Question about Toshiba Satellite P15-S479 Notebook
Replace hard drive
There was a loud clanking noise coming from my computer that lasted for about 20 minutes. My computer seem to start working normally but later started working slower. Now I get the following message: "Smart failure predicted on hard disk O: Toshiba MK6022GAX-(pm)warning: immediately back-up your data and replace your hard disk drive. A failure may be imminent.
  • allam2007 Oct 06, 2008
    Thanks for your reply. If I may say so, my problem is my question. Is it difficult to replace the hard drive? I know that it is located behind the cd/dvd drive.
    Thanks again.
    allam2007
    Novelist:
  • 169 Answers
You didn't ask any question ....but you already know the answer. The drive is most likely now a paperweight.
If you have critical data to recover, you can contact Drive Savers ...they're pricey, but they're good!
Hope this helps - remember to rate! :)
Posted on Oct 02, 2008
  • Scott Merrill
    Scott Merrill Oct 07, 2008
    The hard drive is one of the easiest things to replace on a laptop, if not the easiest. Once you remove the drive cover/door, there may be a couple screws to remove (not always) holding the drive to the frame. After that, you just ease the drive out and replace.
    Note: many laptops have a connector (usually black) that fits over the pins. If your old drive has one, make sure to remove it and affix it to the new drive before installation, lest ye bend all the pins and render the new drive dead before usage :)
    Scott
WHAT IS THE LIKELY CAUSED OF A LOUD SQUEALING NOISE COMING FROM THE ALTERNATOR SERPENTINE DRIVE BELT SYSTEM ? IS IT THE ALTERNATOR OR SERPENTINE BELT?
serpentine belt is getting old and hard and the cold weather was causing it to slip
check belt condition ( small cracks across the grooves = scrap and get a new one) and check tension
Jan 22, 2016 | Cars & Trucks
My 97 bmw is hard to start and when it does it makes a loud clanking noise
To be honest I believe it could be your starter and/or battery's. If its makes a clanking noise from what I know it should be the starter.
Oct 05, 2013 | 1997 BMW 328
Clanking noise coming from Allison Transmission on a 2001 Chrevrolet Silverado 8.1 Liter engine
this does sound like theres a loose line tapping the engine/frame,during warm up the engine idles faster which could make it vibrate faster causing the the clanking or tapping noise,if this has started after trans fluid change,then check the lines running from the trani to radiator sometimes the service person might bang into something causing plastic clips that hold the lines to break,try getting under it and have someone start the truck and listen to see where it's coming from also hold the lines & see if the noise stops,the service guy could have unbolted something & never put the bolt back causing the clank ex.line may have a clip holding it thats bolted to the trani pan ?good luck
Dec 29, 2012 | 2001 Chevrolet Silverado 2500HD
Constant loud noise when frig turns on/comes from bottom
when the compressor is running unplug the ref. and if you hear the noise coming from the compressor then
a ballance spring may be broken inside the compressor.
The compressor will run normally with a broken spring it will just be annoying when it shuts down.
Jan 16, 2010 | Roper RT21AKXKQ Top Freezer Refrigerator
Acer aspire4920 makes loud noise at start up
This could be caused by the harddrive. There might be a bad bearing or something. Please backup all your data. You will probably have to replace the hard drive sooner or later.
May 07, 2009 | E-Machines T6524 PC Desktop
Rattling from under the hood
I would start by splitting up the drive train to determine if it is accessory, engine or transmission related.
There are a number of things that can cause a problem like this.
1) Is the noise louder in drive or reverse.
2) I would start with heat-shields because of your "clank" description. Exhaust manifold, catalytic converter shields and any other you can find under hood or under body.
3) If all is good, check engine and transmission mounts. Make certain none have collapsed, cracked or broken.
4) If all good, remove all accessory drive belts and start engine to see if noise goes away.
That's a lot to start with, so let me know what you find and we will go from there.
Regards.
Mar 30, 2009 | 1995 Buick Riviera
Loud clanking noise in dishwasher
Most likely the motor as food caught in the sump would not make a noise you described.
http://tclaundryrepair.com/home
Feb 19, 2009 | Kenmore Dishwashers
MY ENGINE KNOCKS AFTER DRIVING A FEW MILES
you have a rod knocking in the engine
Feb 04, 2009 | 1985 Nissan 300ZX
Toshiba Satellite P15-S479 Notebook Logo
243 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
