Hi, I have Samsung Q35 and it seems that there is something wrong with the screen. Could you please let me know how much will it cost to change it Thanks, Sumit
    Novelist:
  • 169 Answers
We can't charge you through this site for onsite services such as these. However, I can tell you that if a client needed a new LCD for their laptop, my local service charge varies between $60 and $75, plus the cost of the LCD. LCD's usually run $100-$175 (depending on model) on eBay.
So, if you take it locally to get fixed, that's around the base line of what you should be paying. Naturally, the bigger the store (Best Buy), the more you'll pay. Try to find a local "PC repair shop" and you can save some $$$
Hope this helps - remember to rate :)
Posted on Oct 02, 2008
Get my screen on samsung chromebook back to normal as itis showing black background and pictures look ghost like
hard to say without seeing it, sounds like your back light may have gone off try opening and closing the lid a few times and check the power setting in the control panel
Feb 17, 2015 | Samsung R440-11 14"" LED Notebook - Core...
Left half of screen has dark rainbow effect and remains on for 10-15 sec after shut off
Try changing the input device to something you are sure works. Switch off TV manually, switch off power, remove plug and retry after 48 hours. If problem persists, please refer it to a qualified service technician.
Jul 25, 2012 | Samsung LN52A850 52 in. LCD HDTV
My samsung tocco lite screen seems to be out of sync?when i touch something,something else comes up.. can you help me please?
hi there go to setting & then calibrate the screen touch. After that your problem will be solved. Thanks
Dec 19, 2010 | Samsung Cell Phones
Samsung Jet screen problem
IT SIT IS THE PROBLEM OF YOUR DISPLAY PLEASE CHANGE IT BY GIVING IT TO A AUTHORISED SERVICE CENTRE
Jan 03, 2010 | Samsung Jet S8000 Cell Phone
Cant connect my q35 speaker, help please!! Theres 4 connections??
Hi, They should have a gold bar "jumper"between the two black/and the two red connectors. If not, it is missing,but the reason for that is you can use seperate amps for the woofer and the tweeter/mid.Called "Bi-amping."You can just use a extra wire to connect both inputs together. Black to black and red to red.
Oct 30, 2009 | KEF Audio Q35 Speaker
Crack inside screen and now cant see anything on screen at all - is it repairable and how much will it cost?
dear,
if the screen has broken then u have to change it intially then after changing it the other issue will occurs if it had did something wrong with it..
regards,
rate it if the issue resolves..
Jul 18, 2009 | Samsung Tocco F480 - Pay Monthly Cellular...
I can't close the DVD on my Samsun Q35 laptop. It won't close. It seems to get stuck halfway.
mechanical failure if u know how to open it then u need to open it check the moving parts if not replace it
May 21, 2008 | Computers & Internet
Without my laptop (samsung q35) being linked to the mains it is nearly impossible to be able to see what is on the screen, i have tried to adjust settings but this has had little or know affect. pleas help...
You may check power settings in control panel and see if somehow the settings for your screen are set to turn off or the power settings program has been corrupted for some reasons. Although I doubt that this the case it is worth to check.
At the same time there is a need for more information about how did that start or if you have done any physical changes to the computer.
Another thing you may do is connect it to an external monitor and see if the same thing happens to the external monitor. If that is the case then I think there is something wrong with your display card.
Jan 27, 2008 | Computers & Internet
VERTICAL LINES AND THE COLOR CHANGES
are the colored lines all the way across the screen? with no video even menu does not show up i would say you have a bad panel take it back to the store
Oct 22, 2007 | Samsung LN-T4671F 46 in. LCD Television
Monitor works for about 30 mins then goes blank with a messahe reading 'Not Optimum'
Hi Rick I have the same problem. Have you found a solution yet? I had the power supply tested, that is not the problem. It seems to go off when it gets hot. If I point a fan at it, it seems to last longer before blacking out. Pete
Feb 23, 2007 | Samsung SyncMaster 710N 17" LCD Monitor
Computers & Internet Logo
Brian Sullivan
Brian Sullivan
David Payne
David Payne
