Question about LRD2200SWS Radar Detector
Need the cigarette ligher connection to the LRD2200SWS
Can anyone point me to where I can find the cigarette lighter connection to the LRD2200SWS?
  • 3 Answers
I would go to your nearest Radio Shack or Walmart. They have a plug that has different ends to match your unit. Please let me know if this helps you.
Posted on Oct 02, 2008
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
1994 Mitsubuishi 3000GT
shorting cigarette lighter element or faulty socket blowing the fuses
Dec 20, 2016 | 1994 Mitsubishi 3000GT
Cigarette Lighter Outlet Doesn't Work; Fuse Still Intact
If the cigarette lighter has been in use for cigarettes ... it could be that the contacts within lighter outlet contact points are heat damaged and connection to auxiliary device may not be made electrically ... You could test if you had a voltmeter ... but if you can visibly see heat damage... perhaps you could try scratching any obvious tarnished metal contact point with screw driver... . (the central contact point is the one that is likely to be tarnished requiring cleaning) unless it is a loose electrical conection gone bad... but that would require removing the cigarette lighter.
Note: recommend to remove the cigarette lighter fuse before attempting to insert a metal object into the cigarette lighter... else sparks may fly and the fuse will/or should blow.
good luck.
Feb 27, 2015 | Volkswagen 2006-2010 Jetta TDI Steering...
1994 honda accord can't fine fuse for my cigarette ligher to replace
In earlier model vehicles, the cigarette lighter is on the same circuit as the dash lights/ radio/ interior lights. Maybe it's not labeled as cigarette lighter, try other fuses. also, there should be a fuse panel both inside dash and under the hood. Also, sometimes there can be an in-line fuse right behind the cigarette lighter.
Oct 21, 2010 | 1994 Honda Accord
The cigarette lighter on my 2001 ford escort zx2 does not work. It isn't a fuse and there is no power going to the leads that connect to the lighter. Can't figure this out. please help. John C.
FYI, the ligher only gets power when the key is on. If it doesn't have power even with the key on, then the leads probably came off the back of the lighter.
Jan 09, 2010 | 2001 Ford Escort ZX2
Cigarette lighters not working
Most fuse boxes on Toyota products are located under the hood. They are well marked and have a plastic cover on them.
Jun 29, 2009 | 2001 Toyota Prius
Cigarette Lighter not working
The front lighter is powered by fuse 24(20 amp) in the interior fuse panel and the other lighter or power point is powered by fuse 12 (20 amp) in the under hood fuse box
May 08, 2009 | 2005 Ford Escape
Hi, I am trying to connect my GPS to the cigratte lighter and its not charging it. I spoke to one of the mechanics and he told me that cigratte lighter connection is only used for cigrattes ligher you
Remember, the lighter outlet is only hot when the vehicle is running. Few vehicles come with an aux outlet that is hot all the time. Trucks do but not cars.
Apr 23, 2009 | GPS
1999 toyota corolla cigarette lighter works but electronics do no
a lot of cars are that way u need to have it changed to a power point adapter should not cost to much GM is famous for doing this even though it does not make sense
Jan 07, 2009 | 2000 Toyota Corolla
Cigarette lighter not working properly in Pontiac...
This is a very common issue, either the ground at the back of the lighter socket is pulled off, or more likely the socket is defective, they are very easy to change, u can use a generic replacement from any parts store, the factory part will be at least 2X as much..
Jan 05, 2009 | 2003 Pontiac Grand Am
LRD2200SWS Radar Detector Logo
117 people viewed this question
Top Uniden Vehicle Parts & Accessories Experts
John Nolan
Greg Cann
Greg Cann
Are you an Uniden Vehicle Part and Accessory Expert? Answer questions, earn points and help others
