Question about Samsung SCH-a670
DEAD PHONE Our SCH-a670 seems dead. I thought the battery had died, but it stays off and non responsive even with a new battery and the charger plugged in. We used this phone successfully for several years. And yes, we DO know where the on switch is. Anyone have any ideas? Is the circuit board fried? And is there any way to retrieve the info from a deceased phone?
Leave it on for a few days then charge it and then see if it works. I am having the same problem now after 4 years worry free.
Posted on Oct 02, 2008
It keep giving me a message to plug in my charger because my battery is going dead so i bought a new dell charger the original one that goes with the netbook, and it worked for awhile, but now its telling...
it might be the battery, i had the same problem with my netbook the charger is ok but the battery died i can use it if it is plugged even if the battery is dead.you can tried taking the battery off the netbook if it turns on the charger is ok.
Sep 13, 2013 | Dell Inspiron Computers & Internet
My fone dead put charger in does nothing dead dead dead
Nokia phones are notorious for slow response time when recharging from a completely dead battery.
Remove battery.
Make sure there is good contact between all of the contact points.
Replace battery.
plug in charger.
wait for at least 5 min.
If recharge symbol does not appear in window, then one of these things has occurred:
1. Phone has internal damage or water damage. no way to fix without nokia service.
2. Battery is dead. Try a new battery
3. Charger is bad. Try a new/different car charger or home charger.
These chargers are very inexpensive on Craigs List, try to solve it before throwing away the phone. Good luck,
A former Nokia employee.
Feb 16, 2011 | Nokia Cell Phones
Samsung sch-a670 won't power on
wellcome,you can only change the phone panel instead,so that it will not just destroy the phone ok
Jul 28, 2009 | Samsung SCH-a670
Unlocking Samsung sch-a670
you cant cingular is a gsm network and verizon is cdsa
Jul 28, 2008 | Samsung SCH-a670
No power
Make sure you have an original OEM charger for the MDA. Many of the knock off chargers don't provide the right amperage for the device. What happens is that since the phone is completely dead, it can't regulate how many amps the battery should get during the charge and an incorrect charge current won't charge the battery. I'm guessing that someone sold you a Motorola RAZR charger or another knockoff made for the RAZR. This might charge your phone when the battery is working, but not when it's DEAD. Also you won't have luck plugging it into a computer USB cable because, again, the phone can't tell the computer what charge to send and most computers only produce <0.5 amps in the USB port.
Get a charger that states it is an OEM (original eqipment manufacturer) device or one that is specifically designed for the MDA (or Cingular 8125). eBay is full of them.
Bad charger (probably won't work for a dead battery)
Good Charger (correct amperage and designated for the MDA)
Jul 08, 2008 | T-Mobile MDA
Not charging
i think ur phons circuit is short .so thats why
Nov 27, 2007 | Nokia 5500 Sport Cellular Phone
Nokia 6021
Take it to your service dealer and ask them to test it and if possible to retrieve your data. Sometimes they will be able to make the phone work long enough to be successful. You will likely have to replace the phone anyway, so this process will relocate your numbers to your new phone if successful.
Nov 01, 2007 | Samsung SCH-a670
My phone dosent turn on or nothinq
When the battery is totally depleted, you will need to use a charger that came with the phone. Sometimes it will take a few mintues (give it 10) for the battery/charging circuit to come on.
Sometimes you can charge from other sources than the charger that came with the phone. You generally will need enough charge on the battery to start the phone.
Example: If I have enough battery to where the boots and turns off, I can generally get it to charge from USB or my car adapter. You will need to get the phone to turn on and boot most of the way up before it will take a low current charge. If my phone is so dead it will not even turn on, I must plug it into the AC adapter. Sometimes even then the light does not turn on right away.
The problem is probably due to the number of amps provided by the charger. When the battery is totally dead, the charging circuit is drawing so many amps that it will prevent low amp chargers from being able to do the job. That's why these phones have such heavy duty AC adapters.
Apr 28, 2006 | T-Mobile Sidekick II
Samsung SCH-a670 Logo
115 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
