2006 Suzuki Forenza Logo
james peffley Posted on Dec 08, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to change a crank position sensor on 2006 suzuki forenza
What is the easiest way to do this?
  • Allan Dec 16, 2011
    I put full instructions, however, I don't know it posted all of it.
Allan
Level 2:
Scholar:
  • Expert 79 Answers
  • Posted on Dec 16, 2011
Allan
Expert
Level 2:
Scholar:
Answers
79
Questions
Helped
63519
Points
128
5) Install the rear A/C mountingbracket. Tighten the rear A/C mounting bracket bolts to 35 Nm (26lb-ft).6) Install the A/C compressor. 7) Install the power steering pump. 8) Connect the negative battery cable.how to change a crank position sensor on 2006 suzu - 12_16_2011_6_00_05_pm.jpg
If this helps, please say so! Thanks! :-)
    Removal
    1) Disconnect the negative battery cable.
    2) Remove the power steering pump, if equipped.
    3) Remove the A/C compressor.
    4) Remove the rear A/C compressor mounting bracket bolts and the rear A/C compressor mounting bracket.
    5) Remove the accessory mounting bracket by removing the bolts.
    6) Disconnect the crankshaft position (CKP) sensor connector.
    7) Remove the CKP sensor retaining bolt.
    8) Gently rotate and remove the CKP sensor from the engine block.
    Installation
    1) Insert the CKP sensor into the engine block.
    2) Install the CKP sensor retaining bolt.
    Tighten the crankshaft position sensor retaining bolt to 8 Nm (71 lb-in).
    3) Connect the CKP sensor connector.
    4) Install the accessory mounting bracket with the bolts.
    Tighten the accessory mounting bracket bolts to 37 Nm (27 lb-ft).
    5) Install the rear A/C mounting bracket.
    Tighten the rear A/C mounting bracket bolts to 35 Nm (26 lb-ft).
Just changed coil and still no spark suzuki forenza 2006
Basic first check your fuses 2nd you got a check engine get it scan tell me the code if you got a crank sensor trouble code change it it will start
1helpful
3answers
Trouble code P0340 2006 Suzuki Forenza
It`s coming up the Camshaft position sensor.
Where is the cam position sensor on a suzuki forenza 2006
Camshaft poistion senor that's what wrong they told me
1helpful
Is throttle positioning sensor on 2007 suzuki forenza is it steal on warranty
Yes it is covered for 7 years or 70,000 miles on most cars. Just call the dealer.
I have a 2006 Suzuki Forenza, If I want to test or troubleshootmy crank sensor sensor how would I go about doing that? I replaced my Throttle body and the car won't start because it is not sparking. My...
They are a magnetic pickup device. You can test them but the test is never conclusive. Go to O'Reileys or Autozone, they usually scan your car for free. Hope this helps...
2helpful
3answers
How do i replace my TPS on a 2006 Suzuki Forenza?
2006 SUZUKI FORENZA RECALLS/DEFECTS & PROBLEMS Access the National Highway Traffic Safety database of 2006 SUZUKI FORENZA recalls and defects found on 2006 SUZUKI FORENZA automobiles. The National Highway Traffic Safety administration is authorized to order the 2006 SUZUKI FORENZA manufacturers to recall and repair vehicles or parts of motor vehicle equipment when its investigation indicates that they contain serious safety defects in their structure, or performance.
Check with your loacol suzuki for recall not sure on this part but it is a common problem
Good luck
7helpful
TRANSMISSION RANGE SENSOR FOR 2006 SUZUKI FORENZA IS IT PART OF WHEEL TRAIN? AND IF i FIX IT MYSELF DO i NEED IT CALIBRATED BY COMPUTER?
You do not need to "calibrate the computer" when changing the trans. range sensor. If the dealer is telling you this, it is because they want more of your money. Just buy the sensor.
Top Suzuki Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
john h
Are you a Suzuki Expert? Answer questions, earn points and help others
