Question about Philips 42PF9630A 42 in. Plasma Television
Powers off by itself
TV powers off for no reason
    Sergeant:
    Champion:
  • 223 Answers
I think there could be a fault on the power supply board of the tv. If you can check this yourself if not find a competant technician. Hope this helps.
Posted on Oct 01, 2008
Jvc TV has no power
(See the comment I added to the comment section regarding your 2 volt output)... Without using the remote, press the power button on the TV itself and HOLD IT DOWN until the TV powers on. If that works, it is a (going) bad power amp chip. The good news is that if it works, it will work that way for quite some time, just so long as you are consistent with holding down that power button _until_ the TV powers on. Every time it fails to power on (such as when using the remote and/or momentarily pressing the power button), the chip fails further. In other words, the more times it is allowed to NOT "power on" the closer you get to total failure. So, if holding the power button until "power-on" works, make sure nobody does it the "not-working" way anymore. (Hope that makes sense because it really will matter). The cost of repair is not worth it. If all the above does not apply, you can check for a blown fuse in the TV's power supply. However, I can assure you there will be a (not worth fixing) reason for a blown fuse in the first place. BTW, I had a two JVC TV's with the "power-on" problem as I described above. I threw them away 2 years later _still_ working the way I described to you.
Oct 14, 2015 | JVC Televison & Video
RCA P56950 Powers on then 10 mins later powers off, repeats cycle. Then channel display in TV changes by itself
may be some thing is stuct on the controt pannel power button or others check. try this it may work
Jun 04, 2012 | RCA P56950 56" Rear Projection Television
Nec nlt-19hdb3 lcd tv turns on, boots ok, then powers itself off after about 15 secs
Power supply board have problems.Tries unplug,replug the tv an hour later,the tv now,will reset itself back to factory setting.The tv should work now,not than the power supply board is dead.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Oct 11, 2010 | NEC ONYX NLT-19HDB3 19 in. LCD TV
My tv powers on but no pictures. the picture will
Probably the inverter board which is part of the LCD itself. Can get pricey.
Oct 13, 2009 | Samsung LN-T4665F 46 in. LCD Television
Its your bulb on its way out.
the replacement bulb is a Sony XL-2400 But yours should definately be under warranty
Mar 20, 2009 | Sony KDF46E2000 46" Projection HDTV
My TV powers off by itself for no reason.
If you have read any of the previous post about this....sounds like a overheating issue. This happens quite often with overhead projectors also. Keep in mind that this is only guidance but it might be a good idea to open up the unit and get rid of dust. Dust becomes an insulator on all electronics (power supplies, electronics, lamps) or use some of the other quick fixes mentioned in the other post like add cooling externally. Hope this helps.
Dec 26, 2008 | Samsung DLP HL-P5663W 56" TV
SONY SXRD Powers off and on
the tv will cycle the lamp over and over when it goes bad. for some reason, it doesn't spit out the lamp error. the steady green blinking led means the tvs coming on. replacing the lamp will solve your problem.
Nov 25, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
TV powers on, then cuts off by itself. After many on-off tries, tv goes to menu and through it, then cuts off.
TV powers on, then cuts off by itself.  I have no picture, and will not let me control the tv. with remote, or manual.
Jul 20, 2008 | Philips 60PP9202 60" Rear Projection...
RCA 32" SDTV
27V530t......my TV powers off and on all by itself and wont stay powered.Can you help ?
Jul 09, 2008 | RCA 32F531T 32" TV
Tv unexpectedly powers off
Hi i has the same probleme..... My tv has 1 years and 6month... since two days.... the tv turn off itself...I have just take 15minute, unplug tv, and i have open in the right side the little panel...And i have clean inside!!! And i have do the same thing with the big panel in the back of the TV...After i have clean the fan...After this clean my tv is number one... and nothing turn off
Apr 21, 2008 | Toshiba 42HM66 42" Projection HDTV
Philips 42PF9630A 42 in. Plasma Television Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
