My new cd/radio in my car mp3 cd tuner mosca111usb dosen't work lights keep flashing on and off when ignition on cant stop them with switch off button,just takes in cd no sound push eject button cd does eject, driving me nuts hope you can help.
  • susuki p Oct 10, 2008
    susuki p answering - cd/radio ok now it's been a fortnight since i put it in the car booked it in garage to get sorted out 4 oclock on thursday, picked up boy on school run bought him home while parking up the radio burst into life so had it checked out anyway.radio negative earth only worked with aerial connected fitters earthed it working ok now thankyou.
    Genius:
  • 1,124 Answers
Check your setting and your wires connection. Sure something wrong.
Posted on Oct 10, 2008
    Master:
  • 479 Answers
You have not connected the wires properly or any of the connected wire has loosed inside please check it properly.
Posted on Oct 01, 2008
  • tech gurus Oct 01, 2008
    on the dashboard fuse panel find the radio fuse pull it out and put it back in with the fuse tool. This resets your radio,
Radio in my 2000 Skoda Fabia keeps jumping from tuner to cassette mode
It is an internal radio problem, Not worth fixing. Replace it. cheaper.
Apr 06, 2016 | 2000 Skoda Fabia
My pioneer radio wont stay tuned in
You need a 12 volt battery connection at the stereo.
Aug 11, 2012 | Pioneer Deh-1420ub Car Stereo Cd Mp3 Wma...
2003 alero steering won't lock and nothing happens when you turn the key in the ignition
If the security light keeps flashing,you might as well do a reset.
Be sure to turn off all the accesories including the radio before you start the process.
Insert the key to the ignition switch and turn the key to ON position without starting the car.
leave it ON until the flashing light (security) stops.It will take approximately 15 to 20 minutes.
As soon the flashing stop,turn the key to OFF
position and start the cart.
Hope this help.
Jul 23, 2011 | 2003 Oldsmobile Alero
When i have the stereo on radio my amp/subs work fine, but as soon as i switch the mode to USB ( built in ipod connector) it cuts out the power to the amp/subs. It only works on tuner mode (radio) why?
use the blue/white wire (amplifier remote turn on) instead of the blue wire (power antenna remote turn on) to turn your amp on. the power antenna wire shuts off when leaving tuner mode.
Mar 02, 2011 | Sony DSX-S100 Car CD/ MP3 Player
What color wire goes were on a pioner super tuner deh-10 i cant get the lights on the tuner to come on or when i have it wired every thing works but no lights and it wont take in the cd it will when i push...
unplug all wires and try these basic ones.red(power/ignition), yellow(power/battery voltage), and black(negative/ground). connect all those, and try to power it up and insert a cd. if it still gives you the same problem, then the radio is bad.
Feb 16, 2010 | Car Audio & Video
When I switch the source mode my satellite radio option does not appear
Make sure the tuner is getting power, and the DIN cable is pushed all the way in to the back of the radio..If you don't have the seperate SAT tuner then there is your problem..
Aug 06, 2009 | Alpine CDA-9886 Car CD/ MP3 Player
I just bought a new pioneer cd player and i put a cd inside and it plays it normally but suddenly it changes to radio stations it's very strange
That is the symptom of a faulty selector switch. That's causing automatically switch up from CD to tuner station. Replaced the selector switch with a new one, so ks normal again.
Good luck;
Don't forget to rate:
Jul 10, 2009 | Pioneer DEH-2000MP MP3 CD AM/FM Car Stereo...
How to use mp3 with kenwood kdc mp235
turn radio to stanby. hold function key until a menu appears. then switch on aux in. this should alow you to plug ipod in throough aux in on source menu.
May 15, 2009 | Kenwood KDC-MP235 CD Player
How to connect a pioneer super tuner to a 91 honda accord
With a DC voltage tester, check the two power leads for 12+ volts and proper operation, and be sure the unit is properly grounded.
The two power leads are,
1.Constant feed: which should be connected to an un-switched power source that delivers continuous
power to the units memory.
2.Switched feed: which should be connected to a switched power source controlled by the vehicles ignition switch.
Before installing in dash check unit for proper operation.
Good luck
Aduz
Mar 27, 2009 | Pioneer DEH-P2900MP CD Receiver...
MP3, IPOD, CD doesn't appear when I press "Source"
Easy.
If you read your owner's maunal, page 26, the USB is designed for a flash drive (up to 4GB), not an Ipod.
If you would like to play your iPOD, purchase the IPC008 (Ipod Lead) and you're done!
Feb 24, 2009 | Eclipse CD1200 Car CD/ MP3 Player
99 people viewed this question
 Grubhead
Grubhead
