Question about Cell Phones
Ord #310952A unit dosn,t work. - Cell Phones
Shuv it up your bottom thatll do the trick
Posted on Oct 01, 2008
Dosn,t work
If powered up and no Video, the video circuit was damaged, or compromised. It needs a professional service agent to fix the unit.
Jul 29, 2014 | Sony BRAVIA KDL-40EX620 40" LED TV...
Washer dosn't take the fabric conditioner
Washer dosn't take the fabric conditioner This video will show you how to keep your soap draw clear and how to service the parts
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Dec 03, 2012 | Washing Machines
Electrical problems with a 2002 Satun SL 200, the electrical door locks dosn't work, the mirror adjustments dosn't work, the dome light dosn't work. The engine runs good. head lights work
check all your fuses in engine compartment and under dashboard engine check light comes on every 3000 miles for oil change reminder
Jul 23, 2012 | Cars & Trucks
Fuel guage dosn't work
In almost every case the fuel gauge issue is caused by a defective fuel level sending unit inside the fuel tank, it is an open circuit.
May 23, 2012 | 1999 Buick Park Avenue
1998 chev 1500 hard starting when cold but starts fine after warming up changed plugs and sensors
The first thing i would tey is changeing the fuel filter. Chevy has a problem with the design from the fuel pump to the fuel inlet on the intake manifold. What they did it is back up the power supply to the fuel pump from the fuel relay and split the curicut and ran the back up through the oil pressure sending unit . So even if the relay went bad while driveing the fuel pump would still get power and the truck wouldn't die on the road its a saftey thing .But if the relay is bad then the engine needs to build up enough oil pressure to trip the oil sending unit to send power to the pump from cranking thus a long cranking time when cold . Change the fuel filter first it should be replaced every 4 to 5 years anyway . A nd if that dosn't fix it try the relay it should be behind a panal inside the glove box on your truck and if that dosn't work replace the oil pressure sending unit. One of these 3 things should work if the fuel pump is working correctly
Sep 17, 2011 | 1998 Chevrolet C1500
Can emc ax150 work without the UPS cable?
I moved my AX-150 to a location that would not allow me to install the UPS as it has redundant power/UPS and you should not connect a UPS to the output of another UPS.
Without the UPS the AX-150 forces the Write Cache to be Disabled. Performance drops, form what I have tested, to around 25x slower. This is due to not just turning off the controllers write cache, but as with ALL RAID controllers, the onboard drive 8/16M write cache is disabled as well so the drives are even slower then they would be if they where not used on a RAID controller.
The write cache disable is your real killer! Actually the write cache is disabled one a week while the REQUIRED battery test is performed.
My solution was to write an APC SmartUPS Serial Emulator that talks to the AX-150 telling it that the UPS is working fine so the write cache never gets turned off, including during the weekly battery test!
Here is the needed RJ45 to DB9F. Colors are base on someone cutting off the end of a cat5 patch cable.
You can find the APC SmartUPS commands off the web.
Communications capture:
Normal Comms from/to AX-150
Y >>
SM<0D><0A>
Q >>
08<0D><0A>
f >>
100.0<0D><0A>
R >>
BYE<0D><0A>
Y >>
SM<0D><0A>
Q >>
08<0D><0A>
f >>
100.0<0D><0A>
R >>
BYE<0D><0A>
!!! Weekly Batt Test Time !!!!!
Y >>
SM<0D><0A>
Q >>
08<0D><0A>
f >>
100.0<0D><0A>
R >>
BYE<0D><0A>
Y >>
SM<0D><0A>
W >> !! Tests battery, like pushing the test button on the front panel
OK<0D><0A>
R >>
BYE<0D><0A>
Y >>
SM<0D><0A>
Q >>
08<0D><0A>
f >>
100.0<0D><0A>
R >>
BYE<0D><0A>
Y >>
SM<0D><0A>
Q >>
08<0D><0A>
f >>
100.0<0D><0A>
X >> !! Self-test results
OK<0D><0A>
l >> !! Low transfer voltage
097<0D><0A>
R >>
BYE<0D><0A>
Y >>
SM<0D><0A>
Q >>
08<0D><0A>
f >>
100.0<0D><0A>
R >>
BYE<0D><0A>
Y >>
SM<0D><0A>
n >> !! Get Serial number
AS0632112344<00><0D><0A>
R >>
BYE<0D><0A>
!!! End of Test !!!
Y >>
SM<0D><0A>
Q >>
08<0D><0A>
f >>
100.0<0D><0A>
R >>
BYE<0D><0A>
Y >>
SM<0D><0A>
Q >>
08<0D><0A>
f >>
100.0<0D><0A>
R >>
BYE<0D><0A>
Y >>
SM<0D><0A>
Q >>
08<0D><0A>
f >>
100.0<0D><0A>
R >>
BYE<0D><0A>
Y >>
SM<0D><0A>
Q >>
08<0D><0A>
f >>
100.0<0D><0A>
R >>
BYE<0D><0A>
I would be happy to share the Delphi source and EXE with anyone that would like to use it. Do not see a place to attach files here.
