Question about Maytag MER5552BAW / MER5552BAQ / MER5552BAB Electric Kitchen Range
Maytag MER5552BAW Electric Range
Preheating oven, coil caugt fire and burned in two.
  • jesterzen Jan 06, 2009
    I had the same problem I replaced the element. but the indicator light does not go on and the elements do not heat. The other side works fine and so do the elements. and the indicator light works
  • 943 Answers
Hi. thanks for the question. yes that's how sometimes they burn out .replace the burnt out coil. thanks the appliance doc please rate me
Posted on Oct 01, 2008
I have a Maytag electric oven model MER5552BAW. Bottom bake element blew out. I replaced the element & now oven will not heat at all. Going nuts!
Go to youtube and type in your model number and ask for repair videos:
Feb 20, 2015 | Maytag Kitchen Ranges
Why did my maytag gemini double oven coil caught on fire and break in half?
Because it failed
Ask an appliance parts store how
many times they see that
Jul 18, 2014 | Maytag Gemini 30" Self-Cleaning...
Element in oven sparked at corner and now will not heat
The heating element burned through -- it needs replacing. Turn off power to oven, remove two screws on heating element mount, pull heating element from wall of oven, remove two screws connecting electric leads to heating element. To install new element, reverse steps. Make sure screws connecting heating element to wires are very tight -- otherwise they will arc.
Jan 08, 2011 | Maytag MER5552BAW / MER5552BAQ /...
The oven shuts itself off after preheating.
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
Jun 03, 2010 | Maytag MER6772 Gemini Electric Kitchen...
Coil burner stays on even when in the off position on my maytag range.
The switch control for the burner has gone bad.
If you can get me the model and serial numbers from the tag on the range and tell me which coil is having the trouble I can assist with repair part numbers and tell you how to repair if needed.
May 11, 2010 | Maytag MER5552BAW / MER5552BAQ /...
Your range is stuck in SABBATH mode. You should be able to press and hold the clock button for 5 seconds to reset.
Nov 03, 2009 | Maytag MER5552BAW / MER5552BAQ /...
it could be either or. i would replace the element first as it's much cheaper.
Aug 26, 2008 | Maytag MER5552BAW / MER5552BAQ /...
Oven do not get hot enough
could be a thermostat or the element.
Oct 26, 2007 | Maytag MER5552BAW / MER5552BAQ /...
Maytag oven not getting hot enough
When you put the oven into bake it preheats with the bake and broil element both.  The broil element is most likely your only heat source if it took that long to cook the pie.  Need to verify that the bake element is coming on.  If it isn't then the problem is either in the control or the element itself.  Give me the model # off the sticker on the oven and I can help you do the check out.  In the mean time see if the bake element is getting hot.
Maytag MER5552BAW / MER5552BAQ / MER5552BAB Electric Kitchen Range Logo
203 people viewed this question
Top Maytag Kitchen Ranges Experts
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
