Question about Fujitsu AMILO Pro V1000 Notebook
EXCEL TYPE ON EXCEL / SAVE FOLDER BUT CAN'T RE OPEN FILE. YOU CAN OPEN SCREEN BUT GIVE A BLANK (GREEN) SCREEN WITH NO INFO
I have several excel files stored on my system. I used these files from the same computer daily. Yesterday, when i tried to open several files in Excel 2007 then i found following error on my co,puter...
  • Navigate to the folder containing the XLSX file you want to repair.
  • Right-click the file and select "Copy" and then right-click on a blank space within the folder and select "Paste." This action generates a backup copy of the corrupted file.
  • Open Microsoft Excel 2007 or later.
  • Click the "Office" button in the top left corner of the window and select "Open."
  • Navigate to the folder containing the copy of the XLSX file you generated previously and select it by single-clicking its icon.
  • Click the arrow located to the right of the "Open" button and select "Open and Repair."
  • Select "Repair." If you previously attempted this method and the process failed, try to extract only the values and formulas by selecting "Extract Data" instead. Regardless of the method you choose, your data will appear on the screen within a few seconds if the process completes successfully.
  • Dec 11, 2014 | Microsoft Office Professional 2007 Full...
    Deleted user account for laptop but saved account info in a folder on desktop
    Hello Patty,
    Have you tried dragging the files to your desktop and try opening them that way? if not open up your word or excel program and locate the file by using file and open.. also I would drag and place pictures to a new location other then the files folder that it was saved on.
    May 08, 2013 | Microsoft Windows 7 Home Premium 64BIT...
    How to convert 2007 excel sheet into 2003 excel sheet
    if you have excel 2007 you can save the file into excel 2003 compatibility
    if you have excel 2003 need download compatibility pack from this page
    http://www.microsoft.com/downloads/en/details.aspx?familyid=941b3470-3ae9-4aee-8f43-c6bb74cd1466&displaylang=en
    install it and success!
    Feb 22, 2011 | Computers & Internet
    HOW TO TRANSFER TALLY ACCOUNTS DATA TO EXEL SHEET
    HI,
    Please follow below step
    Step 1. Open Tally
    Step 2. Open Report Which is you want Transfer in Excel.
    Step 3. Press CTRL With E (Ctrl+e) from keyboad
    Step 4. Select Sharped Sheet or Excel
    Step 5. After type location for file save like this D:/your folder name/
    Step 6. After You type file name with xls. like this sales.xls
    thanking you
    davevipul197
    Dec 19, 2010 | Computers & Internet
    I HOW I EXPORT TALLY 7.2 DATA IN EXCEL FORMAT
    There are 2 ways to do it..
    Step 1
    You can export as text and import it back to excel using the text file you created.
    Or
    You can select HTML and give the file name as eg-XYZ.xls
    Step 2
    You can export all reports and statements. For this a separate export button is provided in right hand button bar. To do this go to any report e.g. day book you to export or any statement e.g. balance sheet. You would see export button on top right hand side on button bar. Press it and a screen would pop up with export related options.
    The first option is format of data to be exported namely ASCII, HTML, SDF, and XML. Which ever application you are importing this data in would decide in which format you should export the data.
    For statements like balance sheets and trial balance which we use to send and import file in word and excel etc. HTML format is good. We need minimum formatting in this format while using it in MS Word and MS Excel.
    certain applications accept continuous data where we have defined field length. Then ASCII format is better.
    For application which accept SDF and XML format these formats can be chosen.
    Give a file name and the exported file is saved in the parent Tally directory on your computer. You can now use that file to import its contents into another program, send it as it is (say if it is HTML file) to a colleague or view it using a browser.
    Step 3
    Consider exporting day-book.Go to day book press export button or use shot cut key Alt+E. Exporting screen will displayed.
    Press Back space on your keyboard. And select Format as ASCII (comma delimited). Now give output File Name as Daybook.csv, now select some other option you want to export from the bottom of the screen.
    Press enter to accept screen. Day book is exported in to tally program folder. Check program folder for file daybook.csv,
    Double click on it, the file will open in excel program. If you want it in excel work sheet file, use the option Saveas, and save it in Microsoft excel workbook (*.xls) format.
    Hope this is helpful. Let us know if the issue is resolved.
    *Rating and Comments are invited for this solution
    Nov 10, 2010 | Tally T2245 Matrix Printer
    MS Office 2003 Intallation
    Go to "FILE", "Save As" and then change "Save As type to XLS" That should hold that setting afterwards from now on.
    <img src="http://i.i.com.com/cnwk.1d/i/tr/downloads/images/10_things_office2007_compatibility/10_things_office2007_compatibility_a.jpg">
    If you have any more questions please feel free to email me and don't forget to rate.
    Thanks!
    Feb 23, 2009 | Microsoft Office Excel 2003 for PC
    Excel-template
    Open a blank workbook in Excel and click "save as" option select "Template" from the drop-down list and save it
    Hope this helps,
    CynosureboY
    Sep 13, 2008 | Microsoft Excel for PC
    Using Word & Excel mobile
    I saved an empty blank Word doc. and excel sheet. to my phone via Microsoft Active Sync. Now I just open the blank doc. edit the file, and save it as a diffrent file name. I'm still left with the blank doc. and an edited file.
    Jul 30, 2008 | T-Mobile Dash Smartphone
    Unrecognized file type
    Good Day, This can be fixed, here's a step by step 1. Open folder containing any of the above said files. 2. Click TOOLS in the upper tool bar 3. Then FOLDER OPTIONS 4. Click the FILE TYPE tab at top of window 5. Scroll through list and find above said file type 6. Then click change button, and select from this list the program that you need to open this file with. Hint:If this file type is not in the first list you can click the new button and create it. Hope this helps
    Oct 01, 2007 | Computers & Internet
    Microsoft excel file crrupted
    To open a corrupt file; you have to repair the file first.
    MS Excel has a special feature to repair corrupt file that is Open & Repair.
    Repair a corrupt excel file by following steps:
    • Open a blank wordbook.
    • Go-to the File menu and click on the open button.
    • Now select your corrupt file and click on the arrow next to open button.
    • Select Open & repair option and click on the open button.
    • Save as the file and give the new name.
    Additionally you can try 3rd party excel repair software if Open & Repair fails to repair corrupt file.
    Sep 13, 2007 | Microsoft Office Standard for PC
    Fujitsu AMILO Pro V1000 Notebook Logo
    48 people viewed this question
    Top Fujitsu Computers & Internet Experts
    Alun Cox
    Computer Links
    Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
