun 11, 2008 | Gateway GM5048 (6304) PC Desktop
Sound
reinstall your device drivers for your sound device, if it is a build in sound device for windows, just run your windows etup disk and on the second screen, chooset the option repair.
Sep 05, 2007 | Microsoft Windows XP Professional With...
Gateway GM5048 (6304) PC Desktop Logo
147 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