Can give you snapshot of main command-response logic:
if Result = pmerGood then
begin
tRx := Engine.RxString;
if cbHex.Checked then
Msg(Engine.SeeBytes(tRx)+ ' >> ' + #$0D + #$0A)
else
Msg(Engine.SeeChars(tRx)+ ' >> ' + #$0D + #$0A);
PendingCmd := '';
Engine.CharDelay := 0;
CmdData := 'NA' + #$0D + #$0A;
if length(tRx) > 0 then
case ord(tRx[1]) of
$01 : CmdData := 'Smart-UPS 750 RM' + #$0D + #$0A;
$1A : CmdData := '#uD43127130133136uA43108110112114uI43253257261265uM432252292' + '33237lD43106103100097lA43092090088086lI43208204200196lM43182178174170e47200153045607590oD13120oA13100oI33230240220oM13208s431HMLq4820205081114172023p483090180270360450540630000k4310TNr483000060120180240300360420E443336168ON OFF' + #$0D + #$0A;
ord('A') : CmdData := 'OK' + #$0D + #$0A;
ord('B') : CmdData := '27.40' + #$0D + #$0A;
ord('C') : CmdData := '016.2' + #$0D + #$0A;
ord('D') : begin CmdData := '!!!$'; Engine.CharDelay := 600; end;
ord('E') : CmdData := '336' + #$0D + #$0A;
ord('F') : CmdData := '60.00' + #$0D + #$0A;
ord('G') : CmdData := 'S' + #$0D + #$0A;
ord('I') : CmdData := 'FF' + #$0D + #$0A;
ord('J') : CmdData := '0F,00' + #$0D + #$0A;
ord('K') : CmdData := 'OK' + #$0D + #$0A;
ord('L') : CmdData := '126.7' + #$0D + #$0A;
ord('M') : CmdData := '128.1' + #$0D + #$0A;
ord('N') : CmdData := '125.2' + #$0D + #$0A;
ord('O') : CmdData := '113.0' + #$0D + #$0A;
ord('P') : CmdData := '000.0' + #$0D + #$0A;
ord('Q') : CmdData := '08' + #$0D + #$0A;
ord('R') : CmdData := 'BYE' + #$0D + #$0A;
ord('S') : CmdData := 'OK' + #$0D + #$0A;
ord('U') : begin CmdData := '!!!$'; Engine.CharDelay := 600; end;
ord('V') : CmdData := 'FWD' + #$0D + #$0A;
ord('W') : CmdData := 'OK' + #$0D + #$0A;
ord('X') : CmdData := 'OK' + #$0D + #$0A;
ord('Y') : CmdData := 'SM' + #$0D + #$0A;
ord('a') : CmdData := '3.!$%+?=#|.' + #$01 + #$0E + #$1A + ''')+-89>@ABCDEFGKLMNOPQRSUVWXYZabcefgjklmnopqrsuxyz~' + #$0D + #$0A;
ord('b') : CmdData := '615.3.D' + #$0D + #$0A;
ord('c') : CmdData := 'UPS_IDEN' + #$0D + #$0A;
ord('e') : CmdData := '00' + #$0D + #$0A;
ord('g') : CmdData := '024' + #$0D + #$0A;
ord('f') : CmdData := '100.0' + #$0D + #$0A;
ord('i') : CmdData := 'FWD' + #$0D + #$0A;
ord('j') : CmdData := '0375:' + #$0D + #$0A;
ord('k') : CmdData := '0' + #$0D + #$0A;
ord('l') : CmdData := '097' + #$0D + #$0A;
ord('m') : CmdData := '08/03/06' + #$0D + #$0A;
ord('n') : CmdData := 'AS0632112344' + #$00 + #$0D + #$0A;
ord('o') : CmdData := '120' + #$0D + #$0A;
ord('p') : CmdData := '090' + #$0D + #$0A;
ord('q') : CmdData := '02' + #$0D + #$0A;
ord('r') : CmdData := '000' + #$0D + #$0A;
ord('s') : CmdData := 'H' + #$0D + #$0A;
ord('u') : CmdData := '127' + #$0D + #$0A;
ord('x') : CmdData := '01/01/10' + #$0D + #$0A;
ord('y') : CmdData := '(C) APCC' + #$0D + #$0A;
ord('z') : CmdData := 'CLEAR' + #$0D + #$0A;
ord('9') : CmdData := 'FF' + #$0D + #$0A;
end;
if CmdData <> '' then
begin
Msg(Engine.SeeBytes(CmdData)+ #$0D + #$0A)
else
Msg(Engine.SeeChars(CmdData)+ #$0D + #$0A);
Engine.SendMsg := CmdData;
end;
Bob A. Hay
Mar 02, 2010 | EMC 1U UPS 120V FOR AX150 (AX150UPS120V)...
Blower wont turn on
wired wrong. or you replaced a good control in a unit that has a bad motor.
Jun 19, 2009 | Heating & Cooling
Brother hl-5250dn fuser unit faliure
I have 2 printers that dosn´t work. Brother HL-5250 dn One with fuser that dosn´t work. Can I take thee fuser from the other and attach it into the first one. Or do you ned spcial tools and knowldge to do it?
rolf@edeborg.se
Jan 19, 2009 | Brother HL 5250DN Laser Printer
My suond sesitm not working
My Sound Driver is not working. What am I do for this. It has Realtek drivers. If you can send me it.
Sep 22, 2008 | HP Sound Card
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
