Question about Video Game Consoles & Games
How to fix a reseted Ps3 system - Video Game Consoles & Games
  • Azlie Marikkar Apr 24, 2009
    How can I reset the factory settings or Soft format on my nokia9300 device
MY PS3 WONT TURN ON THE LIGHT TURNS GREEN THEN GOES TO RED
Posted on Dec 25, 2009
How do i fix my video
Posted on Oct 31, 2008
No display on tv
Posted on Oct 15, 2009
My PlayStation 3 is hooked to the av portion of the TV.... it was working fine last night when I went to sleep.... and Igot up this morning and there was no ssound..... if I put it on HDMI I get sound but...
It's actualy an easy fix. The problem you are having, is resetting the video options on your PS3. It auto detects HDMI or A/V cables. Here is a vid of how to do it. Again, really easy. Remember, this works with EVERY PS3 system.
How To Reset PS3 Video Settings PS3
Jul 18, 2014 | Video Game Consoles & Games
Tip
8 Steps to Fixing Any PS3 Issue
Note: If your PS3 is on, but you are looking at a blank screen, you PS3 may be in HD mode.
  • Turn off your PS3.
  • Hold down the power button for 2 beeps. This will reset your PS3 video to standard output.
  • If you are unable to reset your video, skip to Step 8.
  1. Back Up your PS3. You will need a compatible external hard disk drive for this step.
  2. Enter Recovery Mode.
  3. Choose "System Update".
    Try to load a game or movie. If it works, skip the rest of the steps listed below; otherwise, continue.
  4. Re-enter Recovery mode, and choose "Restore Default Settings".
  5. Re-enter Recovery mode, and choose "Restore File System".
  6. Re-enter Recovery mode, and choose "Rebuild Database".
  7. Re-enter Recovery mode, and choose "Restore PS3 System". WARNING!: This option will delete everything on your PS3 hard disk drive!
  8. Return the unit to Sony. If your PS3 is still under warranty the fix will be free; otherwise it will cost $150.
on Mar 26, 2010 | Sony Playstation 3 (PS3) Console
Ps3 only displays in 1080i
I have similar problem , ps3 320gb + 5 years old sony bravia 1080p = everything OK
but when i connect ps3 to new samsung ue46d7000 1080p = doesn't work (only 1080i)
I am using same HDMI cable
Jun 19, 2012 | Sony Playstation 3 (PS3) Console
How do you reset your PS3?
You can reset the Sony PlayStation 3 to troubleshoot the gaming system or restart after a hard drive freeze. Resetting the PS3 will restore the PS3's settings to to the default factory settings. Consider backing up any data or custom settings before doing a system reset for the PS3 as they might be erased.
instructions:
  • urn off the PS3 by flipping the power switch on the back of the system.
  • 2
    Turn the power switch back to the "on" position.
  • 3
    Hold the power button while the PS3 is powering up until you hear three beeps. These signal that the PS3 has received the manual system reset command.
  • 4
    Prompt through the initial setup menu to continue resetting the PS3.
  • 5
    Select "Format" from the system menu to format and finish a complete system reset for the PS3.
  • Dec 06, 2011 | Sony Playstation 3 (PS3) Console
    When i start up my ps3 it has no icons what is the best way to fix that issue
    Best advice would be to do a hard reset, if a hard reset doesn't work it is an internal hardware issue that can't be fixed without opening the Ps3...Here are the instructions for how to perform a COMPLETE hard reset.Hard Reset procedure for the PS3 (as instructed by Sony CS).
    Be sure to backup your settings/games saves by doing a System > Backup on your PS3 or you may lose your game saves! Also, this is a last resort procedure prior to exchanging/returning to sony.
    1. Power Off the PS3 via the power switch in back and power back on w/switch.
    2. Hold Power Button on the Front until you hear 3 beeps.
    3. Then go through the initial setup and then run a full Format via System > Format. (will take approx 3 1/1 hours). You may need to have our AV cables ready if your using HDMI (in case HDMI isn't detected after initial reset).
    4. Restore your backup you made prior to doing factory/hard reset (optional, if you created a backup).
    Good Luck!!
    May 16, 2011 | Sony Playstation 3 (PS3) Console
    Ps3 red light is blinking how can I fix it
    Follow the procedure below to fix the problem on your ps3,
    1. Turn off Playstation®3.
    2. Hold the power button down; the system will turn on and turn off once again.
    3. Once the System has been shutdown, re-press you finger until you hear 2 consecutive beeps
    4. When you hear the 2 beeps take finger off power button.
    5. You will be prompted to plug in your controller via USB and then hit the PS button
    6. The Recovery menu will pop up.
    The current Recovery Menu supports:
    • Restart System: Restarts the PLAYSTATION®3 System.
    • Restore Default Settings: Reset all system settings back to default.
    • Restore File System: Checks for corrupt/missing system files.
    • Rebuild Database: Rebuilds the OS for the PLAYSTATION®3.
    • Restore PS3 System: Fresh restore; Deletes everything and starts from Scratch.
    • System Update: Update the PLAYSTATION®3 System.
    Take care.
    Aug 25, 2010 | Video Game Consoles & Games
    My ps3 reads system is to hot and shuts down within five minutes. I don't think the fan is working at all. No warranty how can I fix this myself? I know how to take ps3 apart and I've cleaned the dust out...
    Try upgrading the firmware as well.. Or doing a factory reset..
    The error code could simply be stuck, and an upgrade or system restore may fix the issue if you have already cleaned the fans.
    Aug 17, 2010 | Sony Playstation 3 (PS3) Console
    Problems with call of duty 4 and call of duty world at war
    i guess it's a problem with your Hard Disk . please try the following :
    • re-updating your system by an USB device (download the update from sony ps3 website)
    • reinstalling all game data files
    • restoring your system (don't forget to backup all your important files such as game saves !!)
    Jun 19, 2009 | Sony Playstation 3 (PS3) Console
    Ps3 video screen black can hear sound
    its easy to fix...press and hold the power button for 10 sec. until it resets its self....the console is set to..be on hi-def and u have to reset the console settings...hope it helps
    Apr 19, 2009 | Sony Playstation 3 (PS3) Console
    Black screen When i turn my ps3 on
    You can try to reset the system. The way that you go about that is to push and hold the power button for, I think 15 secs. you will hear it beep and then reset. Give it a try.
    Feb 03, 2009 | Sony Playstation 3 (PS3) Console
    Video Game Consoles & Games Logo
    1,035 people viewed this question
    Top Video Game Consoles & Games Experts
    Josh Whitehead
    Josh Whitehead
    Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
