It is an outside temperature warning light. Turns yellow when the temperature gets to around 5 degrees and then turns red with the temperature gets to around 0.
The snowflake is an indicator that it is possible for ice to be present on the road. The other one indicates that you need to add windshield wiper fluid to the vehicle...once it is above 32 degrees the red snowflake will go off and a yellow one will come on, once it is above 40 degrees outside the yellow light will shut off as well
the snow flake means the gear box is going in and out of winter mode my dad had the same thing happen but on a diffrent car he topped up his gear box oil and it was fine after
I don't know ... but I will say that when I have encountered a snow flake on a auto display, it has meant (in the cars I have driven) the air conditioner is turned on.
If the light on your cougar has a wrench on it then this is your "Interval Maintenance light", it comes on when your car is due for a scheduled maintenance as prescribed in your owners manual (oil changes, transmission fluid, etc). Another light located on the upper cluster is the "Outside Temp Freeze Warning Light", this light looks like a yellow or red snow flake, if this light is yellow it means it's nearly freezing outside (so watch for slippery roads), and if this light turns red it means that it's 32 degrees or lower
These are outside temp. warning lights. The Yellow light goes on when the outside temp. dips to 40 degrees to let you know that there is a possibility of frost. The Red light goes on when outside temp. dips to 30 degrees suggesting a possibility of icy conditions.
I have a '99 Mercury Cougar & I've been read somewhere that the snowflakes have to do with the outside temp. & traction. I think it's warning you that it may be slippery or icy. I've noticed that when it's +3 to about -2 or -3, the yellow snowflake shows up. Any anything colder than -3 shows the red snowflake. The other lights: the wrench comes up in yellow. That one has always turned on after a certain amount of km's & it's advising you that your car needs a check-up (that's when I know I should look into getting an oil change). You can turn this light off by holding down the two buttons above & below the 'clock' button. Hold them down together for at least 5 seconds & that wrench light should go off. Otherwise, there is a light for checking your breaks (upside down exclamation mark), low windshield fluid. I can't think of any other ones but I hope this helps.
